Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th October 2006, 10:48 AM
Filip M. Filip M. is offline
Registration Date: Nov 2004
Karma Power: 21
Filip M. has less than 100 Karma points so far.
Question Continuous Improvement Process Map - As an individual process?
we had an internal discussion if it's necessary to determine "continuous improvement process" as an individual process as such or to integrated in the defined COP, MOP and SOP processes.
If we take it as a process on its own, what are the input's , output's and the key indicators measurements ?
Have some of yours perhaps an example.
Thanks in advance for a quick respons.
Best regards,
Filip
Sponsored Links
Old 6th October 2006, 11:17 AM
Martijn Martijn is offline
Quality Smuality
Registration Date: Apr 2006
Thanks Given to Others: 36
Karma Power: 28
Martijn is appreciated, and has over 500 Karma points.Martijn is appreciated, and has over 500 Karma points.Martijn is appreciated, and has over 500 Karma points.Martijn is appreciated, and has over 500 Karma points.Martijn is appreciated, and has over 500 Karma points.Martijn is appreciated, and has over 500 Karma points.
Default Re: Continuous Improvement Process Map - As an individual process?
Hi Filip, not into automotive at all, but i think i understand your question. My approach would be to look at the improvement process as the entire management system and not describe it specifically. Depending on the systems structure this is more or less obvious.
I structured my management system so that input for continual improvement are complaints, audits, corrective actions, process indicators, customer satisfaction assessments, etc. This is all summarized in a management review, which can be seen as the official round up of the continual improvement loop. From there we get more corrective actions + new input for strategy / goals / targets, which is input for the operations, which again gives input in the form of complaints, audits, etc.
Hope this clarifies things a bit.
Groet, Martijn
Sponsored Links
Old 6th October 2006, 11:27 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
I think it's a good idea to adopt a simple improvement algorithm that's universally applicable:
  1. Identify something that can be improved, and define what "improved" means in each individual context.
  2. Make a plan.
    1. Make sure that you define the problem to be solved in simple, straightforward language.
    2. Make sure that it is a problem.
    3. Make sure that in solving the problem, you don't screw something else up.
    4. Define the resources that will be needed, and confirm their availability.
    5. Make a reasonable effort to define the criteria to be used in judging whether or not the problem is solved.
  3. Implement the plan.
  4. Determine whether the plan has worked or not
  5. If it has, move on to something else, but keep monitoring and be open to opportunities for further improvement. If not, go back to #2 and adjust your plan and repeat the steps.
This is nothing new; it's just the PDCA/PDSA (whichever you prefer) cycle that originated with Walter Shewhart and was refined by Deming, and has successfully withstood attempts by scores of dilettantes to repackage and present it as a wonderful new strategy. The object is not perfect processes; the object is to reach a state of optimum performance--that is, a state that is operating as well as possible given the known constraints.
Old 6th October 2006, 12:47 PM
AndyN's Avatar
AndyN AndyN is offline
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
Dag, heren!
I wouldn't advocate a 'process map' (or any other document) to meet ISO/TS 16949. What's needed is an 'approach' much as described in ISO 9004 - the guidance on Improvement. For example, if you choose to use 6 Sigma or Kaizen as your means to improve, these are more approach than process, perhaps (sure, you can process map them, of course). Since there's a need to have well qualified people doing these activities, like 6 Sigma 'Black' and 'Green' belts, there's less need for a document which describes the way they do things.
Perhaps more importantly, the way you get your management team to identify and support improvement through leadership, direction and resource allocation is of higher significance. Improvement should be identified from an effective management review of the QMS and lead to a clear plan which is supported by human resources, budget, progress monitoring etc......
Do you have these in place too?
Tot ziens!
Andy
'Cause you know sometimes words have two meanings.....
Old 6th October 2006, 01:02 PM
Peter Fraser's Avatar
Peter Fraser Peter Fraser is offline
Involved - Posts
Registration Date: Sep 2003
Thanks Given to Others: 5
Karma Power: 48
Peter Fraser has disabled his/her Karma.
Originally Posted by Filip M. View Post
Best regards,
Filip
Filip
Perhaps best to think of it as an objective which can be met by other processes (such as process design, process review, management review...)
Peter
"Insight through Clarity"
Old 6th October 2006, 01:16 PM
RCBeyette's Avatar
RCBeyette RCBeyette is offline
When in doubt - THINK!
Registration Date: Jan 2002
Thanks Given to Others: 113
Karma Power: 217
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to RCBeyette
While I'm not TS, we do have process maps and as Jim said, they are structured in the PDCA format (y-axis) along with who is involved (x-axis) for each step.
Continual improvement is factored into each process as opposed to being a process on its own. The reason for this is to us, PDCA = CI. As part of our Act, we have a learning cycle from which the outputs become the inputs to the first step back up at the Plan stage.
Basically our process maps are cycles, just as PDCA is a cycle, and CI is part of the process.
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
What other activities should be included in a Continuous Improvement process? brutas ISO 9001 - Quality Management Systems Standard 1 22nd November 2008 05:14 PM
Looking for Possible Continuous Improvement initiatives for the CI Process? Jrich ISO/TS 16949 - International Automotive Quality Systems Standard 7 25th March 2007 04:06 AM
Annex B examples of Continuous Improvement Process SteelWoman ISO 9001 - Quality Management Systems Standard 3 20th April 2005 12:35 PM
The Continual Improvement Process (vs. Continuous Improvement?) Marc Book, Video, Blog and Web Site Reviews and Recommendations 6 8th May 2004 12:06 AM
What are the Components of a Good Continuous Improvement Process Swagg Preventive Action and Continuous Improvement 6 18th April 2004 07:57 PM
The time now is 07:17 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
