The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Wooden Line
How to measure countersink angles of countersunk holes in sheet metal panels
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
countersink angle, countersunk hole, sheet metal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 27th June 2006, 12:21 PM
RCW's Avatar
RCW
Question How to measure countersink angles of countersunk holes in sheet metal panels
I am trying to measure the countersink angle of countersunk holes in sheet metal panels. I was told this could be done by using ball gages, placing several balls in the countersink, measuring their height off the panel, then by "using trigonometry, just calculate the angle."
Has anyone done this before? If so can you provide better instructions than what is listed above and/or the proper trig formula to use? Is there a better/easier way to measure the countersink angle? (I was looking into handheld gages to do this but they approximately $1000 each and have to be made for a specific diameter hole.)
Sponsored Links
  Post Number #2
Old 27th June 2006, 12:51 PM
Jim Wynne's Avatar
Re: How to measure countersink angles
In Reply to Parent Post by RCW
A couple of thoughts:
  • Chamfer/c'sink gages don't have to be that expensive; look here for example. (No specific recommendation implied, just a < $1000 example).
  • In general, precision measurement of c'sink angles is a waste of time, especially if the purpose is to fit the head of a standard fastener. Put a screw in and see if it fits like it should, and you're done. Also, if the c'sinking is a captive operation (i.e., done where the inspection is done), you can just verify the tool used to make the c'sink. If it's the proper angle, the angle isn't going to be an issue. C'sink depth is more often an issue, as clueless engineers specify c'sink diameters that are too large for the material thickness, resulting in the hole at the bottom of the c'sink being enlarged beyond its UTL.
Thanks to Jim Wynne for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 27th June 2006, 02:38 PM
RCW's Avatar
RCW
In Reply to Parent Post by Jim Wynne
I already looked into these types of gages and will probably be purchasing one. However these gages only measure the outer diameter of the countersink and not the angle.
A noble thought but when my customer comes in to look at my FAI data.....
My main purpose is to obtain equipment for data measurement & recording purposes. That and to keep my suppliers honest.
  • Also, if the c'sinking is a captive operation (i.e., done where the inspection is done), you can just verify the tool used to make the c'sink. If it's the proper angle, the angle isn't going to be an issue.
The items under inspection are from my suppliers so I don't have access to their tooling.
  • C'sink depth is more often an issue, as clueless engineers specify c'sink diameters that are too large for the material thickness, resulting in the hole at the bottom of the c'sink being enlarged beyond its UTL.
HIGHLY AGREED WITH!! I've seen countersunk holes that were approaching the diameter of the thru-hole. I've also inspected 2 identical pieces from the same lot and you can visually see a difference with the countersunk holes between the two units.
  Post Number #4
Old 27th June 2006, 02:44 PM
Jim Wynne's Avatar
My experience has been that telling customers that a verification like this doesn't add value is usually all that it takes. In most cases I've seen, they would rather see it verified with a screw. There are ways, of course, such as using a mold material, but it's messy and takes a while, and there's that ROI thing again. You can also keep your suppliers honest by using a screw. If the specification is for a 100-degree c'sink and they make 90s, you'll be able to tell in an instant, and hit your supplier over the head with incontrovertible evidence. Of course, it's best to avoid dishonest suppliers in the first place...
  Post Number #5
Old 27th June 2006, 02:48 PM
Jim Wynne's Avatar
One more thing...there's also often an issue with the block tolerance for angles (typically +/- 1 degree) and measurement of c'sinks. If a c'sink is specified at 100 degrees and the proper tool is used, it's never going to be 103 or 97. There is no point in compiling variable data, in other words, unless your supplier is scooping them out with spoon.
  Post Number #6
Old 27th June 2006, 02:56 PM
wweng7
Re: How to measure countersink angles of countersunk holes in sheet metal panels
Measuring angle of c'sk tool is OK as long as you do not have build-up on tool itself. If you need to inspect actual angle of c'sk on the panel you can make a mold and check angle on comparator.
  Post Number #7
Old 27th June 2006, 03:37 PM
Claes Gefvenberg's Avatar
Claes Gefvenberg
Lightbulb Re: How to measure countersink angles of countersunk holes in sheet metal panels
I have not used that particular method but the enclosed drawing shows how to find the triangle you need. The rest, as your friend said, is trigonometry...sin x = (r1-r2)/height diff. Ordinary bearing balls can be used, no need for an expensive gauge.
/Claes
Thanks to Claes Gefvenberg for your informative Post and/or Attachment!
  Post Number #8
Old 28th June 2006, 08:14 AM
andygr's Avatar
andygr
The use of the hight differance between ball of known sizes works well for angle actuals. An additional option is to cast the countersink and use an optical comparitator to measure the replication.
Inspection of this feature on an on going basis should be concentrated on the set up. The countersink angle changes as the cutter wears. Once you verify the actual dimension to address recording actual values for an as9102 FAI then move to process control. Check the first and last and all inbetween should be good. Key features are the oriantation of the cutting tool and restraining of the part.
Reply
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
How to Measure Chamfer Angles jdm2008 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6 28th March 2013 12:59 PM
What do 'Read Across', 'Drill Deep' & '6 Panels' mean in GM's QSB Sheet? miley TS 16949 - International Automotive Quality Systems Standard 2 7th June 2011 10:19 AM
How to Measure over 100 inches on Sheet Metal and hold ? .060" R. Webb Metrology Topics - Measurement Devices, Calibration and Test Laboratories 1 23rd July 2010 11:26 AM
Countersink Tools - Burrs on the bottom and at the top of the holes sergiov Manufacturing and Related Processes 3 29th October 2009 06:17 PM
How to Measure thickness of Carbon Fibre Panels lee01 Metrology Topics - Measurement Devices, Calibration and Test Laboratories 7 9th July 2004 06:51 AM
The time now is 05:02 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
