Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 24th February 1999, 09:28 AM
narakorn
Unregistered Guest
Posts: n/a
Please Help! Questions on use of SPC, Ppk, Cpk during PPAP
Dear Folks
I am a project manager in the automotive parts company in Thailand. Our company got ISO9000 last year and now going for QS9000.
I have learn a lot about SPC in the past cople year. However, most of the materials are only mention about theory of SPC. None of them explain how to start. This made me mad. Since, I have tried to ask the following question to our consultant but nothing clear for me. Two days ago, I found this web page and hope that someone out there can give me a light.
My question is quite simple and I would like to ask by uning the following model.
Model: Suppose that I have one new machine which operate only one process , let say drilling dia 10 +/- 0.1 mm and roughness is 6.3Rz . Our customer request us to use SPC for boths value where the requirements are
1) For PPAP, Ppk must greater than 1.67
2) For ongoing SPC Cpk must greater than 1.33
Question: 1)Why we use Ppk at the PPAP stage? (Ppk is for long term study but doe not require for stability???)
2)Do we need to use X bar R chart during our run for PPAP?
3)If yes in 2, How can we set a UCL and LCL? (If the answer is, we can have it after we finish sampling, then calculate, so what about during the sampling, how can we sure that our process is in control, and if the number of require subgroup is large, we don't to end up do it all over again after finish sampling????)
4) For one side spec (roughness in this case),if the requirement is Ppk greater than 1.67. It means that the average value will near 3.2Rz which also means that we have to design our process not for 6.3Rz but for 3.2Rz Otherwise, we will not earn those. For this case, it will cost a lot more, so can e use Pp for this.
5) When will we apply Cpk instead of Ppk (when it stable??)
6) UCL, and LCL of X bar and R chart of Cp, Cpk come from???
7) Since Cpk is a study of short term, so how can we use Cp for ongoing process??
That would be all of my questions. Sorry for a long question but really need answer.
Regards,
Narakorn Ratchapolsitte
PS: Sorry for my English, it does not be our first langauge here in Thailand
Sponsored Links
Old 24th February 1999, 11:28 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Narakorn,
Question 1: Why we use Ppk at the PPAP stage?
Ppk is the term used for the 'preliminary' process capability. You use Ppk when you are determining process capability prior to production.
Question 2: Do we need to use X bar R chart during our run for PPAP?
Need, no, but you must be sure your process is in a state of statistical control prior to accepting Ppk as a satisfactory measure of process capability.
Question 3: …how can we sure that our process is in control…
You monitor the process for a period of time (typically 30 days) and evaluate its state of control. If in control, perform your capability study. If not, take corrective action on the process and repeat (monitor the process for a period of time, etc).
Question 4: It means that the average value will near 3.2Rz which also means that we have to design our process not for 6.3Rz but for 3.2Rz.
This depends on variation. Since variation is not provided, I offer this:
USL = 6.3
Mean = 3.2, then standard deviation must be less than 0.619 to achieve Ppk of greater than 1.67. As standard deviation decreases, your mean can increase.
Question 5: When will we apply Cpk instead of Ppk?
When you have satisfied the requirements of #3 response above.
Question 6: UCL, and LCL of X bar and R chart of Cp, Cpk come from?
I am not sure of your intent of this question. Are you asking how to calculate Cp and Cpk from an Xbar-R chart?
Question 7: Since Cpk is a study of short term, so how can we use Cp for ongoing process?
Both Cp and Cpk are metrics of on-going processes.
For a more detailed discussion of process capability, you may want to see:
http://Elsmar.com/ubb/Forum10/HTML/000015.html
http://Elsmar.com/pdf_files/cpk.pdf
Hope the above helps.
Regards,
Don
Sponsored Links
Old 25th February 1999, 09:18 AM
narakorn
Unregistered Guest
Posts: n/a
Default
Dear Don
Thank you for your answer. I think that I am now getting some light. BTW, can you recommend any material that I can use for implementing SPC in my company.
Regards,
Narakorn
Old 25th February 1999, 12:08 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
Narakorn,
Glad it helped.
Hum, reading material. I have found that most reading material available usually falls into two categories. Theory oriented and application oriented. From your request, let’s try the latter:
SPC Essentials and Productivity Improvement; A Manufacturing Approach; William A. Levinson and Frank Tumbelty; ASQ Quality Press; 1997
Handbook of Statistical Methods in Manufacturing; Richard Barrett Clements; Prentice Hall; 1991
Also, Grant and Leavenworth’s Statistical Quality Control is very good, but I do not have the publisher info. Try a search at ASQ. I particularly like this one.
You may also want to try www.altavista.com and in the search box type {“statistical process control””manufacturing”} with the text in the brackets exactly as typed above. That will give about 100,000 hits. When you are here, visit as many as you can and collect as much as you can.
Go to www.amazon.com and try a search.
The Quality Council of Indiana publishes a series of primers intended mainly for preparing for the ASQ’s certification exams. While not books, they are good educational and learning tools.
I personally have many publications from private sources that are very good, but they are no longer in print and not available on the web (yet). I also have a couple of PowerPoint presentations (old) that were developed for training years ago. I do not attest to their accuracy or content, but I can forward if you like. I would need a while to remove dated information.
Well, that should keep you busy for a while. Enjoy.
Regards,
Don
Old 27th February 1999, 12:43 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
narakorn,
Forgot two:
Process Quality Control by Ott and Schilling and Sun-Tzu's The Art of War.
Definitely, Sun-Tzu.
Regards,
Don
Old 3rd March 1999, 08:26 AM
narakorn
Unregistered Guest
Posts: n/a
Default
Dear Don
I now got a Statistical Qaulity Control by Grant and .... Very interesting and this will keep me busy for a while. It really good book. Thank you, and if I have any question, you will be the one that I will contact, that's for sure.
Regards,
Narakorn R
Old 3rd March 1999, 04:29 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Default
narakorn,
Glad I could help. Have fun.
Regards,
Don
Old 5th March 1999, 09:48 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Thanks for the great help, Don!
Reply
Bookmarks
Tags
capability study, cpk, ppap, ppk, spc
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cp Cpk Pp and Ppk Definitions - I'm doing SPC and Capability Analysis Leigh Definitions, Acronyms, Abbreviations and Interpretations 7 11th June 2009 01:16 PM
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Howard Atkins SPC Monitoring and Statistical Analysis Techniques 0 20th February 2006 03:41 AM
Calculating Cpk/Ppk Simultaneously in SPC software statman78 Capability, Accuracy and Stability - Process, Machine, etc. 6 12th January 2006 01:45 PM
SPC Terminoloy & Jargon: Cpk, Ppk etc.: How did it evolve? Qualithirsty Capability, Accuracy and Stability - Process, Machine, etc. 8 19th June 2005 02:27 AM
Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? G.Hester Capability, Accuracy and Stability - Process, Machine, etc. 3 29th March 2000 10:59 AM
The time now is 07:18 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
