Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 30th December 1999, 06:59 AM
Marcin
Unregistered Guest
Posts: n/a
Question SPC from Each Cavity? Small Plastic Parts using Injection Molding Machine
We manufacture small plastic parts using injection-moulding machine. Sometimes there are 2, 3 or 4 cavities in the moulding-tool, so in the same time machine injects and moulds 2, 3 or 4 parts.
The question is if we need to measure (for Ppk, Cpk and Cmk) parts from each cavity or it is enough to measure only one (always the same of course) that represents current injection process.
Sponsored Links
Old 4th January 2000, 08:52 AM
pdboilermaker
Unregistered Guest
Posts: n/a
For this application, it would make sense to collect data on each of the cavities, each cavity is slightly different from the time the tool is new. After the tool is put into use each cavity will "wear" slightly different over time. Good data samples will allow you to detect this wear gradually over time (possibly used as a predictive maintenance tool). Allows you to say "hey this tool needs to be fixed before it becomes a problem for our customer" rather than your customer saying "part "a" will not fit into part "b" anymore, it was good but now it's not, please answer this corrective action explaining why"
Sponsored Links
Old 4th January 2000, 09:12 AM
Marcin
Unregistered Guest
Posts: n/a
Question
Yes it's true that each cavity will "wear" slightly different over time. But the process will be the same for all cavities. If the process is bad for one, it is bad for others as well. Am I right? I forgot to mention that besides SPC measurements there are "Special Characteristic" measurements performed during the process for important dimensions (for each cavity). And this makes us sure that each cavity remains within required tolerance and during the life-time of the tool gradual wearing will be detected.
So now, is it necessary to measure samples from each cavity to follow the process?
Answering Marc Smith: automotive.
Old 5th January 2000, 01:44 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Yin Yang
You gave 2 important criteria:
Automotive
Special Characterics
The probable answer is - yes. I say probable as that has been my experience, but your customer is the ultimate in determining requirements.
In so far as it goes, the equal wear theory is typically correct, but not always. In addition, an individual cavity could be damaged in a number of ways.
I would communicate with your customer and ask them what their expectations. In the QS/Automotive world I would expect your customer to require data from each cavity.
Old 5th January 2000, 01:46 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Marcin,
I agree with most of what is written above. Keep in mind that while the process is the same, the results for each cavity can be quite different.
Let me give you an example. We have parts being produced for us with a multicavity tools (2,4, 16, and even one 64 cavity tool). The one that comes to mind was a 4 cavity tool. Eventually over time, we began to receive 1 bad cavity, then 2, eventually 3. Our supplier did not use process controls (nor inspection for that matter). This lead to production delays. Not a desired state.
What had happened was that thin slides/inserts within the mold began to wear and crack over time. Each failed at different rates and times. If they had been running SPC on each cavity (even a modest 2 or 3 part sample for each) they would have detected tool wear before failure of one or more slides. This could have been detected with variable or attribute data. The thing to remember that although a single machine and process are being used, each cavity represents an individual population. Combining the cavities creates a bimodal distribution, which is often difficult interpret in detecting potential/actual issues (and incorrect).
My suggestion: measure each separately.
Regards,
Kevin
Old 10th April 2000, 12:16 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Spin!
<font COLOR=RED><BLOCKQUOTE>What is Cmk?</BLOCKQUOTE></font>
This is a term used for machine capability. See:
http://Elsmar.com/ubb/Forum10/HTML/000067.html
Regards,
dWizard
[This message has been edited by Don Winton (edited 10 April 2000).]
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Benchmarks for Plastic Injection Molding - Let's Share! Helmut Jilling Benchmarking - Sharing Data 17 11th November 2009 07:07 AM
Short molding issue - Plastic injection molding from a multi cavity mold philiplim Quality Management Related Issues 13 18th February 2009 04:08 PM
What to manage after Plastic Injection Molding - Plastic Parts sadhusong Manufacturing and Related Processes 15 5th April 2008 03:21 AM
Plastic Injection Molding - Medical Devices - How to Clean Parts Please gregfish Manufacturing and Related Processes 6 6th June 2006 08:51 AM
Cmk calculation - Small plastic parts using injection-moulding machine Marcin SPC Monitoring and Statistical Analysis Techniques 2 4th January 2000 10:59 AM
The time now is 04:37 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
