Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th August 2006, 09:14 AM
joonyeen joonyeen is offline
Registration Date: Aug 2006
Karma Power: 14
joonyeen has less than 100 Karma points so far.
Question 3 sets of Data. Possible to acquire the 4th with MINITAB?
Hi there everyone in the cove!!!
My first ever visit and hoping for many more to come. I have come to the usage of this programme (minitab) 2 weeks ago and found that my knowledge is really limited. I am currently a uni Student and am trying to interpret results for the tribology department.
I am currently working on datas from this experiment :
Machine - Optimol SRV III
Variables
- Temperature (-40, 25, 100, 200, 250)
- Lubrication ( A, B)
- material of the metal piece (C, D)
In this experiment, the ceramic sphere is sitting on a metal piece. It is then acted on by a constant force and oscillates horizontally with a constant amplitude, different lubrication, and also in different temperature. The resulted calotte on the sphere is then measured in mm.
My professor has given me 3 sets of datas:
1 - A and C
2 - A and D
3 - B and C
with the help of MINITAB, i have plot graphs and can make assumptions on the difference between these 3 combinations.
the question now is, am i able to use MINITAB to come out with the 4th set of data which is the usage of the combination of B and D
hereby i thank you in advance if any one of you could help me in this. thank you very much!!!!
Sponsored Links
Old 10th August 2006, 11:34 AM
ezorangee ezorangee is offline
Involved - Posts
Registration Date: Sep 2005
Thanks Given to Others: 6
Karma Power: 19
ezorangee is appreciated, and has over 100 Karma points.ezorangee is appreciated, and has over 100 Karma points.
Default Re: 3 sets of Data. Possible to acquire the 4th with MINITAB?
I need some more information....Are you doing a designed experiment with three factors....Temperature, Lubrication, and Material? Is the data the professor gave you the responses for this experiment? I'm sorry for my confusion, but I am not sure what you mean by aquiring the 4th data set.
Regards
Sponsored Links
Old 10th August 2006, 12:01 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
If I understand correctly, you are trying to predict what would happen if you ran the experiment with B & D, but that combination has not actually been tried.
If you assume linear relationships and no interactions for lubrication and material, then you could come up with a prediction for the combination B & D.
  • Experiments 1 & 2 hold A constant, so you could compare the effects of C vs D.
  • Experiments 1 & 3 hold C constant, so you could compare the effects of A vs B.
Once you know the effect of A vs B and the effect of C vs D, you could predict the results if you tried B & D
For example, suppose the results were
  • Experiment 1 (A&C): 10 mm
  • Experiment 2 (A&D): 12 mm
  • Experiment 3 (B&C): 13 mm
Going from C to D increases the result by 2 mm, so you could increase the result of Experiment 3 by 2 mm to predict 15 mm for B&D. (Or going from A to B increases the result by 3 mm, so you could increase the result of Experiment 2 by 3 mm to again predict 15 mm for B&D.)
Of course, this makes some pretty major assumptions about linearity and lack of interaction. If this is not true, or if random variations are a significant factor, then the predictions may be no good at all.
Tim F
Old 10th August 2006, 12:21 PM
Karma Power: 14
hi there,
the data given are the responses from the experiment which i have carried out. It is indeed an experiment with 3 variables.
i am trying to predict the result for the combination of B and D. i might or might not be doing the experiment base on these 2 variables, but i was asked to find out what the outcome will be, or what the assumption will be. In a way, it will help in saving cost and time when carrying out further experiments in the sense that if something that we assume has no result, we will not waste time and effort in continuing doing so.
thanks ...
Regards
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems jatabe Quality Tools, Improvement and Analysis 2 12th December 2007 08:01 PM
Robust Test for Two Data Sets - Tooling on an Injection Molding Machine rmacken SPC Monitoring and Statistical Analysis Techniques 2 11th October 2007 11:27 AM
Unidentifiable distributions? 2 sets of data - p Value less than 0.05 RMedrano SPC Monitoring and Statistical Analysis Techniques 34 11th May 2006 08:16 AM
Theoretical Analysis of Different Data Sets - Quality Concerns at Toyota Charmed Philosophy, Gurus, Controversy and Evolution 0 7th August 2004 04:15 AM
Gage Pin Quality - Buying new pin sets cheaper than calibrating our current sets Jeff McBroom ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 25th February 2001 01:29 AM
The time now is 08:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
