10th September 1998, 05:10 PM
Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive
HOW DO YOU PERFORM A COMPLETE MSA WHEN YOUR TEST METHOD IS A DESTRUCTIVE TEST??
10th September 1998, 08:10 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Well, for complete MSA info we would need more data.
There's 1 'general' method akin to an R&R in intention (consideration of repeatability and reproducability) described near the end of the MSA presentation (if I remember correctly) in the pdf_files directory here.
Anyone want to go into details?
14th September 1998, 10:35 AM
The test I am referring to is bond pull, both destructive and non destructive. We use ultrasonic bonders with aluminum wire and periodically we do a non destructive pull test and then on separate units, a destructive bond pull. I do not know how to measure repeatability or linearity in these two cases.
15th September 1998, 08:04 AM
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63 Karma: 151
Use a test coupon, its the only way you can do it as a continuous process, short of dedicated bonders for product. Have been doing this for years for mil standard defense/space programs, as well as AS/QS and has been acceptable. I hear the frustration..been there, done that. that process does NOT fit the mold for SPC stuff at all.
25th January 2000, 03:52 AM
How can I do in case I cannot find/use dummy coupon? Is it possible to use within Lot material to explain Repeatability and between Lot to explain Reproducibility?
What about your idea? Thanks for your idea.
25th January 2000, 08:27 AM
Destructive measurement system analysis can be accomplished via SPC. You should referene "Evaluating the Measurement Process When Testing is Destructive" by Donald J. Wheeler and "EMP-Evaluating the Measurement Process", by Donald J. Wheeler and Richard W. Lyday. Both publications can be obtained from SPC Press, Inc. 615-584-5005
25th January 2000, 09:49 AM
Registration Date: Mar 1999
Karma Power: 45 Karma: 10
The best method I found for MSA on destructive testing is through using the ISOPlot method developed by Dr. Dorian Shainin (see www.shainin.com for information).
Basically, I would take 2 consecutive samples as a group and collect a total of 30 groups. Next I would use sample 1 of each group as Trial 1 and sample 2 of each group as Trial 2. Then I would plot Trial 1 versus Trial 2 and determine the discremination ratio. It is very similar to correlation, but the method of calculating discrimination ratio is the key to qualify the measurement system. There is a software to do this from Shainin (www.shainin.com/RedXTracker/).
Check it out!
27th January 2000, 12:43 AM
Involved - Posts
Registration Date: Sep 1999
Karma Power: 43 Karma: 10
MSA reference manual give some examples of approaches to MSA including single specimen. Let's see in Appendix D pp.107 and let's comment on that.
