Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 2nd February 1999, 10:28 AM
Fanjun
Unregistered Guest
Posts: n/a
Default R&R difference between QS9000 and ASTM
I learned MSA a month ago. I found that the Reproducibility is smaller than the Repeatability in the calculation of Gage R&R. But in all standards of analytical method such as ASTM and ISO standards, Reproducibility is always bigger than Repeatability. How to explain it?
Sponsored Links
Old 2nd February 1999, 12:11 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Fanjun,
This should not be the case. Each should be based on the data collected and the respective variations. Perhaps a re-check of the references is in order. In some cases, variation across operators will be greater than variation across trials and vise versa.
Maybe someone else more knowledgeable in the mechanics of the MSA manual methodology could shed some light on this, but I believe the statistics of ANOVA (on which the R&R is based) would preclude this from happening.
Regards,
Don
Sponsored Links
Old 4th February 1999, 09:44 AM
Fanjun
Unregistered Guest
Posts: n/a
Default
I have some ASTM Standard Test Methods on hand such as ASTM D5708-95a , ASTM D2007-93 and so on. In D5708-95a,it says the Repeatability of Vanadium is 4.0 mg/kg,the Reproducibility of it is 19 mg/kg,when the concentration is 100 mg/kg. In D2007-93,the result is Repeatability: 1.3%, Reproducibility: 7.8%.
They all show that Reproducibility is bigger than Repeatability,and my other ASTM methods show the same case.
I think you can find them somewhere and will be kindly so as to give me an explanation.
Old 4th February 1999, 05:24 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
Fanjun,
My response was to indicate this is not ALWAYS the case. I could (and will if needed) provide examples where repeatability is larger than reproducibility. The LTV manual has some of this type.
Advice: Do not use examples as the condition. Variability exists just as much across operators as across trials.
Regards,
Don
Old 7th February 1999, 12:33 PM
Batman
Unregistered Guest
Posts: n/a
Default
Could it be that Fanjun is reading a particular test method, that has been analysed before? I could state that on a particular laser micrometer in my lab, on a particular shaft diameter, that the Equipment variation [Repeatability] is 11.1%, the Appraiser variation [Reproduceability]is 4.5% for a combined 12.03% (real example.) This test would of course vary the next time, but in general if I was writing a specification for the test method here I could state the above percentages?
Old 8th February 1999, 01:54 AM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
I think that is the case. Your example is is a good explanation of what I was trying to express.
As I stated, I could also provide others, but I believe your points are well taken and should provide enough explanation.
Regards,
Don
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ASTM D624 - Test Method for Tear Strength of Vulc. Rubber & Thermo. Elastomers guoyiivan Definitions, Acronyms, Abbreviations and Interpretations 1 7th July 2009 01:56 AM
Good Engineering Practice (GEP) & ASTM E2500 DRDDO ISO 13485 - Medical Devices - Quality Management Systems 2 24th April 2009 02:07 PM
Who can test to ASTM D808, ASTM D4327 and ASTM D1179 (Halide Ion) Gilberto Reliability Analysis - Predictions, Testing and Standards 1 27th July 2007 10:17 PM
What is the difference between D&D Review, D&D Verification and D&D Validation? issmart ISO 9001 - Quality Management Systems Standard 8 5th March 2007 06:14 AM
What is the difference between ISO9000 & QS9000? Marc QS-9000 - American Automotive Manufacturers Standard 0 23rd November 1999 12:55 PM
The time now is 02:03 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
