Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th August 2000, 03:42 PM
Montserrat P Montserrat P is offline
Registration Date: Aug 2000
Karma Power: 38
Montserrat P has less than 100 Karma points so far.
Question Skip Lot Sampling - How to Perform Skip-Lot and Chain Sampling
Hello:
I would like to know if somebody have experience related with the use of the Skip Lot Sampling Technical. Our company want to implant this technical in our process.
I will appreciate a lot all kind of information related with it.
Sponsored Links
Old 15th August 2000, 04:06 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
I have used skip lot sampling in the past, but it was so long ago, my tiny little mind does not recall how we did it.
Might I suggest using MIL-STD-105, and work into a reduced sampling plan?
Sponsored Links
Old 15th August 2000, 04:26 PM
robertocarvajal
Unregistered Guest
Posts: n/a
Question
Hello:
I need to use Skip Lot Sampling also for a new project....If somebody fromj you have experience from it, please let Montserrat know....
[This message has been edited by Marc Smith (edited 15 August 2000).]
Old 15th August 2000, 07:26 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,896
Karma Power: 605
Yin Yang
Skip Lot is really Dock-to-Stock. In Dock-to-Stock, sooner or later your system should require a random or structured check.
A typical skip lot would be:
Inspect 3 lots. If OK, Dock-to-Stock for 5 shipments. Check the 6th shipment. If OK, Dock-to-Stock for 5 more shipments.
Continue as long as no nonconformances are identified.
If at any time time a nonconformance is identified, the inspection frequency is tightened - you define what 'tightened' is - such as inspect 3 shipments before returning to skip lot. Some systems are also set up to increase sample size when a nonconformance is identified.
Old 24th October 2000, 07:24 PM
Drew H
Unregistered Guest
Posts: n/a
Question
Has anyone used AQL and skip lot systems to satisfy the Incoming Inspection requirements for QS-9000? We are considering using this as an interim measure for suppliers who are not yet certified, but our auditor is making grumpy noises.
Old 24th October 2000, 08:22 PM
Karma Power: 38
BIG Smile
We are in the process to study the Skip Lot in one of our process, however, we have not thought about to implant it in the incoming inspection. Is the history of quality level of your suppliers so excellent to make the skip lot?
May I ask you, where did you find that information Sksp? I will appreciate to count on with more literature about it.
Old 24th October 2000, 08:55 PM
Drew H
Unregistered Guest
Posts: n/a
Money
You should check out American Society for Quality - Statistics Division - Volume 4 "How to Perform Skip-Lot and Chain Sampling" by Kenneth Stephens.
The incoming quality varies - some suppliers are very good and skip lot will work; others will require constant incoming inspection. Question is, if the supplier has been shown to have adequate quality levels based on past history, but is not yet certified - will we be OK for our QS audit or is skip lot simply not allowed for QS incoming inspection? Hopefully our suppliers will be certified soon, but in the interim we need to do something and the cost of inspecting every shipment isn't justified for our good suppliers that are not yet certified.
Old 3rd November 2000, 02:00 PM
BenR
Unregistered Guest
Posts: n/a
You might check out Juran's Quality Control Handbook; he has a couple of pages on skip-lot schemes as does Montgomery in "Introduction to Statistical Quality Control." Also, you might search the web; seems like I found some good (and free) information of sampling a year or so back.
Good luck.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Skip Lot for product or for Supplier ? PaulSanda Inspection and Test, Sampling and Related Topics 4 17th March 2009 09:45 AM
ANSI/ASQ Z1.4-2003 Sampling with Skip Lot jjcgia Inspection and Test, Sampling and Related Topics 2 25th August 2007 12:38 PM
ISO 2859-3 - Skip-lot sampling procedures - Unauthorized Inspection Frequency tahirawan11 Inspection and Test, Sampling and Related Topics 3 24th January 2007 12:27 PM
Sampling - Skip Lot - 20 ppm - What is your opinion of Skip Lot sampling? chrisoleary Inspection and Test, Sampling and Related Topics 6 28th February 2006 11:51 AM
Skip Lot Inspection - What do we look at and when? Andrews Inspection and Test, Sampling and Related Topics 3 29th October 2002 02:23 AM
The time now is 04:55 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
