Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st September 1999, 09:58 AM
Martin Rudkin
Unregistered Guest
Posts: n/a
Clown MSA and the 3rd Edition
We are a injection moulding and metal pressing company supplying 1st tier automotive suppliers - hence being pushed down QS9k.
I am at present trying to compile an MSA procedure/process. We have many parts which are 'live' within our company and to carry our MSA on all of them would not be feasible. (time/man power)
I would like to carry out Equipment Studies(micrometers, callipers, etc) but I am unsure how to include everything our auditor has been looking for - R&R, Linearity, Bias, Stability in a manner which is efficient and complies to QS9k 3rd Ed.
I have been slogging through the MSA booklet but it does not make it any clearer.
Sponsored Links
Old 2nd September 1999, 04:49 PM
TheOtherMe
Unregistered Guest
Posts: n/a
Bomb!
The MSA manual is primarily aimed at repetitive measurements of a specific dimension on a specific part. Take a look at page 37. Linearity = |Slope| x Process Variation. Take your equipment and do a few studies on a few different parts. Companre the part to part results. Now you have qualification of the instrument for measuring other parts by 'similarity'. Remember you are looking at a part to part situation and so you might want to do an R&R on one part as you need a way to address process variation. Some issues should be understood as well such as the differences you will find using the same instrument (such as micrometers or calipers) on different materials (you say you injection mold and you press metal).
What do you mean by " 'live' within our company"?
Sponsored Links
Old 3rd September 1999, 04:54 AM
Martin Rudkin
Unregistered Guest
Posts: n/a
I Say...
Thanks for your reply, it has provided me with ideas.
What I meant by live is that they are in current production.
The problem is that if I was to carry out an MSA study on each 'live' part, I would have to carry out more than 1000 MSA studies - not exactly my idea of fun!
Also, if possible could you explain in layman terms 'Process Variation' So far, within the MSA manual, I can only find it given as a figure but not how to calculate that figure.
Old 3rd September 1999, 07:55 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
Basically, the process variation is the spread of the process or, a more inexact term might be RANGE of values (for a given parameter) you expect to see from your process. For a normally-distributed process, the process variation is described by the standard deviation (sigma). This metric allows you to describe your range of values in terms of, for instance, % of values within your tolerance. If you use a control chart method to do your MSA, then calculate sigma using the R-bar/d2 method(a list of d2 values is given in chapter 2, table 2). If you are not using this method, the easiest way to calculate sigma is the button on your scientific calculator (no joke!). Otherwise, you can use a hand calculation which is located in statistics text books. This should be a last resort unless you are a purist! If your process is not normally distributed, you can use other metrics. Hopefully this description is in layman's terms!
[This message has been edited by Roger Eastin (edited 03 September 1999).]
Old 3rd September 1999, 09:31 AM
Martin Rudkin
Unregistered Guest
Posts: n/a
Question
Thanks Roger, sorry to be a pain but going back to TheOtherMe's reply about page 37 of the MSA handbook, the process variability has been calculated as 6.0 from the measurements taken.
Do you know how they have arrived at 6.0? Is it a sum the variances from each reference size/part trial?
Old 3rd September 1999, 04:07 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Bomb!
I can't say where they derived 6 as the process variation for the example. This is not my forte - maybe one of the others can help who has the MSA manual.
[This message has been edited by Marc Smith (edited 03 September 1999).]
Old 3rd September 1999, 04:16 PM
Marc's Avatar
Karma Power: 605
Covering Ass
It's not? And all this time I thought this stuff was fun! Umm, here's where you have to use some 'calibration systems sense'. You can classify types and/or brands of equipment, for example. You have 10 B&S 5" calipers? Qualify 1 and 'by similarity' extend the results to the 'brothers and sisters'. Uncertainty for the instrument is expressed in the manufacturers stated tolerance for the instrument.
Roger obviously knows this subject a lot better than I - Comments, Roger?
Old 6th September 1999, 07:54 AM
An Original Cover!
Karma Power: 54
Marc - you are certainly more of the expert on calibration "common sense" than I am. On the question of where the "6.00" came from on page 37 of the MSA manual: I think it came from the nominal value in Table 5 on page 36 of the instrument considered in the example. The graph on page 38 is helpful here too. I believe they are doing this because they are comparing the linearity of actual measurements to a "best line" line (incorporating bias calculations).
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Meeting the AIAG's MSA Manual Gage R&R Bias, Linearity, Stability requirements Frank45 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16 9th December 2008 10:44 PM
Linearity Analysis - AIAG's MSA Manual 3rd Edition - Question datony Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10 31st May 2006 11:45 AM
Laser Mike Insturment - MSA - Which (Bias, Linearity, Stability, R&R) are applicable? manpreet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 8th February 2006 04:22 PM
MSA Tools - Excel templates for doing the Linearity & Bias, & Stability Studies Courier Excel .xls Spreadsheet Templates and Tools 6 23rd October 2004 08:07 AM
4.11.4 MSA is R&R Enough? Linearity, bias, stability necessary as well? saleh.E Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 13th February 2001 08:36 PM
The time now is 08:54 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
