Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 14th June 2006, 07:56 AM
luciano luciano is offline
Involved - Posts
Registration Date: May 2006
Thanks Given to Others: 102
Karma Power: 17
luciano has less than 100 Karma points so far.
Question Is AQL necessary for ISO 9001 receiving inspection?
Hello friends
In need some help to understand if I need AQL for incoming inspection or not for ISO 9001.
I am trying to implement ISO 9001 in the factory where I work, and I don't know what to do.
If I don't need AQL, how I will establish the appropriate sample for inspection.
If I need AQL, which is more proper.
Thank all of you very much.
Sponsored Links
Old 14th June 2006, 08:54 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default Re: Is AQL necessary for ISO 9001 receiving inspection?
Originally Posted by luciano
Hello friends
"AQL" (acceptable quality level) isn't necessarily related to sampling inspection; it can be applied as a result of sorting, for example. What do you do now to verify purchased material before use? Some companies do a lot of receiving inspection using standardized sampling plans (what you refer to as "AQL," I presume) and others little or none, opting instead to develop suppliers and rely on them to provide conforming material. There is no ISO requirement for receiving inspection, per se.
Sponsored Links
Old 14th June 2006, 10:02 AM
Involved - Posts
Karma Power: 17
Thank you Jim
I had some audits frome our costumers, and they ask me to show the criterions for incoming inspections. I don't have options to not verify the purchased material., and this inspections need to be veriy documented. I think, I can't verify 2000 part like 50000.
What do you suggest ?
Many, many thanks .
Old 14th June 2006, 10:10 AM
Jim Wynne's Avatar
Courtesy Access
Karma Power: 612
Thank you Jim
Many, many thanks .
You didn't answer the question--what do you do now? What, if any, specific objections did your customers raise? What sort of problems do you have with acceptance of nonconforming material?
As a starting point, you should use the Cove's search function, starting with the threads listed towards the bottom of this page. There's lots of information here regarding sampling inspection and sampling plans.
Old 16th June 2006, 06:42 AM
Involved - Posts
Karma Power: 17
Sorry because I din not answer to your question ?
Yesterday I had a free day, and I was not to work.
What I am doing now ? - to answer the question;
When I recive the suplly material I have a chekclist.
In my chekclist I am looking to:
1. If the material exist in my approved material list
2. if the supplier are approved
3. Documents (quality certificate)
4 I evaluate the conformity of quality certificate with tehnical characteristics
5 compare the material with master specimen
6 pack condition
(this is for plastic material . I work in a plastic mold injection factory)
For ather materials (pipes)
1.I masure diferent kind of dimensions
2 ...
But I don't know the proper sample size for quantity recived.
I had read the discution from forum.
Thank you for your time
Old 18th August 2006, 11:56 AM
Johnson Johnson is offline
E-Mails Invalid or Rejected
Registration Date: Mar 2006
Karma Power: 0
Johnson is appreciated, and has over 100 Karma points.
I don't think AQL is a must. But it is a method which might be given up.
As an automotive supplier,the quality acceptance levl is zero. If one part is found with defect, the whole lot should be rejected no matter how large is the lot size.
I always use a fixed sample sie for receiving inspection. But th eacceptance cretiria is always zero !!! And there is no problem at all for customer auidtand the third aprty audit.
Best Regards,
Johnson Shao
Old 21st August 2006, 02:31 AM
Involved - Posts
Karma Power: 17
Originally Posted by Johnson View Post
Best Regards,
Johnson Shao
Thank you very much for your advice
My question is: How can I know the size of my sample to be relevant ?
Which are the rules to establish the size of my sample ?
Is percentage from the quantity recived ?
Best regards
God bless you
Thank you for your ansver
Old 21st August 2006, 02:56 AM
Gert Sorensen's Avatar
Gert Sorensen Gert Sorensen is offline
QA Systems Coordinator
Registration Date: Apr 2006
Thanks Given to Others: 327
Karma Power: 73
Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.Gert Sorensen is appreciated, and has over 1700 Karma points.
Hi Luciano,
If you want to use AQL then this is what you need:
ISO 2859-1: Sampling procedures for inspection by attributes - Part 1: Sampling schemes indexed by acceptable quality limit (AQL) for lot-by-lot inspection.
Determine what quality level you can accept, and simply use the tables given in the standard to determine sample size and rejection criteria.
However, in order to help you further you need to elaborate a bit on what kind of raw materials you want to inspect. Is it compounds, foils, moulded items or?????
Beetle Bailey Rules!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Critical Characteristics in Incoming (Receiving) Inspection - Inspection Levels luciano Inspection and Test, Sampling and Related Topics 14 20th October 2009 01:54 AM
Receiving Inspection Procedure - Visual inspection defined little__cee Inspection and Test, Sampling and Related Topics 12 9th October 2009 12:25 PM
Incoming (Receiving) Inspection - Is it really necessary that we follow the AQL? Libie AQL - Acceptable Quality Level 7 23rd August 2007 09:23 AM
Process Control Plan and Inspection Plans - Receiving and final inspection required? krishkaar Inspection and Test, Sampling and Related Topics 8 3rd November 2004 07:46 AM
4.10 Inspection and Testing - Do we have to do AQL (MIL-Std-105) sample inspection? Bonnie AQL - Acceptable Quality Level 3 13th September 1998 10:46 PM
The time now is 11:15 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
