Go Back   The Elsmar Cove Forum > National and International Business Standards > RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th November 2006, 06:38 AM
ROOTS ROOTS is offline
Involved in Discussions
Registration Date: Nov 2006
Karma Power: 13
ROOTS has less than 100 Karma points so far.
Question Clarification in RoHS - The meaning of % of Lead by Weight
When I went through the ROHS Directive, I found that there are some exemptions given as stated below;
1. The maximum concentrations are 0.1% (except for Cadmium which is limited to 0.01%) by weight of homogeneous material. This means that the limits do not apply to the weight of the finished product, or even to a component, but to any single substance that could (theoretically) be separated mechanically — for example, the sheath on a cable or the tinning on a component lead.
2. Steel up to 0.35 % lead by weight*
3. Copper alloys containing up to 4.0% lead by weight
4. Aluminum containing up to* 0.4 % lead by weight
5. Lead in lead-bronze bearing shells and bushes
I could not able to understand the meaning of % of lead by weight? Whether they meant about weight of the lead from the total component or anything else? If so, how to calculate the weight of lead (Constituent) in grams in a component. Is there any formula?
Can any one help me Pl.
Regards
M.Prabhakar
Sponsored Links
Old 7th November 2006, 06:50 AM
chergh chergh is offline
On Holiday
Registration Date: May 2005
Thanks Given to Others: 6
Karma Power: 0
chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.chergh is appreciated, and has over 1300 Karma points.
Default Re: Clarification in RoHS
0.35% max lead in steel would work as follows: 1g of Steel could have a maximum 0.0035g of lead.
Calculation:
weight of material(steel) x percentage allowed / 100 = weight of allowed lead
The steel would be analysed by yourselves or a third party using ICPMS (Inductivley coupled plasma mass spectrometrey). The usual way of reporting this is in PPM (part per million). This is a simple ratio so to convert %(% is the same as parts per hundred) to PPM by multiplying by 10,000 so this would equate to 3,500 ppm. Or you could ask the persons doing the analysis to report it as % of weight
Thanks to chergh for your informative Post and/or Attachment!
Sponsored Links
Old 16th March 2007, 09:16 PM
sfkevin sfkevin is offline
Registration Date: Feb 2007
Thanks Given to Others: 14
Karma Power: 14
sfkevin has less than 100 Karma points so far.
Default Re: Clarification in RoHS - The meaning of % of Lead by Weight
That is a good visual description of by weight. As for the verification, you have to be aware of the other amendments to the RoHS requirements allowing other materials to be in excess of 1,000PPM of some elements. We count one certification s from suppliers but also test with an X-Ray Fluorescence Spectrometer (XRF) unit to confirm the parts are within RoHS requirements. I have also come in handy for verification that we are getting the correct alloy for metal fabrications.
Thanks to sfkevin for your informative Post and/or Attachment!
Old 17th March 2007, 06:40 PM
gleclair gleclair is offline
Registration Date: Dec 2006
Thanks Given to Others: 5
Karma Power: 12
gleclair has less than 100 Karma points so far.
Originally Posted by sfkevin View Post
We count one certification s from suppliers but also test with an X-Ray Fluorescence Spectrometer (XRF) unit to confirm the parts are within RoHS requirements. :
When you use the x-ray for testing can you also test for chromium VI or any other repoartables with it. If you can E-mail me with what company you used to do this. This would come in handy for me.
Glen
Old 14th March 2008, 10:20 AM
cthyau cthyau is offline
Registration Date: Jan 2008
Karma Power: 8
cthyau has less than 100 Karma points so far.
There is no formula. The lead content has to be determined by lab test. So when it says 0.35% of lead by weight in steel, it means if I were to take a piece of steel (e.g. 1kg) to the lab and perform a composition analysis, I can only find 0.35% of 1kg (i.e. 3.5g) of lead. Otherwise, that piece of steel is considered not RoHS compliance. Sometime it is possible that a lab test is not necessary. For the steel case, most steel foundry will have a "mill certificate" or "analysis report" attached to each batch of steel. You can just ask the supplier for that.
Old 14th March 2008, 11:51 AM
Karma Power: 14
Glen
Glen,
You can search the web and come up with several handheld or table top X-Ray Fluorescence Spectrometer (XRF) units. We had chosen a portable one for easy of transfer from one location to the other. As for the chromium VI, NO not the one we had. It would state if there was a high amount of chromium and we would then rely on the customer certification if it stated it passed ROHS.
“cthyau” is correct that the only true analysis in by sending it to a lab with the specialized equipment for analyses by digestion or in the case of an only metal parts ark test, this will measure the percentage of elements given off and give you a detailed reading of each element and the percentage at the given spot.
Hope that helps.
”It is easier to do a job right than to explain why you didn't.” – Martin Van Buren
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
RoHS exemption for Lead in Copper Alloys - a potential change? ScottK RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 2 18th November 2009 03:21 PM
Weighing (Weight) Scales Verification - Blank weight of material qalsang ISO 17025 - Calibration, Measurement Gages and Test Laboratories 13 5th January 2009 04:45 PM
China ROHS Clarification quality1 RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 3 23rd September 2008 12:05 PM
RoHS Lead (Pb) Weight Calculation on paper before we begin costly testing Steve McQuality RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 18 12th January 2007 03:36 PM
Weight Measurement Uncertainty - F1 10 Kg weight comparison with 10 Kg E2 weight ahmadfy2003 Measurement Uncertainty (MU) 4 5th January 2007 03:30 PM
The time now is 07:48 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
