Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th October 2006, 11:37 AM
Bernard Alderson Bernard Alderson is offline
QA Manager
Registration Date: Aug 2005
Karma Power: 19
Bernard Alderson has less than 100 Karma points so far.
Please Help! Measurement Uncertainty (MU) vs. Level of Certainty - ISO17025 para. 5.1.1
In section 5.1.1 of the stardard ISO17025 they ask you to factor in or rate the factors like Human, sampling, conditions. In assessing the level of certainty of measurement and results. My Questions is: Is there a format that can beused for rating the level of certainty (ie - FMEA) and if so does anyone have a system that they use and would not mind sharing it?
Sponsored Links
Old 13th October 2006, 01:02 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Default Re: Measurement Uncertainty
I would do a measurment study with those factors designed in (DOE) then use Variance Components to assess the different sources.
Steven Walfish
When in doubt, ask your company statistician!
Sponsored Links
Old 13th October 2006, 10:27 PM
Hershal's Avatar
Hershal Hershal is online now
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default Re: Measurement Uncertainty vs. Level of Certainty - ISO17025 para. 5.1.1
Couple of things.....
Measurement Uncertainty (ANS/ISO/IEC 17025 Clauses 5.1.1, 5.4.6.1, 5.4.6.2) is generally described (using Metrology methods and models) in the GUM, which is the Guide to the Expression of Uncertainty in Measurement, available as ISO GUM, or as ANSI/NCSL Z540-2-1997.....
Now.....
MU is basically divided into Type A and Type B. Type A is the statistically driven information, generally, the readings you get, that is, the measurements themselves.....
Type B on the other hand is non-statistically driven, and unfortunately has an INFINITE number of contributors. Put another way, a single system such as FMEA may not be the ultimate answer.
We may be able to provide a bit more help if you give some detail of the application you have, whether for test or calibration.
Also, the first thing you should consider is obtainng training, both in ANS/ISO/IEC 17025 and in MU (assuming you have not yet obtained training). There is a link or two in the 17025 board and the training board (posts by me and others also I believe) on such training.
Not quite the answer you sought I suspect, but more information is needed to provide a better answer.
Hope this helps.
Hershal
Old 16th October 2006, 03:51 AM
QA Manager
Karma Power: 19
Let Me Help You Re: Measurement Uncertainty vs. Level of Certainty - ISO17025 para. 5.1.1
The laboratory in question is a test laboratory, which carries out phyical testing (validation) on performance fabrics. Tests such as
- Number of ends/10cm (warp)
- number of ends/10cm (weft)
- Tensilte properties
- Tear properties
- Porosities
- Abration resistance
The factors I have isolates are:
- inturpretation of test methods
- Operator competence
- Lab contitions
- Sampling
I now need a way to evaluate the impact of those factors on the outcome of the result to ensure acceptablilty
and the reason for not seeking out training is the cost and bugetry contrains so I will have to go the difficult route.
Old 16th October 2006, 11:50 AM
Consultant
Karma Power: 43
Keep in mind the factors you want to isolate and study are hard to measure. How do you measure intepretation of a test method? Seems like training would reduce or eliminate much of the issues. You can study the effects of operator, lab conditions, and sampling if you want to look at differences in the response.
Steven Walfish
Old 16th October 2006, 01:49 PM
Ken K's Avatar
Ken K Ken K is offline
Registration Date: Jun 2000
Karma Power: 57
Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.
- Lab contitions
- Sampling
I would probably add a couple more factors:
-materials tested
-equipment used to test materials
-gages used to measure samples
-dimensions of sample pieces
But like Hershal mentioned, there can be INFINITE number of contributors. I would concentrate on those that would have the largest impact on the test results.
Old 16th October 2006, 07:39 PM
Hershal's Avatar
Metrologist-Auditor
Karma Power: 186
For a test lab, you have an advantage.....ISO/IEC 17025 only requires reporting uncertainty....
1. when the customer requests it.....
2. when there is a regulatory requirement.....
3. ifthe uncertainty can push the results potentially into the fail zone.....
But uncertainty development mens you have to look at every part of the process, quantify when/where possible, and establish what the contribution is actually doing to your measurement. THAT is where a test lab actually gets some value from an uncertainty study.....
Put another way, if you are doing the uncertainty only to satisfy some AB auditor, don't bother, take the CAR and save your effort - BUT - if you are using uncertainty analysis as a process mapping and improvement tool, you are using it properly, for a test lab.
Also, for most test methods, the final number is not a source of great concern.....whatever it is, that is what it is.
Hope this helps.
Hershal
Old 15th March 2007, 05:49 AM
amanbhai amanbhai is offline
Involved - Posts
Registration Date: Apr 2005
Thanks Given to Others: 56
Karma Power: 35
amanbhai is appreciated, and has over 100 Karma points.amanbhai is appreciated, and has over 100 Karma points.
Read This! Re: Measurement Uncertainty vs. Level of Certainty - ISO17025 para. 5.1.1
i work for the physical testing lab & have the same problem.
It is important for all of us since i don't find the person who could teach us these calcualtions.
Even tough we have calculated the MU easonably that we can justify to the assessors. I belevie.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? ScottBP Measurement Uncertainty (MU) 2 25th March 2009 11:04 AM
Measurement Uncertainty & Tolerance - Adding Uncertainty to the Tolerance Charles Wathen ISO 17025 - Calibration, Measurement Gages and Test Laboratories 12 5th June 2008 08:16 AM
Measurement Uncertainty - Measurement Uncertainty in Measurement Results Marc Definitions, Acronyms, Abbreviations and Interpretations 0 17th April 2006 08:13 AM
17025 Para. 5.6.2 - Calibration certificates - Measurement results - Uncertainty joecalibratio Measurement Uncertainty (MU) 6 18th October 2005 04:39 PM
In-tolerance Probability - Level of Confidence - Uncertainty and Proficiency Marc Measurement Uncertainty (MU) 0 20th October 1999 08:08 PM
The time now is 04:25 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
