Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th November 2000, 06:11 AM
VojkoKrizman
Unregistered Guest
Posts: n/a
Question Debalancing machine - is SPC needed?
Debalancing machine is consisted from two parts:1 measurement instrument and debalancing part. ALL parts (rotors for DC motors) are measured (100% inspection). If balance is more than prespecified target (eg. > 40 gmm) then parts go through balancing operation that lowers the debalance below target (measured again). Parts, that go to the next operation, than comes from two distributions (supposed nonnormal):1. good parts from initial measurement and 2. balanced parts. How to measure the Ppk (I understand that Cpk can not be computed). Is it necessary to compute Ppk, since it seems all parts are good but parts from the first distribution can be near the target (but below!)
Vojko Krizman
SLOVENIA
Sponsored Links
Old 17th November 2000, 05:51 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
My initial thoughts are you have 2 separate calculations to do, because you essentially have 2 different populations. You would want to know how capable the rework process is.
Also wanted to mention that my Great grandparents were born in Slovenia!
Laura
Sponsored Links
Old 20th November 2000, 05:32 AM
VojkoKrizman
Unregistered Guest
Posts: n/a
Debalancing operation cannot be omitted.The result of this operation are parts that come from two distributions and we have 100% inspection. My main question is: If we have 100% inspection and all parts are good, do we have to compute Ppk, especially if all parts are good (but from distribution it comes out we have some fraction of nonconform parts!?)
Old 22nd November 2000, 10:51 AM
Laura M's Avatar
Courtesy Access
Karma Power: 70
100% inspection is often the alternative if you do not meet process capability requirements. If you have a bimodal distribution due to 2 processes rolled in to one data set, then it is possible that each process is separatly capable, but when you combine them the standard deviation increases and the capabiiity index would indicate parts out of spec. Without knowing more about the prcocess, that's probably as much as I should say so I don't mislead you.
Old 22nd November 2000, 11:58 AM
Rick Goodson's Avatar
Rick Goodson Rick Goodson is offline
Registration Date: Aug 2000
Karma Power: 42
Rick Goodson has less than 100 Karma points so far.
I agree with the advise Laura has given but wanted to add a thought. If the two separate processes are capable, why combine them and then and force yourself into a 100% inspection operation that may not be necessary? If you run both populations across the same secondary operation you could consider a 'short run' SPC technique such as a 'Nominal' or a 'Target' chart. Once again, as Laura stated, I would need to know more about the process before we could definitively say short run is the best option. If you want to investigate short run further try the International Quality Institute, http://www.i-q-i.com/index.htm or Dr Don Wheeler's website http://www.spcpress.com/
Old 10th January 2001, 10:49 AM
Mark M
Unregistered Guest
Posts: n/a
The Hat
Adding to the Balancing Process Characterization Issue ...
How are you going about calculating the process capability for a polar oriented process (imbalance amount and angle) when the usual capability calculation assume a linear measurement? Of course, the polar coordinates can be converted, but you still have two dimensions instead of one.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Is SPC a requirement of AS9100? Small Machine Shop and Assembly Cindrakay AS9100 Aerospace Standard and Requirements 8 19th September 2009 08:25 PM
What type of SQC or SPC Techniques can be implemented in Machine Shops viren SPC Monitoring and Statistical Analysis Techniques 8 17th April 2009 07:58 AM
Old machine (Mitutoyo Qualimate DL-500) for SPC - Is it Worth the effort? qualitymoron Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 30th January 2008 01:30 PM
Machine Capability Studies: How many parts needed? Dawn SPC Monitoring and Statistical Analysis Techniques 11 21st March 2001 02:17 PM
SPC from Each Cavity? Small Plastic Parts using Injection Molding Machine Marcin SPC Monitoring and Statistical Analysis Techniques 5 10th April 2000 12:16 PM
The time now is 01:10 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
