Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th March 1999, 09:20 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
Question Ppk - Capability calculation using the estimated sigma calculated from the Rbar/d2
I have a customer who takes a 30 piece sample and determines a Ppk.
He tells me we do it wrong. This is how we do it:
We take subgroups of five, and get X bars. Then we take the X bars and average them together to get a double X bar.
Then we take the double X bar and substitute it in the Cpk formula where the X bar is. Are we doing this right? HELP!!!
Sponsored Links
Old 26th March 1999, 09:29 PM
Batman
Unregistered Guest
Posts: n/a
Default
Hi Dawn.
Very simply, Ppk is the capability calculation using the estimated sigma calculated from the Rbar/d2 (read Rbar devided by d2,) as opposed to the Cpk calculation using the population sigma. The d2 factor is in any look-up table, and is based on the subgroup size.
Remember, when utilizing a SPC type chart, where you determine variation over time, and thus calculate Xbar and Rbar, the Ppk calculation holds up if the plots are "in control," so 5 subgroups may be a stretch for determining an "in control" condition.
If you are taking a 30 piece sample from a lot of parts, you may consider a Cpk calculation, if the sample is random. You may even consider NOT taking that sample if the parts come from a process that has demonstrated good control and good capability.
There is much more to this, I know a couple of wizards nearby that would love to enhance this. Also I believe there is a very good Cpk / Ppk explanation in the PDF zone elsewhere in this site.
Sponsored Links
Old 27th March 1999, 01:42 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Dawn,
Batman said it all, and there is not much I can add. Your method will satisfy the 'statistically valid' parameter, if asked, based on the information you supplied.
Regards,
Don
Old 27th March 1999, 05:59 PM
Karma Power: 0
Default
Thanks, I will look for the definition in the pdf files.
Next, I am told if I don't use the range in a capability study, I am doing Ppk not Cpk.
Also, if I calculate sample standard deviation, I am doing Ppk . Standard deviation is Cpk. Any takers?
Old 29th March 1999, 09:56 PM
Mark W
Unregistered Guest
Posts: n/a
Default
I don't claim to be a capability index guru, but the SPC Manual in the QS9000 documents gives a pretty clear definition of Cpk and Ppk. If using a control chart method for variable data (i.e. Xbar/R), Cpk (Capability Index) is derived from the chart with an estimate of the standard deviation taken from the control chart, s=Rbar/d2. It is used to determine long term process capability assuming a stable process and demonstrated with the control chart. The Ppk (Performance Index) is a measure of how the process is performing to the specifications based upon a sample from the population and the estimated sigma is derived using the sample standard deviation formula SqRoot(Sum(Xn-XBar)^2/(n-1)) (??or something like that??).
I believe your customer may be referring to these definitions when they state their way of calculating the Ppk index. Someone please let me know if I am way off base here.
Old 30th March 1999, 01:47 AM
Batman
Unregistered Guest
Posts: n/a
Default
Sorry, I didn't mean to confuse, but Mark is right. 'Process Capability,' called Cpk, IS from X-r chart, and is a capability index for 'common cause' only variation, that is, from a 'stable' process. This is the Rbar/d2 calculation. Yes, Dawn, Cpk uses the range chart.
Ppk is calculated from the sample standard deviation, or also called the population standard deviation.
Ref page 80-81 QS9K SPC manual.
Mark - use the calculator, it's easier. Heh heh.
Old 30th March 1999, 10:46 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Question:
Is the sample standard deviation (s, n-1) the same as the population standard deviation (sigma, n)? While the resultant is generally very close for averages above 25-30 samples, below you run more significant differences. When calculating Cpk, the denominator in the formula uses the 'population' estimate for the standard deviation, while in Ppk, the 'sample' estimate for the standard deviation is used.
Second Question:
I may be off base on this, but I thought that Ppk was used because the population standard deviation (sigma) is unknown? In this case, the biased calculation is used to normalize your results.
Anyone?
Old 30th March 1999, 02:18 PM
Karma Power: 94
Default
Don,
Ppk. Never heard of it until I got into the automotive world. Ppk from my understanding is used to prequalify processes in early Control Planning/PAPP. I do not know enough about its derivation, so I can't dub it as complete "nonsense" although I feel in my gut that it is. My gut tells me that it is just another fine creation from the automakers to make life simpler and create useful shortcuts. What's the sense if it is scrutinized? Oh well.
Back to the group...
Reply
Bookmarks
Tags
capability, estimated sigma, ppk, sigma
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Sigma Level and Capability - What are Ppu, Ppl, Sigma Level, Sigma Capability fed-up Capability, Accuracy and Stability - Process, Machine, etc. 6 6th May 2009 08:24 AM
MiniTab Calculated Formulas for a Calculation in a Column Michael J. Connell Using Minitab Software 2 29th June 2007 09:36 AM
Standard Deviation vs. Estimated Sigma Gary E MacLean SPC Monitoring and Statistical Analysis Techniques 9 27th June 2007 10:14 AM
Ppk and Pp on unilateral or unequal tolerance - DCx says Pp can not be calculated qualitytrec Capability, Accuracy and Stability - Process, Machine, etc. 19 9th September 2004 10:19 PM
Unbiased Estimators for Sigma? Is 's' an alternative to RBar/d2? George Tirebiter SPC Monitoring and Statistical Analysis Techniques 7 16th May 2001 06:02 PM
The time now is 08:27 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
