Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th November 2006, 10:54 AM
bizonio bizonio is offline
Registration Date: Nov 2006
Karma Power: 13
bizonio has less than 100 Karma points so far.
Question Not Full (Partial) Lot at End of the Shift - Sample Size
Hi!
I'm a novice engineer QA and I have some problem to solve.
Lot size = 238 (151 - 280 range according AQL)
Ma = 0.4, Mi = 1.0
Normal sampling plans, GIL=II.
What is my sample size??? (according wich kind of defect I have to concidering it? Ma or Mi?? Because according with Ma, sample size is 32, but according Mi is 50.
What to do if 100 each will reamain at the end of shift or at the model change??? What size of the sample will be???
I hope that you help me.
Sponsored Links
Old 13th November 2006, 11:30 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default Re: Not Full Lot at End of the Shift - Sample Size
Bizonio,
I'm not sure there is an official answer for your question.
Statistically speaking, it is probably best to draw separate samples testing for majors vs minors, especially if the two are in some way correlated. From a practical perspective, it would almost certainly work well enough to use the same peices to look for both majors and minors.
If the table suggest two different sample sizes, I would draw enough for the larger sample (50 in your example). From that group, randomly test some for the major defects (32 pieces in your case) and then test all the pieces for minors. What you DON'T want to do is make the sample size the same for both while keeping the original AC & RE numbers, because that will throw off the statistics.
If you end up with an odd-sized lot at the end of a shift or production run, I would just look up in the tables the appropriate sample size for that lot.
Tim F
Sponsored Links
Old 14th November 2006, 04:09 PM
Karma Power: 13
Thank you for the quick answer!
Tim F
I also thought so but I am not sure whether I can act into this way because in the case of change of the lot size the arrows are pointing me to the same size of the sample like in case of the lot about value 238. So in this way for example for lot equal 100 I would have test 50 pieces which means so 50%. The same amount for 70 lot pieces, 60, etc. Must I act this way? Is there some method of the selection of the size sample proportionally to the lot size?
Old 14th November 2006, 04:40 PM
Karma Power: 123
bizonio,
There is no other way within Z1.4 (MIL-STD-105E) to choose sample sizes (unless you want to go to a different inspection level for the small end-of-run lots, which sounds like too much trouble). Especially when the lot sizes are small and the AQL is low, you may end up testing the entire lot.
From a statistics perspective, the size of the lot makes little difference - it is the "acceptable" level of defects and the confidence that mostly determines the sample size. Unless you want to realy go into the statistics of sampling AND then convince your boss and/or your customers that you have a valid solution with a smaller sample, it is probably best to stick with a known standard and just do 100% inspection when that is what the table says.
Tim F
Old 20th November 2006, 11:56 PM
thomastang thomastang is offline
Karma Power: 13
thomastang has less than 100 Karma points so far.
Send a message via MSN to thomastang
about material function, only need sample checking, but for apperance, if possible, need PRD liner worker take 100% sorting/inspection. it apply to start/end of one shift,or modeld change in line.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
The Relationship of Sample Size and Lot Size shixueyun Inspection and Test, Sampling and Related Topics 8 10th October 2009 11:12 AM
AQL vs. Cpk - Sample Size and Reduced Sample Size Mike Hammill Inspection and Test, Sampling and Related Topics 12 29th September 2009 05:45 AM
Sample Size for 95% CI - Lot size is 25,000 - 2% Defect Rate Process DWPOZE Inspection and Test, Sampling and Related Topics 32 17th August 2009 10:47 AM
Calculating an AQL given a sample size, accept/reject numbers, and lot size seve00 AQL - Acceptable Quality Level 2 10th April 2009 05:19 PM
Sample Size and Confidence question for Small Sample Size on Large Lots RMedrano Inspection and Test, Sampling and Related Topics 8 17th March 2008 09:01 PM
The time now is 12:42 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
