Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th January 2001, 02:10 PM
rivet guy
Unregistered Guest
Posts: n/a
Please Help! VisualSPC: Anyone else using this software? Resistance from experienced operators
Hi All:
Anyone using this software in a pretty high piece rate mfg environment?
Screw machines, cold headers 20k to 40k pcs a day.
Seems cumbersome, not specifically this product but how do we do SPC without cutting into production?
There is resistance, since experienced operators know almost by intuition if tolerances are drifting, they don't need SPC to tell them the obvious.
How do you answer such very legitimate questions?
I mean paper charting seems like it would be faster.
Sponsored Links
Old 17th January 2001, 02:30 PM
SteelMaiden's Avatar
SteelMaiden SteelMaiden is offline
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
Been there in a previous life. We got a lot of grumbling at the beginning of the project, but once operators gained proficiency they told us it was easier to input values than to chart by hand. It will definitely save you time in calculating capabilities, re-calculating control limits, etc. There are remote sending/receiving units out there to capture your readings and eliminate some of the manual data entry.
Going to a computer system from paper will seem like a disaster for awhile until you reach the top of the learning curve. Good luck on your project, you'll be glad you did it.
Sponsored Links
Old 17th January 2001, 02:33 PM
Jim Biz's Avatar
Jim Biz Jim Biz is offline
Registration Date: Mar 2000
Karma Power: 51
Jim Biz is appreciated, and has over 100 Karma points.Jim Biz is appreciated, and has over 100 Karma points.
I Say...
Hmmmmm --- need more information to give you a "good answer"
Whats the current sample size?
How much of a "Cut into production are you seeing"?
> can't say I've heard anyone that would agree with the statement SPC by Intuition is an acceptable method....
it may be useful to your operation - maybe not - smallest realistic sample sizes could help but I'd explain to the operators that you need some data to prove that it isn't needed by using it for a short term anyway
Regards
Jim
Old 17th January 2001, 06:54 PM
Al Dyer
Unregistered Guest
Posts: n/a
We are testing a package from CimWorks that looks promising. It is flexible enough that we can network it to multiple operations and processes.
Defining which software works for our application has been a long road. We feel that the investigation process has also been a good learning process, as the operators that will use the system are part of the group evaluating the product.
I'll keep you posted as we continue...
ASD...
Old 18th January 2001, 11:30 AM
rivet guy
Unregistered Guest
Posts: n/a
"Good luck on your project, you'll be glad you did it."
Thank you and I truly hope so.
Our SPC is a "flowed down requirement" and its not really clear that quality has improved since going to SPC. The parts function as they always have only now we have the new SPC requirements.
We could get a whole lot more "buy in" if we could get some easily observable quality, cost, or thru-put improvements with the new SPC.
Thank you
Old 18th January 2001, 11:53 AM
rivet guy
Unregistered Guest
Posts: n/a
"Whats the current sample size?"
Our sample size is pretty modest, our people check and verify dimensions probably 2 or 3 times more frequently.
Its just the "overhead" of getting one's hands ready for computer work, fishing the right chart for the machine out of the computer, when one has been on a screw machine or header. Also we share computers, so people tend to "customize" the setting for themselves.
I'm trying to get our people their own computers, this maybe doable since computers are getting so cheap.
Significant enough that operations is aware, if you know what I mean.
"that you need some data to prove that it isn't needed by using it for a short term anyway"
I like this approach, maybe I can minimize it altogether :^o
BTW, many of our people still remember very fondly old DOS based SPC software since 1) the font was huge, small font and oil smudges on monitors are a real nusance. 2) DOS based apps were much more simple, no Windows overhead, and actually was faster.
Old 18th January 2001, 12:01 PM
Geoff Cotton's Avatar
Geoff Cotton Geoff Cotton is offline
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 42
Geoff Cotton has less than 100 Karma points so far.
Quid Pro Quo
"Experienced operators know almost by intuition if tolerances are drifting".... that sounds like they are over controlling the process. SPC will find that out for you, and lets not forget over controlling cost money and downtime.
We used to have operators that kept away from SPC, but now several years later, they REFUSE TO RUN without SPC charts.
Geoff
(Tried computerized SPC and found it too easy to fiddle the data. Our guys prefer paper charts as they use them to make notes on about how the process has run etc. The notes are really usefull when you have to try to remeber what happened months ago)
Old 29th January 2001, 05:52 AM
John L Morris
Unregistered Guest
Posts: n/a
We are also thinking about using Visual SPC for a high speed manufacturing environment. We are currently using an old DOS based system and I would welcome any thoughts from anyone who has experience of using the Visual SPC system. (ie benefits, problems etc) My impression is that it is not easy to set up in the first place, but once it is set up the operators find it easier to work with.
Reply
Bookmarks
Tags
high speed manufacturing, screw machines, spc, statistical process control
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Competency - How I can show experienced operators are competent? vikinguk Documentation Control Systems, Procedures, Forms and Templates 3 14th July 2009 08:23 AM
MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R DJN Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10 7th March 2006 09:02 PM
In need of Training for VisualSPC ShopFloor v4.5 by CimWorks RoboElvis Training - Internal, External and Distance Learning 1 31st August 2005 11:16 AM
The time now is 12:46 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
