30th October 2006, 04:06 PM
Registration Date: Oct 2006
Karma Power: 13 Karma: 10
Good Manufacturing Practices Implementation in a Manufacturing Facility
hey, i was wondering if anyone can help me ot here???
As part of my Masters degree, I doing a project on Good Manufacturing Practice implementation on a manufacturing facility that is the ingredient supplier for a variety of products (personal care, dietary supplement, etc).
My dilemma is that I have no idea how to begin the implementation.  I have
carried out a literature review on the requirements of GMP standards and
have an understanding of how GMP will fit into the Quality System of the company. But I’m not sure where to head to next. How would you even start to compare the differences between the current SOPs and the required?
Any advice on this area would be greatly appreciated.
Dazed and very confused
30th October 2006, 04:24 PM
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 122
Karma Power: 109
Re: Good Manufacturing Practices implementation on a manufacturing facility
I suggest you do a gap analysis.
Write up an audit checklist based on the GMPs you're using.
Then go through existing procedures and check off what's covered.
What's left are the gaps that you need to fill.
31st October 2006, 03:37 AM
Re: Good Manufacturing Practices Implementation in a Manufacturing Facility
thanks Discordian.
i'm completely new to the area of quality management, as you can probably tell.
i'm in the process of trying to do that. but just having a little trouble actually doing the gap analysis. e.g. in the GMP standards, it is necessary for the building to prevent the contamination. and the company's Quality Manual states similar type of thing.
but my job here is to actually identify what should be done to eliminate contamination. and this is where i'm sort of stuck.
thanks for your comments!
31st October 2006, 03:54 AM
Registration Date: Dec 2005
Thanks Given to Others: 674
Karma Power: 176
Firstly, welcome to the Cove. Pl mention specifically what you want as GMP means a lot; right from the receipt of the raw materials and packing materials in your plant until the finished goods out of the gate and beyond.
Is your job only to list the measures to eliminate contamination ?
I have no special talents. I am only passionately curious - Albert Einstein
31st October 2006, 04:07 AM
thanks for the welcome.
no, my job is to find the relevant GMP standards on the products of the company, and implement the GMP standards on the manufacturing facility, which includes eliminating contamination. from what i understand, my project is based on the whole GMP standards, but probably not including labelling the products, etc.
hope that made some sense.
31st October 2006, 04:15 AM
Karma Power: 176
In that case, I suggest the following -
1. Make a list of all your internal procedures
2. Do a gap analysis against the GMP requirements
3. Additionally, audit the process to identify gaps
4. Revise the procedures
5. Train all applicable employees.
Looks simple, right
Best Luck
31st October 2006, 09:57 AM
Karma Power: 109
thanks Discordian.
seems what you're looking for here are two different things, if I'm reading this right...
1) you're trying to do a gap analysis
2) you're trying to come up with specific procedures.
don't do both at the same time... do the gap analysis first. As you do this you might want to create a cross reference sheet comparing GMP elements to existing Quality Manual sections and procedures.
Then start attacking individual processes like contamination prevention, which in itself can be a large topic... we can talk lot-to-lot cross contamination, cleaning and sanitizing validation, pest control, food and drink on the shop floor policy, clothing and dress code, etc.
31st October 2006, 01:16 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Welcome to the Cove!
I don't mean to discourage you, but some consultants are paid tens of thousands of dollars to do the task you seem to be set.
First, let me ask, "Is there any question whether this organization has issues with some of its products which may be a result of NOT following Good Manufacturing Practices?" If yes, those glitches should be the focus of a "root cause" investigation and dealt with first.
Second, creating a GMP-focused production process means starting at the beginning:
Work out the steps in each production cycle of each product. Are there any common processes or machines shared by more than one product? How are such processes or machines dealt with to avoid cross-contamination? Is it effective? Similar methods to prevent contamination from other substances not purposely introduced into the process are examined and tested for effectiveness. One of the best sources for cleaning and sterilization techniques meeting GMP is the individual manufacturer of a machine.
Most GMP can be simply stated as "what's best to produce a pure, uncontaminated product? How do you prove you are doing it effectively and consistently?"
Reason: typos-they seem to appear out of thin air!
