The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 5th October 2006, 11:12 AM
jeremiah jeremiah is offline
E-Mails Invalid or Rejected by Recipient System
Registration Date: Apr 2006
Karma Power: 0
jeremiah has less than 100 Karma points so far.
Question Demagnetizers - Need for calibration?
Do demagnetizers require calibration. If so, can anyone share a procedure to do this?
Sponsored Links
Old 5th October 2006, 11:23 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,778
Karma Power: 1444
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Re: Demagnetizers - Need for calibration?
In Reply to Parent Post by jeremiah View Post
If it's not used for measurement, it doesn't need to be calibrated. Do you have gauss meters for measuring whatever it is that you're demagnetizing? If so, they should be calibrated, as they provide the evidence that the demagnetizer is working properly.
We aim to please. You aim too, please.
Sponsored Links
Old 5th October 2006, 11:25 AM
ScottK's Avatar
ScottK ScottK is offline
Not out of the crisis
Thanks Given to Others: 170
Karma Power: 284
ScottK is appreciated, and has over 1700 Karma points.
ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.
what are you demagnetizing?
Measuring tools, audio/video tapes, computer media?
Time for a new sig line.
My LinkedIn Profile
Old 5th October 2006, 02:18 PM
gard2372's Avatar
gard2372 gard2372 is offline
Involved in Discussions
Thanks Given to Others: 7
Karma Power: 56
gard2372 is appreciated, and has over 500 Karma points.gard2372 is appreciated, and has over 500 Karma points.gard2372 is appreciated, and has over 500 Karma points.gard2372 is appreciated, and has over 500 Karma points.gard2372 is appreciated, and has over 500 Karma points.gard2372 is appreciated, and has over 500 Karma points.
Often when using a demagnetizer in NDT, passing a megnetized rod, bearing race, shaft etc... we put D/C current through a part to mag it, then when the inspection was done, we passed the parts through an A/C coil field to demagnetize the parts. We verified this with a gauss meter which was calibrated.
I would apply some logic to this, if you are using a demagnetizer of some sort, then the device used (gauss meter) to verify the conformance of demagnetization, then only the device used to check demag should be calibrated in this case the gauss meter.
" Remanent magnetic fields can:
affect machining by causing cuttings to cling to a component.
interfere with electronic equipment such as a compass.
create a condition known as "arc blow" in the welding process. Arc blow may cause the weld arc to wonder or filler metal to be repelled from the weld.
cause abrasive particles to cling to bearing or faying surfaces and increase wear.
Source:
http://www.ndt-ed.org/EducationResou...netization.htm
"It costs a lot to build bad products"
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Flow Meter Calibration - Outside Calibration Service vs. In-House Calibration CDISO ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 1st November 2011 08:00 PM
Required Complete calibration SOP, calibration Plan and master list template! swapan2u ISO/TS 16949 - International Automotive Quality Systems Standard 3 30th September 2011 09:35 AM
Gage pin calibration - Actual calibration readings required on the calibration cert mfr11 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 9th April 2009 12:58 PM
Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question Coleman Donnelly ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 10 29th November 2007 01:59 PM
Calibration Outsourcing vs. In House Calibration - Outrageous Costs of Calibration Cathy Everett ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 28 5th September 2006 12:50 AM
The time now is 03:50 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
