I want to create a boxplot picture by Minitab:
- With maximum and minimum value of a group of data to be automaticaly displayed on the range box
- Without mean and median value and line appeared on the range box.
How can do it?
- But there is not "Max", "Min" option box in the DataView window.
- I don't need the mean line either, how can I delete it.
Johnson Shao
Not sure what you are asking for here...but it sounds like you just want a single bar that goes from the min value to the maximum value. Not a boxplot.
Steven Walfish When in doubt, ask your company statistician!
right click the boxplot and select the add-->data label-->individual data-->use label from column, then the data will be display including the max and min. You may remove the particular data display by just click on the data and delete.
To display the median or mean reference line to be displayed,
choose the label when tou are creating the box plot. Select the data label and choose the median in the lable check and use eight y value lable or label from the data collection.
