The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO/TS 16949 - International Automotive Quality Systems Standard > QS-9000 - American Automotive Manufacturers Standard
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 25th January 2000, 03:54 PM
Joe_1
Unregistered Guest
Posts: n/a
Let Me Help You Purchasing Procedure - Where to put Material Request in the Procedure
Here's a good one for all of you QS/ISO gurus. We are a job shop/machine on the "fly" shop. We also do automotive production on a smaller level. Now, with that breif background, let's get into the mess. We do have a procedure for Purchasing and so on that has been approved by a registrar. Here's the case: In the beginning, before certification, there was the P.O., the P.O. was used as sole purchasing document. Mr. P.O. was reviewed and signed prior to order, and all was well. Then, 6 months later, things began to change. Now, Mr. P.O. has another friend, Mr. Material Req. Mr. Material Req. is used by Operations Managers to "plan" or "project" what materials are needed for specific jobs. Once Mr. Material Req. is completely filled out, the Purchasing Agent can review him. Once reviewed, Mr. P.O. is then created using the data gathered from Mr. Material Req. My question to you guys is, how do I implement and where do I implement Mr. Material Req. into my procedure,err,or do I even need to??? Pardon my explination, but I'm married to a Kindergarten Teacher!!
A Confused dude,
Joe_1
Sponsored Links
Old 25th January 2000, 05:01 PM
Al
Unregistered Guest
Posts: n/a
BIG Smile
Mr. Material Req. should be covered somewhere in writing, dependent upon on the tiering of your Quality System documents. If Mr. P.O. is detailed within a Work Instruction and referenced in a Tier I or a Tier II document then I would do Mr. Material Req. likewise. At the very least the process that states how Mr. Material Req. is used needs to be in a Work Instruction.
Sponsored Links
Old 25th January 2000, 05:07 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,439
Karma Power: 400
Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.
Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.
Yin Yang
And remember that Mr. Material Req is the source (well, at least one source) specifying requirements. So - contrast what is on the material req with what's on the PO.
Old 26th January 2000, 09:25 AM
Tom Goetzinger Tom Goetzinger is offline
An Early Cover
Registration Date: Mar 1999
Karma Power: 0
Tom Goetzinger has less than 100 Karma points so far.
As Marc indicated, the Material Req is one source for transmission of requirements to the Purchasing Department. Unless you want to create a work instruction for every method of requirement transmission, I would suggest wording your PO procedure to allow input from appropriate sources and let it go at that.
Be careful that you don't create such a burdensome system that it is not beneficial to your company and becomes a burden to maintain.
[This message has been edited by Tom Goetzinger (edited 26 January 2000).]
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Lot Acceptance Procedure - Material Acceptance Procedure for the supply department Sarpedon Supplier Quality Assurance and other Supplier Issues 3 11th July 2009 03:41 AM
CFO trying to turn Quality procedure for Purchasing into a purchasing manual al40 ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 15 23rd April 2008 03:18 PM
Purchasing Procedure - Purchasing process is not complete until product is received? S.Frieda ISO/TS 16949 - International Automotive Quality Systems Standard 11 25th July 2007 02:33 PM
Procedure Signatures - Who needs to put authorization signature on procedures? Bryan Documentation Control Systems, Procedures, Forms and Templates 13 11th July 2006 09:38 AM
Purchasing Procedure Example Needed Vash Stampede Documentation Control Systems, Procedures, Forms and Templates 9 21st June 2005 09:52 AM
The time now is 10:17 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
