Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
23rd November 2006, 05:34 AM
Registration Date: Nov 2006
Karma Power: 27 Karma: 10
USP Class VI vs. ISO 10993 - What are the differences?
Could any body clarify me the exact difference  between USP class VI versus ISO 10993, Please.
23rd November 2006, 06:54 AM
Addicted to standards
Registration Date: Mar 2006
Thanks Given to Others: 286
Karma Power: 248
Re: USP class VI versus ISO 10993
I do not know USP class VI, and know just the necessary of ISO 10993, but reading a little on the net about USP class VI it seems it´s comprised of two specific tests (systemic injection and intracutaneous) made on animals. Well, ISO 10993 is a series of standards which describes a lot of tests (there´s 19 standards in the series and the fisrt is the general one, so it seems to exist at least some 18 different tests, i am not sure of this). The tests to be made depends on some characteristics of the product being tested, for exemple contact time. Also, there´s some tests done on animals, if i remember corrrectly, but most of them are not. Well, that´s what i can think of in a hurry. Cheers.
Thanks to Marcelo Antunes for your informative Post and/or Attachment!
23rd November 2006, 09:58 AM
Forum Administrator
Registration Date: Dec 2005
Thanks Given to Others: 1,470
Karma Power: 400
In Reply to Parent Post by ryosaeba
Hi, use the search function available at the top or at bottom of the thread and you will come across many threads. One of the most informative for this subject is Biocompatibility - USP Class VI vs. ISO 10933
Well done is better than well said - Benjamin Franklin
Thanks to Ajit Basrur for your informative Post and/or Attachment!
23rd November 2006, 12:22 PM
 . That cleared me a bit.
23rd November 2006, 08:45 PM
Forum Administrator
Karma Power: 400
So do you still have some queries
1st May 2009, 04:11 PM
Getting Involved (6 to 9 Posts)
Registration Date: Feb 2009
Thanks Given to Others: 3
Karma Power: 18 Karma: 10
If a material is found to be USP class 6 compliant and meets the standards of 10993-1, must a med device company repeat those tests, or may they thoroughly document the material is deemed safe?
1st May 2009, 07:28 PM
Appreciated Information Resource
Registration Date: Aug 2008
Thanks Given to Others: 1,035
Karma Power: 350
USP class qualification was a key method for establishing material biocompatibility at least as far back as 1976, until the 1987 adoption of the Tripartitite Agreement.
Tripartite introduced the first expectations of biocompatibility testing specifically focused on device-related material biocompatibility environments, such as implantation and fluid communication. The relevant guidance memo was G87-1. This is still available on the FDA website.
Under Tripartite, USP class qualification was sometimes accepted as sufficient for lower-risk applications. Tripartite was the FDA biocompatibility approach until 1995.
In 1995, the FDA adopted ISO 10993 as its biocompatibility approach. This is their current stance today. The guidance memo was/is G95-1. USP class qualification no longer plays any role in medical device materials evaluation.
Up-to-date materials manufacturers provide both USP and ISO 10993 test data, to support both pharma and device customers.
See G95-1 for a summary table of the ISO 10993 qualifications required for a given degree of patient contact. A minimum of three qualifications (i.e. test types) is needed for even limited-term unbroken-skin contact.
It is not necessary to repeat material-manufacturer-conducted testing, assuming that the material in fact is identical, the testing is relevant, the documentation is complete and properly prepared, and the testing was done to GLP standards by a registered lab.
Thanks to MIREGMGR for your informative Post and/or Attachment!
5th August 2009, 02:14 PM
Involved in Discussions
Registration Date: Mar 2009
Thanks Given to Others: 5
Karma Power: 19 Karma: 15
Is there any centralized respository for material testing results? How would one obtain access to already tested materials?
Like Stainless Steel or TIN Coating.
Forum Posting Settings
