The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Wooden Line
How do I calculate Gage R&R (GR&R) with 1 tester, 1 operator, 3x4 units?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Reply
  Post Number #1
Old 12th July 2006, 03:49 PM
iii_v
Question How do I calculate Gage R&R (GR&R) with 1 tester, 1 operator, 3x4 units?
hello all,
I apologize in advance if this is has been hashed out (or so basic it's not worth asking). but i couldn't do a good search to find what i need.
by the way, I'm spanking-new to QA.. and I'm frantically trying to figure out what I'm trying to calculate... so please bear with me.
A customer has asked for GR&R information on our test setup. I think we have data to generate the value, but I have no idea how to calculate it.
1 test equipment
1 operator
3 control units that has 4 channels (essentially 3x4=12 separate measurements per test)
50+ tests (yes. 50x12 data points!)
I can get stdev for each separate channel (have 12 separate stdev). after that, what do I do? also another stupid question is, what unit is GR&R and what does it really mean? (e.g. GR&R=1 vs GR&R=10, 20, etc. I guess I'm sort of looking for a rule-of-thumb guidlines like, GR&R=y is ideal, GR&R=z is very bad, etc).
help!
Linda
Sponsored Links
  Post Number #2
Old 12th July 2006, 09:24 PM
Miner's Avatar
Re: How do I calculate GR&R with 1 tester, 1 operator, 3x4 units?
You cannot determine GRR with this setup. The best that you can do is determine repeatability, but not reproducibility. Given your criteria, I recommend performing the AIAG Stability study. A calculation shown in this method will provide the repeatability of the measurement system. Is there a reason that you cannot use multiple operators?
GRR results are either 5.15 or 6 standard deviations in the same measurement unit. However, this is typically converted into a percentage of the tolerance (P/T Ratio) or as a percentage of the process variation (% GRR). The rule for these ratios are: < 10% is ideal, < 30% may be acceptable depending on the importance of the characteristic, the feasibility of improving the measurement system, etc. and > 30% is not acceptable.
P/T Ratio is used to determine whether the gage is acceptable for inspection purposes. %GRR is used to determine whether the gage is acceptable for process control, capability studies or process improvement.
Thank You to Miner for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 13th July 2006, 03:53 AM
jrubio's Avatar
jrubio
In Reply to Parent Post by iii_v
hello all,
1 test equipment
1 operator
You need:
1 test equipment
2 operators, Just see the Templete. See Atachement
Althoug this Version is now Obsolet, The costant has changed, Update it.
10 meassurements times two for Every Operator
By two Operators means 40 meassurents, See templete.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Gage R&R - Digital Torque Wrenches - 5-50 nM range units brucep@magna Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12 26th March 2013 08:09 AM
How to calculate Relative Uncertainty - Measurements are in different units amanbhai Measurement Uncertainty (MU) 4 12th November 2010 03:19 AM
Gage R&R on a Tensile Tester RosieA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 11th August 2010 09:47 PM
How to calculate supplier PPM with multiple units vallesj Supplier Quality Assurance and other Supplier Issues 9 3rd September 2008 09:03 AM
Independent Tests - Another operator or tester to do the final test? b3playa Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2 10th April 2006 03:24 PM
The time now is 04:45 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
