Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
7th December 2006, 01:04 PM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Aug 2002
Karma Power: 0 Karma: 10
Audit Finding for this section - Min and Max for measurements - Attribute Gage
Time to sing the blues
I just went through my surveillance audit and 1 finding was I was not putting down the Min and Max for measurements , HOWEVER .I am using Attribute gaging (pin gages) for the dimensions, the auditor was not seeing it that way and would not remove the finding , am I out of line to maybe go over his head in trying to get this finding removed. its only a minor but ..its a finding none the less.
Jim
7th December 2006, 01:23 PM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,804
Karma Power: 1451
Re: Audit Finding for this section
In Reply to Parent Post by jethehiker
Jim
Please post the audit finding exactly as the auditor wrote it, including reference to the "shall" in the standard or your internal documentation that was allegedly violated.
Everyone has a plan until they get punched in the face (Mike Tyson)
7th December 2006, 02:26 PM
AS9100B 8.2.4 Evidence of Comformity with the acceptance criteria shall be maintained.
Finding
For 3 of 4 jobs sampled (37956R2, 41393,45562) either the Min or Max actual data was not recorded as required on final inspection documentation.
I use a electronic data base with colums and last yr at my audit he wrote me up because I didn't have a Min and Max colum ..
 I just can't win
7th December 2006, 02:43 PM
When in doubt - THINK!
Registration Date: Jan 2002
Thanks Given to Others: 408
Karma Power: 332
If your own documentation requires it and it's not being completed, then yes, I see why the nonconformance was issued.
I don't know enough about the area to say whether min/max information is necessary, but if you added the columns - thus making it part of your process - failure to record the information is a nonconformance.
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
7th December 2006, 02:53 PM
Karma Power: 1451
Finding
I just can't win
I'm not an expert in aerospace stuff, but it looks to me like your first mistake was adding the Min and Max columns. The standard, as quoted, requires evidence of conformity with acceptance criteria. Unless the standard, or your company requirements, require a specific way of creating records of conformance, then the auditor is off-base. Do you have records that provide evidence of conformance with acceptance criteria? Why is the auditor concerned with mins and maxs?
As I stated I using Attribute gaging and sometiems its supplied by customer these are Pass/Fail things there is no range ..
7th December 2006, 02:59 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,535
Karma Power: 400
Re: Audit Finding for this section - Min and Max for measurements - Attribute Gage
I see this as the key in this discussion: Attribute Gage. Personally, I'd contest the finding.
This auditor was the same one who wrote you up this year?
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
7th December 2006, 03:37 PM
Post Responsibly
Registration Date: Oct 2001
Thanks Given to Others: 1,598
Karma Power: 883
It is very hard to start second guessing here without a lot of background information. If any of the dimensions being measured is a key characteristic, then the actual dimension record is typically required. Further, one of the main concerns in aerospace is to reduce variation in parts. So, there might be a reason for a min/max requirement. Do you know if AS9103 is a requirement being invoked by your aerospace customers?
However, if your practice of using pin gages to check dimensions as go/no-go is acceptable to your customer and your own command media, the finding could be appealed.
Sustainable conformity assessment must add value to all stakeholders
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
MIN/MAX - Oversea Supplier Raw Material Supermarket Pull Systems
20120404 |
Lean - Lean in Manufacturing and Services |
3 |
15th December 2011 01:17 PM |
Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars
satishrevuru |
ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories |
6 |
13th October 2011 04:13 PM |
CP CPk from Min Max Data?
dlamarti |
SPC Monitoring and Statistical Analysis Techniques |
5 |
9th January 2009 02:35 PM |
Percentage of tolerance reported by supplier using the MIN or MAX dimension values
Irving |
Inspection, Prints (Drawings), Testing, Sampling and Related Topics |
4 |
7th March 2008 07:51 PM |
How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK
james_t_dk@hotmail.com |
Capability, Accuracy and Stability - Process, Machine, etc. |
3 |
2nd April 2001 04:02 AM |
