Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th December 1999, 10:59 AM
Marcin
Unregistered Guest
Posts: n/a
Question Cmk calculation - Small plastic parts using injection-moulding machine
We manufacture small plastic parts using injection-moulding machine. There are quite big batches of production (average 50 000 parts per lot). Please advise me how we should calculate Cmk factor:
1. When it should be calculated (once a year or may be after each new connection of injection-moulding machine with the tool (mould))?
2. How many samples must be taken (I assume that 1 sample always consists of 5 parts)?
3. How frequently samples must be taken?
Thanks in advance.
Sponsored Links
Old 28th December 1999, 12:03 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Clown
I do not a lot of experience in Machine Capability studies, but I took this from http://www.autotrain.org - Link was: /auto-home/main.html
Capability - Machine Capability
A Machine Capability Study is not, strictly speaking, part of Statistical Process Control, as it does not detect the presence or absence of special causes. Instead, it provides a "snapshot" of one particular component of a process, often a machine (hence the title). This could well be of use in the context of, for example, carrying out a trial run on a machine before agreeing to buy it (like test driving a car).
A Machine Capability Study is essentially a way of establishing the capability of the component/machine by assessing how it operates:
  • over a very short period of time
  • in an ideal environment
By an ideal environment, we mean one in which:
  • the machine is set as close as possible to its optimum values
  • it is being operated by an experienced member of staff
  • it is isolated from the normal working environment (and thus unlikely to be affected by special cause variation)
  • the study takes place over a very short period of time
Typically, about 50 outputs of the process would provide data for a Machine Capability Study. This may vary depending on the outputs. For example, an hour's output of nails might be more than enough, whereas producing 50 back axles might not be practical.
Regards,
Don
Sponsored Links
Old 4th January 2000, 10:59 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
I'm not sure what a "Cmk" is, either. Does "m" stand for machine? If it does, then Don probably has the right conditions listed. However, if it is a standard process capability study, you must establish that special causes have been eliminated before you calculate the capability index. Otherwise, you get into questions of things like normality and its impact on percent of product out of spec. Perhaps could describe what you are trying to do in a little more detail.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How do I Calculate a Weight Tolerance? Plastic Injection Moulding MJ-UK Inspection and Test, Sampling and Related Topics 17 24th March 2008 07:34 PM
Machine tonnage required for plastic injection moulding process nskumar50 Manufacturing and Related Processes 4 15th June 2007 12:03 PM
Plastic Injection Moulding Set-up sheet template CarolX Documentation Control Systems, Procedures, Forms and Templates 1 24th February 2007 12:04 PM
UL 746 D - Polymeric Materials - Fabricated Parts - Plastic Injection Moulding Pat McGhie Various Other Specifications, Standards, and related Requirements 3 14th February 2007 11:49 AM
SPC from Each Cavity? Small Plastic Parts using Injection Molding Machine Marcin SPC Monitoring and Statistical Analysis Techniques 5 10th April 2000 12:16 PM
The time now is 02:39 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
