Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 22nd December 1998, 09:14 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
Please Help! Capability Studies - Combining parts from two lots
If we have a capability problem and we need to do a capability study, can we get an accurate picture of taking 6 pieces from one lot (that's all we have) and 6 pieces of another lot and combining them together and doing a study on those 12 pieces or would it be inaccurate because of two different lots?
Sponsored Links
Old 23rd December 1998, 10:02 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Dawn,
Combining the two lots would create a bimodal distribution which introduces bias to your calculations. I believe that the answer is no. Don Winton (and I believe Howard Atkins?) dabble in the Advanced Statistics world and are probably a better source for a solution to your problem than me. I will offer my thoughts if no one can come up with anything.
Answers anyone?
Sponsored Links
Old 23rd December 1998, 09:23 PM
Karma Power: 0
Default
Kevin,
Even if they were ran at the same time?
Old 24th December 1998, 10:34 AM
Karma Power: 94
Default
Dawn,
If they were run at the same time, material source was identical (i.e. same coil of steel used on the same machine with the same initial set-up) then you should be alright. Essentially all you have done was to split a single population into two similar lot populations. They should have the same properties. If you can be sure by the records that this is your case, then combining the two sample lots is probably fine (this is assuming that the distributions are normal and that they have similar standard deviations).
I was really hoping that one of the big guns would bail me out and give you something a little more solid for you. But I hope this helps you some what. Happy Holidays!!
Old 24th December 1998, 07:07 PM
Karma Power: 0
Default
Kevin,
It appears to me you are one of the big leagues.
Thanks for the help - I will use your information as a yes when I go back to work on Monday.
Merry Christmas and Happy New Year!
Old 26th December 1998, 11:13 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Dawn,
You should not have a problem using the two different lots as long as they are representative of the process.
The better answer, of course, is to select lots that are current and running and in a state of statistical control. "THERE IS NO CAPABILITY WITHOUT CONTROL." Ott and Schilling, Process Quality Control, 1990. I assume you already knew that.
Kevin’s point about the bi-modal effects is correct as far as ‘lots’ go and care should be taken. Your observations concerning the ‘lots’ would seen to indicate they came from the same ‘run’ in which case you should be OK and Kevin’s responses are accurate.
“Essentially all you have done was to split a single population into two similar lot populations.” Kevin, more correctly stated, “Essentially all you have done was to split a single population into two similar lot samples.” Just a small point. :>)
I apologize for not joining this thread sooner. The ice storm that blew through here wrecked havoc on power. I have just now been restored and do not know how much longer it will last.
Regards,
Don
Old 28th December 1998, 09:09 AM
Karma Power: 94
Default
Don,
Thanks for the bail out. It is appreciated from this end. Happy New Year by the way!
Regards,
Kevin
Old 29th December 1998, 12:19 AM
Kelly Speiser
Unregistered Guest
Posts: n/a
Default
Don correctly pointed out that a capability study is valid when a process is in a state of statistical control (stabililty).
If Dawn were to use the 12 pieces and plot them on a an SPC chart, what chart should she use? An average and range chart could support n=2 and only 6 points to plot - not enough to show out of control conditions like 8 on one side, 8 trending and so on. An moving average and moving range may be suitable (described in Besterfield's Quality Control Book) to detect instability.
Also, could the 12 measurements be placed in a histogram and an examination for normality be suitable?
Just some more thought on the subject.
Kelly Speiser
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Combining Lots under ANSI/ASQC Z1.4 Inspection Sampling Plan aeroqual Inspection and Test, Sampling and Related Topics 1 16th March 2009 09:49 PM
Differences between Machine Capability and Product Capability studies Mumus Capability, Accuracy and Stability - Process, Machine, etc. 9 14th October 2007 12:01 PM
Capability Studies - Fewest Number of Parts for a Capability Study ivo Capability, Accuracy and Stability - Process, Machine, etc. 9 20th June 2006 04:25 PM
Machine Capability Studies: How many parts needed? Dawn SPC Monitoring and Statistical Analysis Techniques 11 21st March 2001 02:17 PM
Capability Studies - 5 different dimensions - How many parts? Dawn SPC Monitoring and Statistical Analysis Techniques 6 8th March 2000 03:31 PM
The time now is 11:07 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
