Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th December 1999, 09:33 PM
pdboilermaker
Unregistered Guest
Posts: n/a
Question How many SPC charts for Bolt Torque? 4 identical Nut/Bolts in the same part
OK here's the question an easy question but one that we have been debating amongst ourselves for sometime now, it is your job to make hero's of some and zero's of others.
Please see the crude diagram below that represents the nuts:
0 (nut 1) 0 (nut 2)
0 (nut 3) 0 (nut 4)
1}All nuts are identical
2}All bolts are identical
3}The air tool used to put the bolts in is same
4}The person that puts in all four bolts is the same
5}The torques are all the same
6}All nuts are on the same part
The question: How many spc charts do we need for this application?
Do we need one for each nut/bolt?
Do we combine all four nuts/bolts into one subgroup?
Input greatly appreciated
[This message has been edited by pdboilermaker (edited 06 December 1999).]
Sponsored Links
Old 6th December 1999, 10:02 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Question
<FONT COLOR="BLUE"><BLOCKQUOTE>How many spc charts do we need for this application?</BLOCKQUOTE></FONT></P>
Need is a relative term. Your need would depend upon how the data is to be used and what it is to be used for. If you want the data to control the inputs for process improvement and quality improvement, apply the chart that best suits those needs. If the data are to be used just to monitor the outputs, that is another thing altogether.
<FONT COLOR="BLUE"><BLOCKQUOTE>Do we need one for each nut/bolt?</BLOCKQUOTE></FONT></P>
No.
<FONT COLOR="BLUE"><BLOCKQUOTE>Do we combine all four nuts/bolts into one subgroup?</BLOCKQUOTE></FONT></P>
You can if you are so inclined.
I realize the answers are vague, but I would need more details to address specific issues.
<FONT FACE="Veranda,Arial">Regards,
Don</FONT>
Sponsored Links
Old 8th December 1999, 12:07 PM
Brian Dowsett
Unregistered Guest
Posts: n/a
Lightbulb
Speaking from experience, I'd use a sample size of four and put up a visual aid so that 1,2,3,4 are always recorded in the same box on your control chart.
Assuming that there is not much variation due to the effect of each bolt, you can happily plot the average of the four readings to chart the output from your air gun.
If, however, there is an unusual effect from one bolt, it should be evident by looking at the data for that bolt number.
I've no idea of the pure statistical validity of this approach, but it was good enough to get us through Q1 a few years ago.
Cheers
Brian
Old 8th December 1999, 07:48 PM
Randy's Avatar
Randy Randy is offline
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Randy
Not really knowing much about what you guys are discussing I'm going to inject a little about torque that I learned as an A&P Mechanic.
Even when using a calibrated instument or tool for tightening fasteners there are variables which can effect the holding or retention abilities of those fasteners. Some of these are known as:
* Tare torque
* Dry torque
* Wet torque
* Drag torque
Also identical fasteners may be put together and have a very wide range of holding strength between them depending on machining, forging or casting variables.
An air gun may be set for a specific installation torque value, be operating correctly and still nor achieve the desired results unless other factors are identified and stipulated in the requirement.
If I'm off base let me know. But I have seen items installed on aircraft to all the proper specs and still fail because of what I said above.
Old 9th December 1999, 09:59 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
IMHO;
This process doesn't appear to be an application suited for SPC. I don't see any useful info that can be gained by recording the bolt torque in subgroups.
Now, if somewhere down the line we checked the bolts to determine if they were properly torqued, then I could see the need for charting.
Old 9th December 1999, 12:32 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Spin!
Brian Said:
<font COLOR=RED><BLOCKQUOTE>I'd use a sample size of four and put up a visual aid so that 1,2,3,4 are always recorded in the same box on your control chart.</BLOCKQUOTE></font>
That is a good idea. Thus there would be traceability to any data that are not in control to the bolt/nut in question.
