6th September 1999, 10:35 AM
Ppk or Cpk - Preliminary Process Capability vs. Process Performance
The 2nd edition of PPAP says we are suppose to calculate "Preliminary Process Capability" in the form of Ppk, and yet the SPC Ref. Manual says Ppk is "Process Performance" while Cpk is "Process Capability" ….so what gives?
Also by the definition of Ppk and Cpk formula, Ppk value cannot be greater than Cpk since the "sigma" in Ppk includes both common and special causes of variation. And yet the acceptance for Ppk is supposedly 1.67 but for Cpk it's 1.33.
Anyone's got an insight to this?????
1st October 1999, 11:42 PM
Elsmar Server Administrator
Registration Date: Jun 1996
Karma Power: 56 Karma: 10
First, although some time ago, I found this in a search from 1997:
David McGan
Contributor posted 03 August 1997 11:08 AM
I'm almost embarrassed to ask the question, but I've not been able to find a good, clear explanation of the real difference between the Ppk and Cpk indices. Ppk, I know, is usually specified for short-term study results, and uses the calculated standard deviation in its determination. Cpk, on the other hand, is used for long-term study results, and uses the estimated standard deviation in its calculation. But can anyone give me the statistical rationale for this?
-----------snippo-----------
I'm a generalist. Take a look at http://Elsmar.com/ubb/Forum10/HTML/000021.html and see if that helps. Also see http://Elsmar.com/ubb/Forum10/HTML/000024.html
If those don't help, come back to this thread, or post a reply in either (or both) of the threads.
Any comments, Don?
[This message has been edited by admin (edited 01 October 1999).]
3rd October 1999, 12:49 PM
dWizard
Registration Date: Nov 1998
Karma Power: 63
Hmmm. Lets see. First, thanks for ‘lighting the bulb.’ I have been busy this past few weeks and had forgotten this was posted. My apologies for the delayed response.
First, as seen in the links Marc gave I have made my feelings about this whole Ppk thing known. I feel it is just a gimmick that the AIAG group uses to muddy the water. Just MHO.
Typically, Ppk uses sample standard deviation (s) while Cpk uses an unbiased estimate if sigma (sigma hat). The reason (I suppose) is that there may be occasions where this is more applicable. This is not true. Even with small sample sizes, an unbiased estimate of sigma can still be obtained.
As far as the 2nd edition of the PPAP manual goes, I ain’t gotta clue. As I have stated before, I do not do the QS thing.
Regards,
Don
Just the ramblings of an Old Wizard Warrior.
23rd November 2004, 02:46 PM
Registration Date: Nov 2004
Karma Power: 21 Karma: 10
Ppk vs Cpk
Cpk is the 6 sigma range of a process's inherent variation where Sigma is estimated by R bar (Range Average) / D2 for the Sample Size.
Ppk is the 6 sigma range of a process's total variation where Sigma is estimated by the samples standard deviation.
Cpk is an on-ging activity. Ppk is used as a "snapshot" of the process variation at any given point in time. Ppk is useful to determine if a process will be capable (Cpk) if process conditions maintain stability. It is also useful for determining if a continious improvement activity has had an effect on the process.
Daryl
23rd November 2004, 03:19 PM
Quality Champion
Registration Date: Mar 2004
Thanks Given to Others: 7
Karma Power: 93
David McGan
Any comments, Don?
This is an interesting resurrection of some old threads.
First, it shows how much message boards have advanced since 1999.
Second, it shows that the topic of how to calculate and interpret Cpk has not advanced at all since 1999.
Third, it is humorous that Don Winton suggested reading Sun-Tsu's The Art of War to understand Cpk. I read the book imore than 10 years ago and I am positive it did not mention Cpk so Don must have been taking some literary license in referring to it. I asked for the history of Cpk in another thread but I believe we can narrow it down to happening between the death of Sun-Tsu (470 BC) and 1990 if that helps anyone remember.
Bill Pflanz
3rd January 2005, 08:49 AM
Registered Visitor
Registration Date: Nov 2003
Karma Power: 25
// From earlier threads....
Back to my problem!
When our customers want information of our process they always want a Cpk value, this value should it bee Ppk or Cpk?
The Ppk tells me how the process has been or lokked like? Or should I present the cpk value at "right" this time when we are processing our process, because this only take some of the near subgroups/samples depending how many soubgroups (50 or sometimes 25 subgroups deepending of the process) my calculations take to the Cpk calculation from the process?
Should the customer ask for Ppk value instead? Cpk value is more for us as a producer who can control the process?
Any suggestions?
Thanks!
3rd January 2005, 10:54 AM
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Any suggestions?
Thanks!
The main issue of Cpk (against ppk) is altho both use the same data (or could use it), ppk's variation estimate (total variation) is affected with the outliers a lot more than it's conterpart ( Cpk uses within variation estimate).
There are other effects that affect Cpk that most of the SPC software don't take in account (like autocorelation, a shame...). If, and only "if", the process it self is not represented by the Cpk value, you may have such kind of problem. And too much variation on indicator could be because of the sample size, many take Cpk or ppk indicators as an absolute value without the sample size concern.
Maybe not the common way to put the things, but if ppk is a good indicator.. why the control limits are using the within variation estimate?. The within variation estimate for variation show us the process variation not the data variation, it's like with "normalizing" data, you can obtain estimates that with the raw data (all) you will need much more data points.
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
3rd January 2005, 01:53 PM
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Yes, it still amazes me that people don't yet understand the Cpk/Ppk thing. It is very clear in the literature how to calculate and use each one...although as time goes by tpp many practitioners have looked for the "cliff notes" version wich too often was written by soemone who really didn't understand Cpk and Ppk...and the AIAG shortcut approach makes it worse (they aren't wrong - just not clear on why they do what they do and so there is a lot of confusion). This is further compounded by too many people usign "Cpk" when they Mean Ppk...(everytime I've probed this - >50 separate organizations - I find that hte formula teh requestor wants is the formual for Ppk, they just call it Cpk...ARRGH!
But even with the above said, Cpk and Ppk are really just psuedo statistics: trying to reduce variation to a single number. Maybe it's voodoo statistics??
back in 1992 the journal of quality technology ran a full issue of capability index articles...then editorially stated that they woudl never accept another article on capability indexes because they weren't statistically appropriate. (Although I believe tehy have given on that statement since then). Perhaps we should follow their initial lead and pass citizen based referendums to outlaw the use of these indexes???
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Calculation of Cpk and Ppk for an unstable process
morteza |
SPC Monitoring and Statistical Analysis Techniques |
7 |
29th December 2008 10:15 AM |
Difference between Ppk (Preliminary), Cpk, Performance Capability
bkarthikeyan |
2 |
2nd July 2007 07:30 AM |
Evaluating Process Stability - Unstable Processes - Cpk/Ppk?
niotusen |
Capability, Accuracy and Stability - Process, Machine, etc. |
6 |
31st January 2005 03:58 PM |
How to measure Process Capability ( Cp and Cpk)
astudent |
3 |
26th October 2004 10:48 AM |
Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ?
G.Hester |
3 |
29th March 2000 10:59 AM |
