Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 27th March 1999, 10:46 PM
chen
Unregistered Guest
Posts: n/a
Default Using SPC charts for Verification of Job Setups
"job setups shall be verified whenever a setup is performed(e.g.initial run of a job,material changeover,job change,significant time periods lapsed between runs,etc.)" - from QS9K 4.9.4 P37
"setup verification
a recommended method is to produce enough product to constitute a subgroup of the size used for spc.the parts are measured and the results are entered on the control chart.if these results fall within the central third of the control limit zone,the setup can be approved for production.if the results fall in the outer two thirds,a second subgroup should be manufactured,measured,and plotted.if this point falls in the same outer two thirds,the setup should be adjusted and this sequence repeated.if the point falls in the central third,the setup can be approved for production."
- from QS9K GLOSSARY P132
I want to use the method to verify the job setup of our press production.
but there have some questions:
1.control limit zone: USL-LSL or UCL-LCL ?
2.results: all datas of subgroup or Xbar ?
they used "results" and "point",so i do not know the meaning of these words.
pls tell me if you have any information about job setup verification.
have a nice day. Mar.,28/1999
Sponsored Links
Old 30th March 1999, 01:25 AM
Batman
Unregistered Guest
Posts: n/a
Default
Hi Chen!
We have used almost this exact definition for several years. Where appropriate, when a job is setup, the set up person takes a normal sample for the SPC chart and plots it. If the Xbar and sigma or range is in control, the set-up person initials that plotted point and the set-up is "verified." This only applies to set-ups that have run n the past, in control.
Yes, they are talking about the UCL and LCL. Quickly, your Xbar control limits are +/- 3 sigma from the central line. Imagine dividing the area between the UCL and LCL into thirds, three zones. The middle third is the +/- one sigma zone. If your first plotted group is within this middle zone, the process is allowed to go on. If the plotted point is in the next zone towards teh UCL or LCL, the requirement is to take another sample and plot that one. If that sample is in the second zone, an adjustment is required. If the first sample plotted is in the outer zone, that is near the UCL or LCL, an immediate adjustment must be made, and start again.
The range is normally assumed to be (or remain) in control from the last run. In general (note, in general), if the range chart is out of control, this is a machine or tooling problem, one that normal 'post-setup' adjustments cannot fix.
This is of course one "recommended" method, using an SPC chart. There are certainly other methods, and they may work for you.
Sponsored Links
Old 30th March 1999, 07:41 AM
chen
Unregistered Guest
Posts: n/a
Default
Hi batman:
Thanks for your information!
I also have some questions:
1)do you use Xbar and r chart for job setups
at the same time and verify the job setups
by using all the results from Xbar&R chart?
2)this is the first time we use this method
to verify the job setups.so i use the spec
limit(usl-lsl) zone as the control limit
zone.how do you think so? if you have any
good ideas for this case pls tell me.
thanks a lot/have a nice day. Mar.,31/99
Old 18th April 1999, 03:51 PM
Batman
Unregistered Guest
Posts: n/a
Default
Hi chen!
Sorry for the delay, I did not realize you had further questions.
If you are going to use the SPC chart for job set-up verification, take the last chart used and plot the values from the samples from the set-up. This plotted point should be "in control" according to the rules stated above. If it isn't, adjustments should be made towards moving "in control" and another plot made. The SPC chart will already have upper and lower control limits set. You do not use any sort of "specification" chart here.
Also, this is for product that has been run before. New product - first run stuff - needs data collected first before establishing control limits. "Set-up verification" does not apply here. New part data has to be recorded first, then control limits calculated.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Why people not following SPC charts regularly S.Karthik Training - Internal, External and Distance Learning 10 25th August 2008 12:35 PM
Reaction to Out of Control SPC Charts beaser3 SPC Monitoring and Statistical Analysis Techniques 14 2nd November 2007 10:06 AM
SPC in job shop? CNC machine producing a max of 50 pieces per job pradeepm SPC Monitoring and Statistical Analysis Techniques 4 4th November 2005 10:52 AM
Control charts for attributes: is this possible on a non automated job? Myriam SPC Monitoring and Statistical Analysis Techniques 5 12th September 2005 08:35 AM
SPC charts - Sample Size discussion Reggie SPC Monitoring and Statistical Analysis Techniques 19 19th July 2005 01:36 PM
The time now is 03:43 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
