Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Software Quality Assurance
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th October 2006, 02:36 AM
patkim patkim is offline
Registered Visitor
Registration Date: Aug 2005
Karma Power: 18
patkim has less than 100 Karma points so far.
Question How Backward Traceability is maintained in Software Development?
I just wanted to understand how backward tracability is mainatined in software development, or what are the typical guidelines for the same.
Would be great if anyone can share a sample matrix on backward traceability.
Thanks,
Sponsored Links
Old 19th October 2006, 01:45 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default Re: How Backward Tracability is mainatined in Software Development
I don't have a matrix or anything, but maybe this will help: CVS Configuration in Computing Division.
I'm not a software writer, and not many visit this site, but I hope I helped a little, and maybe one of the few who do stop by now and again can help.
Also take a look at CVS - Concurrent Versions System.
Originally Posted by CVS
Introduction to CVS
CVS is a version control system, an important component of Source Configuration Management (SCM). Using it, you can record the history of sources files, and documents. It fills a similar role to the free software RCS, PRCS, and Aegis packages.
CVS is a production quality system in wide use around the world, including many free software projects.
While CVS stores individual file history in the same format as RCS, it offers the following significant advantages over RCS:
* It can run scripts which you can supply to log CVS operations or enforce site-specific polices.
* Client/server CVS enables developers scattered by geography or slow modems to function as a single team. The version history is stored on a single central server and the client machines have a copy of all the files that the developers are working on. Therefore, the network between the client and the server must be up to perform CVS operations (such as checkins or updates) but need not be up to edit or manipulate the current versions of the files. Clients can perform all the same operations which are available locally.
* In cases where several developers or teams want to each maintain their own version of the files, because of geography and/or policy, CVS's vendor branches can import a version from another team (even if they don't use CVS), and then CVS can merge the changes from the vendor branch with the latest files if that is what is desired.
* Unreserved checkouts, allowing more than one developer to work on the same files at the same time.
* CVS provides a flexible modules database that provides a symbolic mapping of names to components of a larger software distribution. It applies names to collections of directories and files. A single command can manipulate the entire collection.
* CVS servers run on most unix variants, and clients for Windows NT/95, OS/2 and VMS are also available. CVS will also operate in what is sometimes called server mode against local repositories on Windows 95/NT.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf CVS Configuration in Computing Division.pdf (75.6 KB, 129 views)
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Design and development inputs, how many records are maintained? New Kid Design and Development - Process and Product 2 16th August 2008 10:53 PM
Electronic Components traceability - Development Laboratory al40 ISO 9001 - Quality Management Systems Standard 6 16th September 2005 08:01 AM
Integrating offshore development into our QMS? Software Development cjohnson Software Quality Assurance 1 28th July 2005 07:31 AM
Software Development Plan - Startup Software Development Company - 13485:2003 guzzi ISO 13485 - Medical Devices - Quality Management Systems 2 6th May 2004 11:48 AM
Controlling software and Data - Control of Information maintained in computers Dawn Quality Assurance and Compliance Software Tools / Solutions 4 14th December 1999 11:55 AM
The time now is 10:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
