Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 20th July 2006, 04:48 PM
davis007 davis007 is offline
E-Mails Invalid or Rejected
Registration Date: Aug 2005
Karma Power: 0
davis007 has less than 100 Karma points so far.
Please Help! Minitab refuses to run saying the Design is Not Balanced - Gage R&R
OK i was asked to do a GR&R on some equipment we have. This equipment feeds vials onto a conveying system and uses a single camera to make a measurement of each vial. How the vial is presented to the camera is likely to be important in the measurement. To check if the measurements are repeatable and reproducable accross all vial holders on the conveying system I was asked to do a GR&R.
As there are 60 holders and getting the data from the equipment takes about 1 min for each sample. It was not reasonable to measure each vial on each holder repeated times. So I took 60 "identical" vials and labled them. I ran these vials through the equipment in order and noted which holder the first vial loaded onto. I then repeated 2 more times ensuring that the first vial always loaded onto the same holder. All the other vials followed in sequence.
I then repeated the test 3 more time ensuring that for this set of three tests the first vial loaded onto a different holder than was used for the first three runs.
I then pulled the 360 data points from the photos the camera took of the parts.
All this went into Minitab in hopes of runninga GR&R BUT it refuses to run saying the design is not balanced. Is this a requirement? If it is I can not run 60 vials on each holder. there are 60 holder that would be 3600 runs. Ineed this done by Monday. Is there another way to get the same indication of what the components of the measurement variabilty are?
Sponsored Links
Old 20th July 2006, 05:28 PM
apestate apestate is offline
Registration Date: Jan 2003
Thanks Given to Others: 2
Karma Power: 59
apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.apestate is appreciated, and has over 1100 Karma points.
Default Re: GR&R - Minitab refuses to run saying the design is not balanced
Hrm I wish I could be of some use but I'm totally unprepared...
I therefore refer you to http://elsmar.com/Forums/showpost.php?p=98579 with an excel template for GRR that should be suitable to your variables measurement.
Someone else might assist you with your technique and issue of operators = 0.
Some questions... What is the resolution of the camera? Can it discriminate between 1cc or .01cc difference in fluid level, for example?
What is the acceptable tolerance on volume in the vials?
Is this your first GR&R analysis on the vial camera measurement system?
And curious myself, is this Banner Engineering equipment and software?
Sponsored Links
Old 20th July 2006, 05:40 PM
Karma Power: 0
I guess the way I am looking at it the "operators" are the holders and I have 60 of them.
For each holder "operator" I have 6 data points, 3 one one vial and 3 on another. To me this is just a highly fractionated DOE. I can not get "Operator" part variability. But I should be able to obtain "operator", part and total variability correct? The total - "operator" - part should be the ("operator" by part and the repetability).
Does this make sense?
Old 20th July 2006, 06:03 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Can you post your data? The way you describe it, it should be possible to analyze the data set.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Old 20th July 2006, 06:07 PM
Karma Power: 0
Excell file should be attached.
Part - 1-60 numbers parts
Chuck -1-60 number of holder on conveyer belt
edge_one - first response
edge_two - second response
fail - not relavent ot this question.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 21st July 2006, 10:24 AM
Karma Power: 0
Can anyone helpme get some data from this?
When I plot EDGE_one by vial I get a great deal of scatter, by chuck I get scatter as well but many of the ranges from one chuck to another do not overlap. This makes me suspect that which chuck is used makes a difference in the result. ANOVA of the data supports this conclusion. BUT how do I determine what fraction of total variation in the data is due to chuck?
Old 21st July 2006, 02:36 PM
Miner's Avatar
Karma Power: 251
The reason Minitab choked on your data was because you have a nested design. The standard GRR format is a fully crossed design. You must use the nested study format within Mintab.
I have attached the results of this analysis below. I also included some graphical plots of the data. It appears that you had a major shift between your first response and your second response. This shows up in the Repeatability source of variation.
Old 21st July 2006, 05:14 PM
Karma Power: 0
Miner,
Thanks for your help. Running the nested GR&R works. BUT..... I get differnt results than you show. Did you treat EDGE-one and EDGE-two as repeats of the same measuremnt? They are actually different measurements not repeats. If do a GR&R on EDGE_ONE I get:
%Contribution
Source VarComp (of VarComp)
Total Gage R&R 7.68795 99.75
Repeatability 0.36026 4.67
Reproducibility 7.32770 95.07
Part-To-Part 0.01937 0.25
Total Variation 7.70733 100.00
Which I am interpreting to mean that going from chuck to chuck give different results. Differences between operators is high.
When I do the same thing on EDGE_two I get:
%Contribution
Total Gage R&R 4.3291 18.71
Repeatability 4.1779 18.06
Reproducibility 0.1513 0.65
Part-To-Part 18.8076 81.29
Total Variation 23.1367 100.00
Which I am interpreting to mean that the part to part variation is high compared to the operator to operator variation.
Make sense?
Thanks again for all your help.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Minitab error response: "Design is not balanced; execution aborted" PaulSanda Using Minitab Software 4 9th November 2009 08:02 PM
Gage R&R or Anova two way? Using Minitab ed1978 Using Minitab Software 1 14th October 2009 08:23 PM
Gage R&R nested on Minitab JCWKJW Using Minitab Software 1 29th September 2009 07:30 PM
Unilateral Gage R&R (GR&R) - Minitab 13 - Does this study pass or fail and WHY? justncredible Using Minitab Software 17 12th December 2006 06:47 AM
Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories Geoff Cotton Using Minitab Software 4 27th May 2003 04:55 PM
The time now is 09:16 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
