Elsmar Cove Quality DiscussionsConfiguration Management Simplified - Complying with AS9100 Clause 4.3The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
  Post Number #1
Old 12th December 2006, 10:57 AM
speck's Avatar
speck
Please Help! Configuration Management Simplified - Complying with AS9100 Clause 4.3
Configuration management seems to be a great big black hole that everything seems to fall in. We are exempt from 7.3 and only heat treat customers product. Justification is we develop the process to manufacture the product not the product itself. We only have 1 single part number for a company that we cannot validate through final inspection. As far as configuration management I am very confused as to what else is involved aside from document control and process change control and what the requirements are. Much has been written about this but most applies to D & D also. The general consensus seems to be if you have a good document control system in place then don't make C.M. overly complicated. I guess I just don't know how to ask a specific question because I don't know where to start with making sure we are compliant to 4.3 or not.
Sponsored Links
  Post Number #2
Old 12th December 2006, 02:16 PM
Wes Bucey's Avatar
Wes Bucey
Re: Configuration Management Simplified - Complying with AS9100 Clause 4.3
You might find some insight about Configuration Management in reading this old thread
http://elsmar.com/Forums/showpost.ph...68&postcount=4
  Post Number #3
Old 12th December 2006, 02:38 PM
speck's Avatar
speck
Thanks for the input. I read that several times before I posted. Am I on track by saying CM is nothing more than document and record control, redeveloping the control plan or heat treat processes, notifying proper parties, proper first article inspection, and then monitoring the change for proper validation. I think I am trying to overthink this a bit too much.
  Post Number #4
Old 12th December 2006, 03:01 PM
Wes Bucey's Avatar
Wes Bucey
In Reply to Parent Post by speck View Post
Close, but not quite. The folks in aerospace and electrical engineering (somewhat in software) make a big deal out of compatibility with ALL Associated Dociuments (read Processes, such as interchangeability; inspection tools, instruments, tolerances; etc.)
For example, if you heat treat widgets for customer A and also heat treat gizmos to the same spec for Customer B, do they both fit in same pan or rack? Same dwell time? Does either customer have a requirement to keep Rockwell points away from certain area of the part?
The customer -specific instructions and requirements are part of the so-called Associated Documents. Depending whether you use gas or electric furnace, is there any fluctuation in energy supply which might affect your process? (I recall an instance in the 60's when the local gas company in Long Island City suddenly began delivering gas with a lower BTU per cubic foot than previously, without notice, causing a lot of fouled up heat treating for at least one company.)
My consistent thesis is good CM requires the input of a person knowledgeable about all the possible "What ifs" which can affect the organization's product or service and makes provision to check the interactions if any one of the factors fluctuates or changes. I do not think it is a "clerk job."
Thank You to Wes Bucey for your informative Post and/or Attachment!
  Post Number #5
Old 12th December 2006, 04:00 PM
speck's Avatar
speck
Thanks again. Mr. Lamen is a nice man and his terms are someone I can relate to. This helps a lot. Seems though that this is a sticky area even for some experience people. I'll chew on this example and relate to our production processes.
  Post Number #6
Old 12th December 2006, 04:12 PM
Jim Wynne's Avatar
Who is Mr. Lamen?
  Post Number #7
Old 12th December 2006, 04:47 PM
speck's Avatar
speck
"In Laymen’s terms" or AS9100 for dummies, whatever you would like to call it. Less inexperienced people like me aren't quite as technically savvy yet or good spellers apparently.
  Post Number #8
Old 10th June 2015, 05:22 PM
Mr. K
So I'm reviewing the concept of configuration management and I stumbled upon this thread. I'm trying to dust off an oldie'.
My question pertains to the domain of configuration management. As Wes describes configuration management above, it would seem that configuration management also includes the specific configuration of production realization processes and their supporting documentation. However, wouldn't that be covered by the requirements pertaining to the Planning of Product Realization and Project Management?
I'm trying to do the best I can to delineate the boundaries of these broad quality concepts. Would my interpretation be incorrect?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Configuration Management - AS9100 Requirements Kasturi.P.Shetty AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9 5th August 2017 09:40 AM
Is Configuration Management Mandatory? AS9100 Clause 7.1.3 speck AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9 11th March 2011 12:01 AM
Configuration Management - AS9100 Rev B or C Mbarr AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7 13th August 2010 07:44 AM
Configuration Management Basics - AS9100 Koivisto - 2009 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9 7th January 2009 04:12 AM
Configuration Management Exemption? AS9100 normzone AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14 15th September 2008 12:29 PM
The time now is 03:29 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