<font COLOR=RED><BLOCKQUOTE>I've no idea of the pure statistical validity of this approach, but it was good enough to get us through Q1 a few years ago.</BLOCKQUOTE></font>
Strictly speaking, subgroup selection is based on your particular need. From Grant and Leavenworth:
<CITE>Generally speaking, subgroups should be selected in a way that makes each subgroup as homogeneous as possible and that gives the maximum opportunity for variation from one subgroup to another.</CITE>
I used to get all kinds of questions regarding subgroup selection, and it usually boiled down to what works for your application.
Randy Said:
<font COLOR=RED><BLOCKQUOTE>An air gun may be set for a specific installation torque value, be operating correctly and still not achieve the desired results unless other factors are identified and stipulated in the requirement.</BLOCKQUOTE></font>
True enough, thus the idea of monitoring the process to determine when it is not performing according to the quality plan. Under the assumption the key inputs are monitored, the results of the key inputs are directly correlated to key outputs and these KOV's values are known, the <font COLOR=BLUE>desired results</FONT> are predictable within a confidence interval. Thus, the requirement for the KOV should be determined as a result of analyzed and acceptable (specified) KIV's.
Sam Said:
<font COLOR=RED><BLOCKQUOTE>This process doesn't appear to be an application suited for SPC. I don't see any useful info that can be gained by recording the bolt torque in subgroups. Now, if somewhere down the line we checked the bolts to determine if they were properly torqued, then I could see the need for charting.</BLOCKQUOTE></font>
Sam,
I disagree here. The entire concept of Statistical Process Control is just that: Control the process. Control the inputs and the outputs will take care of themselves. As Deming stated:
<CITE>Putting out the fire after it has started is not quality.</CITE>
Paraphrased of course, but you see my point. Checking the torque <font COLOR=BLUE>somewhere down the line</FONT> and using a chart there is nothing more than fancy inspection with bells and whistles. Thus we have detected the fire after it has started and not prevented the fire from occurring in the first place (up the line where the bolts are actually torqued).
And this goes somewhat back to Randy's point, but with a twist. Sure the KIV's were to specification, but were they correlated to the KOV's. I suspect not, thus torque to specification up the line serves no purpose if what happens down the line is not correlated to it.
Process control is OK as a tool, but it is just a tool. How effective it is depends on how the tool is used. Just as I do not use a hammer to drive screws, I do not use SPC as inspection.
Just the ramblings of an Old Wizard Warrior.
Regards,
Don
Old 11th December 1999, 12:13 PM
Don Winton's Avatar
dWizard
Karma Power: 63
Spin!
"Putting out fires is not improvement. Finding a point out of control, finding the special cause and removing it, is only putting the process back to where it was in the first place. It is not improvement of the process. You are in a hotel. You hear someone yell fire. He runs for the fire extinguisher and pulls the alarm to call the fire department. We all get out. Extinguishing the fire does not improve the hotel. That is not improvement of quality. That is putting out fires."
W. Edwards Deming
1900-1993
Regards,
Don
Old 28th December 1999, 10:27 AM
Christian Lupo
Unregistered Guest
Posts: n/a
Maybe I missed it, but what's the verdict (summary) of this one. I have been involved in a similar situation. 4 bolts, same pattern, same operator. The bolts are not controlled, I think we got them from a hardware store, the gun is not calibrated. A minumum amount of torque seems to be needed in order to make acceptable product, although we haven't figured out what that minimum is. (It's a new process)
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Fastening Process Cmk study - Bolt Torque Larry.Jiang SPC Monitoring and Statistical Analysis Techniques 1 20th May 2009 05:19 PM
Why people not following SPC charts regularly S.Karthik Training - Internal, External and Distance Learning 10 25th August 2008 12:35 PM
Reaction to Out of Control SPC Charts beaser3 SPC Monitoring and Statistical Analysis Techniques 14 2nd November 2007 10:06 AM
Fastener bolt torque Best Practices - Assembling electronics components kdee122 Manufacturing and Related Processes 7 22nd January 2007 06:11 AM
SPC on Multiple Cavities - Customer wants SPC done on each notch - Cylindrical part jager SPC Monitoring and Statistical Analysis Techniques 16 28th October 2003 08:11 AM
The time now is 01:07 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
