16th August 2006, 06:56 AM
Registration Date: Dec 2005
Thanks Given to Others: 674
Karma Power: 176
FDA Requirements for Document Approval by Quality Department
With reference to FDA, have heard many times that there should be Quality approval for all documents that impact the quality systems. Can anyone let me know where is it mentioned that the Quality personnel should be the final approver of documents ?
I have no special talents. I am only passionately curious - Albert Einstein
16th August 2006, 11:31 AM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Re: FDA Requirements for Document Approval by Quality Department
Originally Posted by Qualityalways
No one says FINAL approval, merely "approval."
Typically, in many larger companies, Quality department is only one of several signoffs, ALL of which are required before FINAL approval is bestowed and implementation allowed.
The original concept of multiple signoffs was to bring a multi-disciplinary approach to each new or revised version, but, alas, too often, the group of signers neglect real review and merely rubber stamp the documents, resulting in egregious errors.
16th August 2006, 11:34 AM
Registration Date: May 2003
Thanks Given to Others: 389
Karma Power: 128
... have heard many times ...
Heard from whom?
First thing each morning, I try on my bathing suit. Then, nothing worse can happen the rest of the day.
16th August 2006, 11:40 AM
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 122
Karma Power: 109
(c) The quality control unit shall have the responsibility for approving or rejecting all procedures or specifications impacting on the identity, strength, quality, and purity of the drug product.
From 21 CFR part 211.22
As Wes said - this doesn't specify "final".
16th August 2006, 11:43 AM
Karma Power: 176
Heard from various people working in Pharmaceutical industry and also seen on documents which had Quality approval as a last signatory. In my all past work experiences in various multinational Pharmaceuticals, we had documentation requirements which had spelt Quality approvals to be taken as last but I could not get any reference to this requirement.
16th August 2006, 11:45 AM
Karma Power: 176
Thanks Discordian
Quality Manager
Karma Power: 397
Actually, as far as FDA is concerned, it isn't "approval" so much as "veto power." Veto power (another term for "empowerment") is something the best run companies are very liberal in spreading around. All would rather err on the side of caution than create life, health, safety issues.
