Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 9th July 1999, 04:36 AM
Tamashiro
Unregistered Guest
Posts: n/a
Please Help! Process Capability - Long-term vs. Short-term
In the Statistical process Control Reference Manual published by AIAG, capability falls under 2 categories; long-term and short-term. On page 59, Long-term capability is denoted as Cpk and uses an estimated process standard deviation while short-term capability is denoted as Ppk using the calculated standard deviation. It has been argued and published by many statistical program companies that Ppk is long-term and Cpk is short-term. the reasoning for this confusion relies on the definition of what long-term and short term is and how it relates to the standard deviation. What is the definition of Cpk and Ppk and why do most software companies publish process capability contrary to the statements in the AIAG manuals?
Sponsored Links
Old 9th July 1999, 12:16 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Clown
There is some discussion of Cpk versus Ppk at:
http://Elsmar.com/ubb/Forum10/HTML/000028.html
As far as the differences between AIAG and the software companies, I ain't gotta clue.
Regards,
Don
Sponsored Links
Old 10th July 1999, 01:15 AM
Lassitude
Unregistered Guest
Posts: n/a
Question
Because the AIAG is not the only 'expert' or business in the world. Software companies are looking to sell to the world, not just Ford, GM and Chrysler.
Specifically which software package are you talking about?
Old 11th July 1999, 01:44 AM
Tamashiro
Unregistered Guest
Posts: n/a
Specifically Minitab
Old 11th July 1999, 02:41 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Question
I have no experience with minitab to know. Can you cite the specific equation differences (or other details of the differences) you are asking about?
Old 11th July 1999, 04:52 PM
Tamashiro
Unregistered Guest
Posts: n/a
The equation for process capability is exactly the same as indicated in the AIAG reference manual. The clarification I'm looking for is in the definition of long term and short term. The AIAG reference manual does not define long term or short term, but seems to imply long term using Cpk. Cpk uses an estimated sigma, which implies it estimates capability based on trend and therefore may predicate future capability. Ppk, however uses a finite source of data for sigma, which implies capability for that particular set of data.
In some of the software packages, I've noticed Cpk is referenced as short-term and Ppk as long-term. What is the definition of long-term and short-term capability and is long-term represented by Cpk or Ppk?
Old 12th July 1999, 02:09 AM
Don Winton's Avatar
dWizard
Karma Power: 63
Clown
I am not familiar with Minitab either. I also do not have a copy of the AIAG manual. But, as I elaborated on in the forwarding thread I referenced above, I believe AIAG has produced more problems by creating this Ppk thing. I had never heard of it before the forwarding thread above, nor had I heard of short-term or long-term capability studies.
All process capability studies should use an unbiased estimate of standard deviation or calculated standard deviation as detailed in the CPK.PDF file located at the PDF Zone section of the Cove. It states:
"To obtain an accurate estimate of the process spread (standard deviation), at least sixty data points are needed. If less that sixty data points are available, use the following formula with error correction factors given in Table 1."
Basically, if there are less than sixty data points, you use an unbiased estimate of standard deviation corrected by the formula. If greater than sixty data are available, use the standard deviation calculated from the data.
BTW, which symbol (s, sigma-hat, s-hat, etc.) does the AIAG manual use in the formula for Ppk and Cpk to represent process spread?
Regards,
Don
Just the ramblings of an Old Wizard Warrior.
Old 17th July 1999, 06:59 PM
BRoyal BRoyal is offline
Karma Power: 45
BRoyal has less than 100 Karma points so far.
Davis Bothe addresses the difference between Cpk and Ppk in his book "Measuring Process Capability." McGraw-Hill is the publisher. Be aware that this book will probably tell you more than you want to know about process capability
Ben Royal
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Interpretation of Short term vs. Long term Capability Studies Chennaiite SPC Monitoring and Statistical Analysis Techniques 3 24th March 2009 09:05 AM
Process Capability Sheet for a short term 30 piece study needed jkittle SPC Monitoring and Statistical Analysis Techniques 1 24th April 2007 04:51 PM
Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability DJN Capability, Accuracy and Stability - Process, Machine, etc. 25 15th March 2006 01:26 AM
Short and Long term effects of humidity on tooling and gages DE_Perry ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 6th August 2005 12:02 PM
Capability: Short Term or Long Term? Cpk= Long term and Ppk= Short term? Andrews Capability, Accuracy and Stability - Process, Machine, etc. 15 22nd January 2004 04:28 PM
The time now is 08:16 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
