Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 2nd October 2000, 01:26 AM
Josh Smith
Unregistered Guest
Posts: n/a
Question Reactions to out of control X bar and R charts?
I am curious as to how other organizations have written their procedures for reacting to out of control points up or below the control limits, 7 consecutive points running above or below the centerline, and 7 points trending up or down?
Our reaction plan on the control plan states that when the process has violated these rules. Supervisor will be notified by quality auditor, suspect product will be isolated and verified by other means (i.e 100% inspect), the process will be adjusted to bring back into a state of control, and process changes will be noted on the process change log sheet.
Does this sound reasonable? Or is it painting us into a corner for QS-9000?
Looking for input?
Sponsored Links
Old 4th October 2000, 04:03 PM
auditor16949
Unregistered Guest
Posts: n/a
The procedure is basically OK. The QS-9000 auditor may ask if you have identified and eliminated the special cause of variation acting on the process.
Sponsored Links
Old 17th October 2000, 12:08 PM
Indywine
Unregistered Guest
Posts: n/a
Keep in mind that 7 points in a row usually reflects a change in the process. However, it could be associated with a learning curve after training. I wouldn't suggest blindly changing the process without trying to understand why there is a new trend.
Jim
Old 17th October 2000, 02:45 PM
lyman
Unregistered Guest
Posts: n/a
BIG Smile
Our procedures which were written by engineering and approved through manufacturing centered the responsibility for initial monitoring of SPC and any related trends with the floor operators. We tied our SPC as much as possible with our computerized manufacturing system so that if the chart showed an OOC point the equipment automatically was no longer available to production until such time that someone from Engineering reviewed the situation and released it. The procedures for trends directed operators to OCAPs which either dictated that a change to equipment settings be made (if appropriate)with the requisite documentation, or that the process be shut down and Engineering and Manufacturing Management be notified. The biggest challenge we faced with this allocation of responsibility was making sure that there was enough information in our computerized record so that Engineering could evaluate the situation to begin effective corrective or preventive action. The second biggest challenge - getting Engineering to document what they did!
Old 25th October 2000, 01:12 AM
Brian Dowsett
Unregistered Guest
Posts: n/a
I think you also could make some reference to process capability.
For instance if you have a very good Cpk value, seven points in one direction definitely merits some attention but may not merit 100% inspection.
In a previous job, our reaction plan was in the form of a flow chart, with some decision boxes based on proven process capability.
regards
Brian
Old 4th June 2008, 08:19 PM
ABS ABS is offline
Involved in Discussions
Registration Date: May 2008
Thanks Given to Others: 1
Karma Power: 7
ABS has less than 100 Karma points so far.
Default Re: Reactions to out of control X bar and R charts?
"We tied our SPC as much as possible with our computerized manufacturing system so that if the chart showed an OOC point the equipment automatically was no longer available to production until such time that someone from Engineering reviewed the situation and released it."
I am looking for ways to connect SPC to the manufacturing system. Looking after your reply, I was wondering if you could elaborate more on how to accomplish this system.
Abhinav.
Old 4th June 2008, 10:35 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Hmmm.....quality auditor, supervisor, engineering
Everyone involved but the operator? SPC was supposed to be a tool for the machine operator to control her process. Are they out of the loop?
Can't they just make adjustments and carry on? Assuming a decent capability, a trend may not be bad product but just a signal to perhaps change worn tooling.
The more the operator knows about SPC, the better.
At least thats the theory. We don't do any better here, but I hope some people get to run SPC right.
Old 5th June 2008, 03:02 PM
Bev D's Avatar
Bev D Bev D is online now
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
agree with Caster on the capability part. you state that "suspect product will be isolated and verified by other means (i.e 100% inspect)". I hope that you mean only product suspected of being out of tolerance?
As Caster points out a capable process can go out of control and all of the parts can be perfectly in tolerance nd acceptable.
The other comments regarding operator involvement are also pertinant. Keeping in mind that are processes that the operator cannot troubleshoot. I've worked with both and sometimes you just dont' want the operator touching anything...
Reply
Bookmarks
Tags
out of control, reaction, spc
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Designing Control Charts - Variable with Small Variation and Tight Control Limit CJLee SPC Monitoring and Statistical Analysis Techniques 17 5th July 2008 02:03 AM
How to interpret s and x bar control charts 0Elizabeth0 SPC Monitoring and Statistical Analysis Techniques 5 18th January 2007 02:19 PM
Short run Z-bar & W charts - Can anyone tell me the formula used? keatwoon SPC Monitoring and Statistical Analysis Techniques 9 19th February 2005 04:03 AM
High Cpk's and Control Charts - Is it justified to stop using control charts? MSAFAI Capability, Accuracy and Stability - Process, Machine, etc. 7 11th August 2001 02:23 PM
Control limit - How is table for x-bar & R control chart derived? Kleeve SPC Monitoring and Statistical Analysis Techniques 7 24th July 2001 02:14 PM
The time now is 02:57 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
