Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th June 2006, 12:24 PM
JtHall JtHall is offline
Registration Date: Jun 2006
Karma Power: 14
JtHall has less than 100 Karma points so far.
Question Fitting an Equation to a set of data? Does minitab have the capability?
Does minitab have the capability to take a formula and fit it to a set of data?
For example I have a data set for force versus time and i have an equation that should fit it, however it has two unknowns. I was hoping i could put this equation into minitab with the data set and have minitab estimate the unkowns by fittign the equation to the data set.
The problem is my experience with minitab is limited and
I dont know how or even if I can do this. Any help would be appreciated.
Jon
Sponsored Links
Old 19th June 2006, 01:02 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default Re: Fitting an Equation to data?
Jon,
Minitab certainly has the ability to fit certain equations to a data set - like straight lines or any number of typical statisitical functions.
If it is something more specific then I don't know that Minitab has any good way of doing that.
On the other hand, there is always Excel. Excel has several built-in fitting possibilities. If that still doesn't cover the function you need, I have used found ways to get Excel to automatically do a least-squares fit worse functions than this using the "solver" ability.
Let me know more specifically what you need, and I'll see what I can think of that might work.
Tim F
Sponsored Links
Old 19th June 2006, 01:45 PM
Karma Power: 14
What i start with is a set of 8000+ data points measured by an instrument. Then I have a specific equation that should fit this set of data. It has four unknowns, I can find two by hand. That leaves me with an equation with two unknowns. I need to somehow find these two unknowns. I was hoping I could do so by fitting the equation to my data set.
The solver tool in excel seems promising I have been playing around with it a little but i havent figured it out completely.
Thanks,
Jon
Old 19th June 2006, 01:59 PM
Karma Power: 123
What I have done is set up a few extra cells with the coefficients to be adjusted (either the two or all four from your example). Then set up a column beside the data to calcualte the fitted value based on these coefficients and to desired formula. In the next column I calculate the (actual-fit)^2 for each row. Finally, I find the sum of all the values in that last column. As you adjust the coefficients, then the sum changes. When you get the smallest value for the sum, then by definition, you have acheived the least squares fit!
The adjustment can be made by hand - for example, just keep adjusting one and then the other until the sum is as small as you can reasonable get. It helps to make a graph to visualize what is happening. Or the adjustments can be done automatically by "Solver" - although sometimes it "gets of track" and can't automatically narrow in on a solution.
Tim F
Old 19th June 2006, 02:15 PM
Karma Power: 14
Thanks,
Ill give it a try.
Jon
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
What is the meaning of the Asterisk in Minitab distribution fitting? UniOfLimerick Using Minitab Software 1 12th September 2007 11:25 AM
Minitab Distribution Fitting 3 Parameters? UniOfLimerick Using Minitab Software 1 30th August 2007 03:48 PM
Capability Analysis - Dealing with non-normal data in Minitab alokb Using Minitab Software 2 26th November 2005 08:50 AM
Distinct data categories - [PV / R&R] - May I know what is this equation used for? match_stick82 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 5th October 2005 02:02 AM
SAE fitting Gauge Point use - How do I set up to use the gauge points? Andy2U Various Other Specifications, Standards, and related Requirements 0 12th May 2004 12:34 PM
The time now is 03:04 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
