26th August 2006, 05:15 AM
Javier Rubio
Registration Date: Jun 2005
Thanks Given to Others: 2
Karma Power: 74
Are Process Maps Mandatory (Required)? TS 16949
Are process map mandatory?
Best Regards from Cádiz Spain (Europe).
Javier Rubio Barragán.
Higher Industrial Engineer and Safety Master
26th August 2006, 06:27 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Re: Are Process Map Mandatory? TS 16949
One existing discussion thread: Are we required to have process maps for each department? I think there are several existing discussion threads about requirements for process maps.
26th August 2006, 10:47 AM
Courtesy Access
Registration Date: Jan 2004
Thanks Given to Others: 10
Karma Power: 34
Re: Are Process Maps Mandatory? TS 16949
Yes. According to our TS auditor whom has just passed his re-cert exam. He told us that to fulfil the requirement of 4.1(a) and (b), the organization has to establish the process maps. However, it is not the IATF requirement to have a turtle diagram. Turtle analysis is just a recommendation but not a mandatory.
26th August 2006, 11:23 AM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Again, the vow of silence is broken
Your auditor is wrong. There is a requirement to define the sequence and interactions of processes, but there is no requirement to do it graphically. A written description will satisfy the requirement, for example.
There is no universally accepted definition of what a process map is, or must consist of, so how could it be a requirement?
26th August 2006, 09:24 PM
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
I would say that if they were mandatory, they would be mentioned in either the ISO/TS 16949 requirements (not there!) or in the 'TS Rules', IATF 'FAQ' or 'Sanctioned Interpretations' (not there either).
Therefore, they aren't mandatory. Anything an auditor says is, once again, a figment of their imagination. I've been to the AIAG training and it isn't in there, either!
Andy
'Cause you know sometimes words have two meanings.....
27th August 2006, 04:46 AM
Javier Rubio
Karma Power: 74
Andy
Jim welcome, a pleasure
In the Check List 16949:2002 book Page 4 states:
In Spanish
Cualquier auditor ISO/TS 16949:2002 debe, por lo tanto, ser capaz de comprender el tratamiento de procesos de automoción IATF así como el tratamiento de procesos y el mapa de procesos de la organización auditada.
Ver cláusula 2.9 de las “Normas para las entidades de certificación ISO/TS 16949:2002 – 1ª edición”
Translating
Check List 16949:2002 Page 4 states
Every Auditor ISO/TS 16949:2002 must be able to undestand the Automobile process treatment IATF and the process treatment and map process of the audited company, See clasuse 2.9 Rules for Certification bodies ISO/TS 16949:2002
In this check list List 16949:2002 Page 5 (In Spanish version) include the process map proposed by IATF
see the link that I posted with the IATF process map (The best in my opinnion I have seen).
Please Critique my process map - Fiberglass business.
So it seems that IATF strongly recommended the process map and their interpretetion of processes interaction.
27th August 2006, 09:24 AM
Auditor/Consultant
Registration Date: Aug 2005
Thanks Given to Others: 389
Karma Power: 188
In Spanish
Translating
Well, there certainly appears to be a different spin in the Spanish than in the English. According to the rules, the English language version would be the prevaling determining requirement.
Also, note, the TS Checklist book was obsoleted by IATF. The contents and comments in it are no longer applicable.
The TS standard and Rules do not mention that process maps are required.
In the other post on this topic, my reply to your question indicated I like process maps, but as an auditor, I have to recognize it is a method, but other tools are acceptable as well. Such as, diagrams, flowcharts, circles connected with lines, photographs, post-it notes, spagetti diagrams, Turtles. You can also describe it with narrative text, describing how the pieces work together. There are surely other methods as well.
I certainly like flowcharts and process maps, but the standard leaves it flexible to allow each organization to select the methods best suited for its processes.
PS: a lot of companies will use different methods for different processes. For example, a linear production process lends itsef well to a flowchart. But some non-linear processes look silly on a flowchart and do much better in a diagram or narrative.
Relentlessly Pursue Excellence!
27th August 2006, 09:28 AM
Auditor/Consultant
Karma Power: 188
Jim is correct and the auditor you cited is wrong. By the way, I also "passed my TS auditor recertification." Passing the test does not make an auditor's opinion a normative criteria. It still has to be based on the standard and the Rules, and it ain't in there...
PS: that auditor would have missed those questions if he answered that way on the test.
PPS: welcome back Jimmie, we missed ya'
