Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th August 2006, 09:58 AM
joonyeen joonyeen is offline
Registration Date: Aug 2006
Karma Power: 14
joonyeen has less than 100 Karma points so far.
Question To Decide Which Factor has the Highest Influence on the Results
Hi all,
Currently solving another problem, determining the influence of each given factor to check which has the highest influence. Objective of this is to eliminate factors which do not influence the outcome so greatly and can be forego to save cost and time.
any idea which test or which graph would be best to portray such results?
thanks,
joon yeen.
Sponsored Links
Old 15th August 2006, 12:07 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Default Re: To Decide Which Factor has the Highest Influence on the Results
You have many options to choose from. Here are three:
Perform a DOE (Designed Experiment) and display the main effects and interactions on an Effect Pareto chart (Minitab). This ranks the effects by strength and shows a line for significance of the effect.
Perform a Multi-Vari Study and graph the results stratified by the various factors to illustrate the relative effects.
A lesser known method used in Statistical Engineering is called a Diagnostic Tree. While this is not a Fault Tree Analysis, there are striking similarities. The Tree documents the potential sources of the Dominant Cause and the process of elimination used to narrow the search and identify the Dominant Cause.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 15th August 2006, 12:44 PM
harry harry is online now
Registration Date: Sep 2005
Thanks Given to Others: 572
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Are you familiar with multiple regression analysis? I think its one of the best tool for this purpose. A small program called 'Lindo' is normally used.
Regards.
Old 15th August 2006, 02:21 PM
jrubio's Avatar
jrubio jrubio is offline
Javier Rubio
Registration Date: Jun 2005
Thanks Given to Others: 2
Karma Power: 74
jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.
Send a message via MSN to jrubio
Miner.
Brilliant and outstanding response.
Best Regards from Cádiz Spain (Europe).
Javier Rubio Barragán.
Higher Industrial Engineer and Safety Master
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Whats the difference in applying error factor and correction factor? ggdjr ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 29th July 2008 08:14 PM
One Factor - Determining if Temperature is a contributing factor RMedrano Six Sigma 9 2nd April 2007 01:58 PM
PPAP Evidence - Material Results or Dimensional results Bigfoot APQP and PPAP 6 30th June 2004 10:46 AM
Using Certified Results from your Supplier - Chemistry report and Tensile results SteelWoman Supplier Quality Assurance and other Supplier Issues 12 27th April 2004 11:16 AM
The time now is 01:49 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
