4th February 1999, 10:00 AM
Capability, FMEA and PPAP - 4.9.2 - The meaning of "high degree of capability"
Hi, I have two questions to submit:
First, I can't understand the meaning of "high degree of capability": Cpk/Ppk>=3 (see reference 4.9.2). Most of the time for us, a Ppk is higher than a Cpk because we carefully monitore all process parameters during a pre-launch. So, during full production, a Cpk has more chance to be lower than a Ppk. So, how can this equation be higher than 3 ?
Secondly, in the QS9000's third edition, are APQP, FMEA and PPAP have no significant changes. We plan doing nothing in those parts to update from second to third edition of QS9000. For me, these program elements have only been moved ?
4th February 1999, 05:56 PM
dWizard
Registration Date: Nov 1998
Karma Power: 63
Daniel,
That I would like to see. Perhaps I misunderstood.
Ppk is higher than a Cpk...
This is, more often that not, a poor estimate of sigma.
I ain’t gotta clue. As I said, a Cpk of > 3.0 would be a sight.
You may want to see http://Elsmar.com/pdf_files/CPK.pdf
Regards,
Don
[This message has been edited by Don Winton (edited 02-04-99).]
Thanks to Don Winton for your informative Post and/or Attachment!
5th February 1999, 11:47 AM
Cpk or Ppk >3 is ok. We understood Cpk divided by Ppk... It doesn't make sense. Thanks !
What about my second subject ?
5th February 1999, 11:05 PM
dWizard
Karma Power: 63
I think what Don was getting at is that a process with a Cpk of > 3, in the true sense, is unheard of.
Correct. But, upon re-reading the original post, I think Daniel was looking at the RATIO of Cpk/Ppk. This is even more confusing. Some QS folks may shed light, but I am so confused.
Sorry, Daniel, but as I have stated before, I am not QS savvy. Therefore, I will rely upon other members of the Cove to cover this aspect.
As always, if I am totally off base, someone please let me know.
Regards,
Don
6th February 1999, 01:13 AM
One of THE Original Covers!
Thanks Given to Others: 22
Karma Power: 94
I think what Don was getting at is that a process with a Cpk of >3, in the true sense, is unheard of. Generally speaking, a Cpk that high would indicate that the tolerance is too liberal or an error in calculation. If there is no calculation error, then the process is probably not worth monitoring (not cost effective) and you would be better off measuring something requiring your attention.
7th February 1999, 12:54 PM
Read "Ppk/Cpk" as Ppk OR Cpk. What they are saying is that, depending upon which calculation you used to determine capability - SPC type chart or histogram, a capability index of 3 is something you should pay little attention to, assuming normal distributions and "in control" is evident.
BTW, there are circumstances where a Cpk of 3 today is a negative Cpk tomorrow. Injection molding is a good example - in fact I have a real example. You can be near the edge but have extremely tight distribution with a Cpk of 3, send the tool out for polishing and suddenly produce parts out of spec. The dimension only moved .0007. Yes, shoot for nominal is normally the rule, but if you only look at Cpk, then you could be surprised in the future...
Oops, I forgot your second question. My input is, if it ain't broke, don't fix it. If you are satisfied that you meet the intent in those sections, they do not need changed. Somewhere you are going to state that your manual meets the "Third Edition" so you may take that opportunity to review those particular sections you mentioned, but I would certainly expend more resources on the sections that did change.
[This message has been edited by Batman (edited 02-07-99).]
8th February 1999, 01:49 AM
dWizard
Karma Power: 63
Good reply Batman. Thanks for the assist.
Regards,
Don
8th February 1999, 09:47 AM
Thanks ! Your comments are very helpful.
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
The meaning of "evaluation/measurement technique" & "control method" in Control Plan
astudent |
FMEA and Control Plans |
6 |
7th October 2009 11:58 AM |
Capability Study on Extruded Alumin(i)um - How would one define a "batch"?
Mezzaluna |
Capability, Accuracy and Stability - Process, Machine, etc. |
2 |
31st January 2008 06:00 PM |
What is exactly meaning of word between "Supplier" and "Vendor" ?
raknaja |
Definitions, Acronyms, Abbreviations and Interpretations |
3 |
13th September 2007 08:41 AM |
Software to Handle All "Quality" Processes? APQP, Control Plan, FMEA, MSA, PPAP, etc.
Morten Lunde |
Quality Assurance and Compliance Software Tools / Solutions |
1 |
11th September 2006 01:30 AM |
FMEA review, RPN reduction - Any "rule of thumb" as to what makes an RPN too high?
rstocum |
12 |
27th July 2006 09:23 AM |
