Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th November 2000, 06:24 PM
Ray Culver
Unregistered Guest
Posts: n/a
Weighting Factor for Excel
Does anyone know if Excel has a formula that calculates a given cell but gives a value back as a "weighted value" compared to the total of all cells in multiple subsets?
Signed: NotsoMathboy.
Sponsored Links
Old 30th November 2000, 10:16 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Is the Weighted Factor fixed or variable?
Kevin
Sponsored Links
Old 30th November 2000, 11:59 AM
Ray Culver
Unregistered Guest
Posts: n/a
Kevin, this would be variable.
I'm thinking that if I find the "average" percent to total for each subgroup, then I either increase or decrease each subgroup an appropriate % to reach the average...I'm I on the right track?
Old 30th November 2000, 02:09 PM
Karma Power: 94
I was trying to remember back some time ago, in Excel 4.0 they had a Problem Solver and a Scenario Manager which worked with Variable data. I was thinking that if your subgroup data was placed into either engine, you might get what you are looking for. Sadly, I have forgotten 5% of the 10% of Excel I use to know.
Perhaps someone out there with good (and recent) knowledge of Excel could help out?
I am not sure why you would want to get a weighted value for subgroup data. Are you trying to make an estimation from the data?
Kevin
Old 30th November 2000, 02:34 PM
Ray Culver
Unregistered Guest
Posts: n/a
Not it's not an estimation of data.
I'm compiling results from a staff survey. Each of the subgroups are the "general causes" i.e. material, methods, measurements, equipment, environment, and people (cause and effect). From those general subgroups the results are then further catagorized by department. For example, a subgroup is People/Customer Service, then People/Warehouse, then equipment/warehouse, etc.
The method of grading importance was from a practice called Nominal Prioritization where the team of supervisors and senior managers each gave a grade (or priority) beside each response question per subgroup. The grade logic, applied to each response, from the survey was, the higher the number assigned to a response the more priority is was to that manager. The problem with this grading is that each subgroup had a different # of responses from the survey...therefore one subgroup had 3 responses where the highest grading for a response would be 3 and another subgroup has 14 with the highest grading per response to be 14. Since the highest priority grading in one could go as high as 14 and the other could only go to 3, I want to "weight" the subgroup with only 3 so that it had the same ranking to the total of all subgroups as the one with 14 so that I can sort all responses by the "weighted" priority # to the total of all responses.
If this sounds like a nightmare to explain I could email you the excel file for a quick peek if you want.....
Old 30th November 2000, 06:39 PM
Karma Power: 94
Send it, but I think I understand your problem.
Off to the homestead, so I'll catch you in the a.m.
Kevin
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
TV Viewing Distance Factor Marc Audio - Visual - Home Theater 7 11th August 2009 07:56 AM
Whats the difference in applying error factor and correction factor? ggdjr ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 29th July 2008 08:14 PM
Supplier Rating System - Weighting low volume suppliers vs. high volume suppliers fcardillo Supplier Quality Assurance and other Supplier Issues 2 2nd May 2008 08:05 AM
One Factor - Determining if Temperature is a contributing factor RMedrano Six Sigma 9 2nd April 2007 01:58 PM
Need excel formating help - Have excel automatically populate a column mike101338 Excel .xls Spreadsheet Templates and Tools 19 7th September 2005 04:30 PM
The time now is 05:22 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
