Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th April 1999, 10:22 PM
chen
Unregistered Guest
Posts: n/a
Question Layout Inspection and Functional Testing
"a layout inspection and a functional verification shall be performed for all products at a frequency established by the customer." from 4.10.4.1 #40 of QS9K
Here layout inspection means we must measure all dimensions showed on design drawings
or we measure some dimensions decided by us ?
have a nice day. APR.,09/1999
Sponsored Links
Old 9th April 1999, 01:28 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
I believe it is Chrysler which mandates a yearly layout. It is now in QS9000. It is the same layout you did for PPAP, as I understand it.
Sponsored Links
Old 10th April 1999, 01:12 PM
Batman
Unregistered Guest
Posts: n/a
Default
Hi Chen!
Many of our first and second tier customers require an "annual PPAP." This is to fulfill the QS9000 requirement to their customers. There is another reason. You should be making product to the latest [agreed-to] customer revision. Since many of our customers transmit orders via a kanban type electronic system, from a blanket order, they are only asking for a part number and quantity. Rarely do these daily / weekly orders include versions, or revisions, to their drawings. So an annual PPAP assures at least a review of your documentation system and their files contain the latest drawing revision submission from us, and allows them to be able to submit PPAP to their customers.
We are not required to perform annual layouts for some of our customers if there has been a PPAP submitted for any reason in past 6 months. We have this in writing from them.
Old 17th April 1999, 04:02 PM
Marc's Avatar
Karma Power: 605
Default
Batman:
Thanks for helping out with some details. It's a 1 piece inspection of every dimension on the drawing (and each note as well) as I understand it. Am I correct?
Old 19th April 1999, 02:36 AM
Batman
Unregistered Guest
Posts: n/a
Default
Yes, each feature on the drawing - dimensions, notes, material properties, surface finish, gage, etc. Also, at least one part from each cavity, too. Some customers want 2 per cavity, fixture, etc. If you have a 16 cavity tool, 16 layout sheets are needed. We have several duplicate assembly fixtures that produce the same part - that means a layout for each.
Old 13th April 2000, 06:29 AM
kavosh
Unregistered Guest
Posts: n/a
Dear colleagues,
I read the comments on Layout inspection. I've been taught that layout inspection includes tearing down the product and measuring all and every point mentioned in the drawing/specs on every part of the product. The emphasis was on all parts of the product.
Is that correct?
Old 13th April 2000, 08:34 AM
Marc's Avatar
Karma Power: 605
Yin Yang
Is that correct?
It can be. Typically a layout inspection is where you take the print and a part (or in your case an assembly) and you measure every feature on the print. However, some customers only ask for critical characteristics be verified. In the case of an assembly, I have not personally seen a requirement that an assembly be broken down and all sub-parts measured to print - this is typically done by the suppliers of the individual parts.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Annual Requirements - TS 16949 - 8.2.4.1 Layout inspection and functional testing atlantisind Inspection and Test, Sampling and Related Topics 2 18th October 2006 11:32 AM
'Final Inspection' and 'Layout & Functional Testing' - Part of Control Plan? jhoniegudel FMEA and Control Plans 6 17th June 2006 11:04 AM
Layout inspection - When is a layout inspection required? andre-soares Inspection and Test, Sampling and Related Topics 4 15th September 2005 08:19 AM
8.2.4.1 Layout inspection - When is a full layout required and how often? Ayelet Inspection and Test, Sampling and Related Topics 8 23rd February 2005 03:50 PM
Layout inspection and functional testing Dawn Inspection and Test, Sampling and Related Topics 1 26th March 2000 01:32 AM
The time now is 09:15 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
