Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th February 1999, 11:00 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Lightbulb Range - Concepts such as mean, median, mode and range
Found this interesting:
-------Snip-------
I am taking my first ever statistics course. However as an elementary teacher, I did teach such concepts as mean, median, mode and range. In this course we learned that range is the highest score/data minus the lowest then add 1 to the difference. I had taught that the way to figure out the range was to simply subtract the lowest score/data from the highest. This is also the way it is done in the statistics program I have. My husband (a statistician) agrees with my method. Which method is correct? If the first method is correct, please explain the reason one adds 1 to the difference. Thanks!
In response to Range: {Not Mine, Don}
Dona, you and your husband is right. The method you used of subtracting the smallest data value from the largest is the correct way of calculating the sample range. The only possible alternative I could think of would be if you wanted to construct an unbiased estimate of the population range.
For example, suppose you have a uniform distribution between A and B, with both limits being unknown. You then calculate from the data, the sample range, r = largest minus smallest. This r necessarily is less than the population range, R=B-A. To obtain an unbiased estimate of R, you need to multiply r by (N+1)/(N-1), where N is the sample size. Note that this is a multiplicative factor, not an additive factor. In short, I can't think of any reason to add one to the sample range.
-------End Snip-------
Thoughts,
Regards,
Don
Sponsored Links
Old 16th February 1999, 10:50 AM
John C
Unregistered Guest
Posts: n/a
Default
Don,
My statistical training was always sketchy and is now very rusty, so I offer this only as a possible clue to the problem. I can’t vouch for it’s validity;
For variables, the range is highest minus lowest. That’s the way I was taught. eg measurement in inches; Highest 10, lowest 5. 10 - 5 = 5.
For attributes, it’s the number of consecutive attributes in the sample (or potential attributes, if all possible have not been observed) that gives the range, eg; marks on a screen; Highest sample had 10, lowest had 5. The range can be considered to include; 5, 6, 7, 8, 9 and 10. So that’s 6 levels of attributes. 10-5 = 5. 5+1 = 6.
rgds, John C
Sponsored Links
Old 16th February 1999, 02:44 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Don,
As part of figuring Sigma, finding the estimation and unbiased estimation is merely the result of data from a population or from a sample. As always, the sample always has potential error beyond the population estimate and n-1 is normally used.
Not sure why to add/subtract a 1 for the Range though. JC's explanation seems reasonable, but I can not confirm.
Old 16th February 1999, 10:38 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
For variables, the range is highest minus lowest. That’s the way I was taught. eg measurement in inches; Highest 10, lowest 5. 10 - 5 = 5. For attributes, it’s the number of consecutive attributes in the sample (or potential attributes, if all possible have not been observed) that gives the range, eg; marks on a screen; Highest sample had 10, lowest had 5. The range can be considered to include; 5, 6, 7, 8, 9 and 10. So that’s 6 levels of attributes. 10-5 = 5. 5+1 = 6.
Agreed. I believe the response cited was probably considering this example. Or rather, see below.
It is also possible that the respondent was thinking sigma rather than range. I posted this in order to see what the responses would be. Many thanks, guys.
Regards,
Don
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Moving Range or Range Charts for Subgrouped Data Manix SPC Monitoring and Statistical Analysis Techniques 6 4th March 2008 03:24 PM
Robust Threshold Range Levels Gilberto APQP and PPAP 1 3rd January 2007 08:14 AM
MS Excel -- Can a cell value be a range (1-2) apestate Excel .xls Spreadsheet Templates and Tools 12 8th June 2006 12:09 PM
Salary Range for a TS 16949 Coordinator? AMR123 Occupation Discussions 13 17th February 2004 02:13 PM
M&TE Temp. Operating Range vs. Specifications Marc ISO 17025 - Calibration, Measurement Gages and Test Laboratories 0 30th January 1999 01:29 AM
The time now is 10:21 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
