Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 24th January 2000, 12:32 AM
Quirino A. Balderas
Unregistered Guest
Posts: n/a
Tool Wear Control Charts
Can someone give me some guidance on which type of control charts can we use to control a machining process in which tool wear is prominent.
We need a control chart that keeps the process in control while it also informs when an offset is required.
Using a normal X-R chart only detects the process variability and does not take into account the tool wear. Our operators have to constantly do tool offsets in order to stay in control. The machine capability is over 3 showing that the machine is very capable and that we can ride the tool wear but that takes us off the control limits.
We need something easy for our operators to follow and control the offsets without processing any out of spec parts.
Sponsored Links
Old 24th January 2000, 04:48 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
I Say...
I am not sure of the details, so I must speculate.
I would assume that the tool wear is directly related to the amount of parts produced. A simple DoE test would determine the relationship. Thus, a simple linear regression chart may be appropriate.
Use the control charts to monitor the parts, use the linear regression chart to monitor tool wear. Used correctly, the operators would know when to adjust before the tool wear caused problems with the control charts.
Regards,
Don
Sponsored Links
Old 24th January 2000, 05:48 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
I've seen the regression line as Don suggests built into the control chart. The control limits also follow the regression line slope +/- 3sigma on either side of the line. If tool wear is fairly consistent between tools, then the slope can be determined, applied to a starting point of a new tool, and control limits "drawn" from there. Kind of like confidence intervals around the regression line. A point over(or under) the control limit "early" in the life of the tool would indicate a special cause. Later in the life of the tool, the same sample mean may occur, but be within the limits... not a special cause. Hopefully this makes sense...easier with a chalk board...May have the formula's in some old notes somewhere. If someone wants me to dig them out, I'll try.
Old 24th January 2000, 07:34 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
We SHALL monitor on-going capability monthly for a customer requirement. We just started doing this and the customer hasn't seen them yet, but will soon. Almost all of our cpk's show downward trend. I think this is due to toolwear-but is only my assumption. Your thoughts? If so, could we not use these cpk's to monitor tool wear?
Old 25th January 2000, 12:22 AM
Quirino A. Balderas
Unregistered Guest
Posts: n/a
Thumbs up
Thanks Laura:
It makes a lot of sense what you replied. The tool wear is due to the number of parts machined and according to a simple DOE performed by turning 300 parts without any offsets I have a clear idea of how the measurements are affected. I will therefore construct a chart in which every so many parts there will be a different target XBar and post the control limits allowed for that target Xbar.
Thank again for your valuable input to everyone.
Q. Balderas
Old 31st January 2000, 08:03 PM
Don Winton's Avatar
dWizard
Karma Power: 63
I Say...
Dawn,
You can chart the process capability on a control chart, just as any other variable. As for the assumption regarding tool wear, it is risky to assume.
Regards,
Don
Old 18th February 2009, 01:29 PM
bobdoering's Avatar
bobdoering bobdoering is offline
Stop X-bar/R Madness
Registration Date: May 2002
Thanks Given to Others: 680
Karma Power: 150
bobdoering is appreciated, and has over 1700 Karma points.
bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to bobdoering
Default Re: Tool Wear Control Charts
This is a great explanation of the classic problem! The correct chart is the X hi/lo-R chart. For more information on preparing this chart, see: Statistical process control for precision machining
Reply
Bookmarks
Tags
control chart
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Sloping control chart to take care of tool wear - Details needed bkarthikeyan SPC Monitoring and Statistical Analysis Techniques 5 14th January 2009 04:19 PM
Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools mlthompson Manufacturing and Related Processes 5 17th May 2008 04:34 PM
To take into account the tool wear during calculating control limits Star18 SPC Monitoring and Statistical Analysis Techniques 6 6th February 2007 05:19 PM
Monitoring Tool Wear - Seeking: Suggestions on a database for Monitoring Tool Wear Dawn Manufacturing and Related Processes 3 7th July 2004 03:46 PM
Short Run SPC with Tool Wear MSAFAI SPC Monitoring and Statistical Analysis Techniques 2 6th August 2001 02:14 PM
The time now is 01:59 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
