The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 4th August 2006, 12:16 PM
True Position's Avatar
True Position True Position is offline
per ASME Y14.5M-1994
Registration Date: Feb 2005
Thanks Given to Others: 5
Karma Power: 102
True Position is appreciated, and has over 1700 Karma points.
True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.
Please Help! Gear / Spline Gaging - Both Internal and External Splines
Recently I've been tasked with gaging a large number of both internal and external splines. The company I work for will not be manufacturing these multiple splines, so fixed gaging is basically out.
The charactaristics it seems the customer is most interested in are Major Diameter, Minor Diameter, Pitch Diameter, and Tooth Thickness.
For OD splines, I've used hand micrometers (and gage pins) for the Major/Minor/Pitch in the past at previous employers, but I'm unsure if the accuracy is going to be high enough, and then there's the issue of the ID splines and Tooth Thickness. My knowledge of gaging tooth thickness is somewhat limited, reading my textbooks doesn't include much, and the machinery handbook includes a moderately convoluted formula that works off the pitch diameter.
My basic question is, what do the rest of you use in the situation? Am I looking at something like a Universal Supermicrometer/Bench Gage?
Sponsored Links
Old 4th August 2006, 08:04 PM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is online now
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 918
Karma Power: 400
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Lightbulb Re: Gear / Spline Gaging - Both Internal and External Splines
In Reply to Parent Post by Hawat
Questions first:
Why is fixed gaging out? Any mistakes will cost you, and a large number could make it worthwhile. How large a number?
Your avatar leads me to assume that you have a CMM at your disposal? So did I once, and for the most commonly used dimensions, I used to get probes (balls) in the same diameter as the gage pins (a bit expensive, yes), and use them to measure cross sections along the splines (one needs to be careful, though. Anywhere near tol limits, and you need to check it with a better method. After all, the requirement is for the entire spline).
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Sponsored Links
Old 5th August 2006, 12:17 PM
Karma Power: 102
Fixed gaging is out because we are only going to be checking on average 8 of each spline per month and there are several of them. The costs of fixed limit gages for a number of splines(each spline in a transmission) gets quite expensive for marginal results.
As to the CMM, I've tried in the past to use it for major(external), but your typical rolled spline isn't very flat near the top and I was having pretty wildly fluxuating results, I couldn't imagine what my GRR would look like. For minor(external) you'd need some very fine probes to get close. As to pitch, I never did consider getting custom CMM stylii. Your procedure was then, to probe each of the gaps, determine the diameter, subtract the probe diameter, and use that as your measure over pins? Ingenious.
I contacted Zeiss about their GearPro Involute software and Rotary Table, sadly the line of machines that I was purchased cannot use this software.
When you said you used a more accurate method, what are you talking about? M&M Profile checker?
Old 5th August 2006, 02:38 PM
Forum Administrator
Karma Power: 400
Yin Yang Re: Gear / Spline Gaging - Both Internal and External Splines
Exactly
That, I'm afraid, was when I went back to my trusty pins + gage blocks (internal) and pins + micrometer (external)... I just used the CMM to weed out the parts I needed to have a closer look at.
/Claes
Hanlon's Razor.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Your Internal Audit Team: Internal or Hired External? Outsourcing Internal Audits? Crusader Internal Auditing 96 12th April 2013 05:23 PM
Using PC-DMIS to measure True Position of the teeth of a Spline ystark Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1 20th November 2011 06:21 AM
Circular or Total Runout Gears and Splines? optomist1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6 29th July 2011 02:01 PM
Calibration Procedure for Internal Spline Plug Gage Needed Lab Geezer ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 4 27th April 2011 10:51 AM
CMM Output Dilemma - Splines are not very friendly to work with Ron Rompen ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 13th March 2006 01:16 PM
The time now is 10:11 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
