Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th January 2000, 02:35 PM
MSHELLEY
Unregistered Guest
Posts: n/a
Bomb! Cp & Cpk - How are you calculating the standard deviation?
WE REGULARLY COLLECT DATA FROM CONTROL CHARTS AND COMPUTE THE CAPABILITY INDEXES Cp & Cpk. WE ALSO COLLECT DATA FROM DOCK AUDITS AND COMPUTE THE SAME INDEXES. WHY DO THE ONES FROM THE CHARTS ALWAYS HIGHER. ASSUMPTION IS THAT ALL DATA IS GOOD.
Sponsored Links
Old 28th January 2000, 03:09 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
If I'm understanding the scenario correctly, I would wonder how are you calculating the std. dev? If you are using r-bar /d2 for the control charts, and experience mean shifts, then the est. of you std dev. can be lower than the dock audit if all the parts are thrown into one "subgroup" and std dev. calculated for the lot. Lower std dev, higher Cpk. Do the process charts show control?
Sponsored Links
Old 30th January 2000, 09:21 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
BIG Smile
Laura brings up a good point. I also would question the standard deviation calculations on the dock audits. Typically, when your sample sizes are less than 60, you must use an unbiased estimate of sigma. With control charts, this is not a problem, but with audits, caution must be exercised.
For more information regarding process capability, go to http://Elsmar.com/pdf_files and download CPK.PDF. This paper explains the unbiased estimate of sigma. You can also visit my web site below for other stuff.
Regards,
Don
Old 19th February 2001, 07:35 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Yin Yang
For a good thread on Cp, Cpk, Ppk, etc., see: http://Elsmar.com/ubb/Forum10/HTML/000001.html
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calculating a Standard Deviation with respect to MTBF bucky88 Reliability Analysis - Predictions, Testing and Standards 1 3rd November 2007 06:44 AM
Mathematical difference between mean Deviation and Standard Deviation Abhijeet SPC Monitoring and Statistical Analysis Techniques 3 11th July 2006 10:20 AM
Calculating Savings from Standard Deviation when Mean remains constant and SD changes cyberspider SPC Monitoring and Statistical Analysis Techniques 4 7th October 2005 04:37 PM
Back to Basics Statistics - Standard Deviation small when performing an R&R Jstain1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14 13th May 2004 02:51 PM
Gage R&R (Ranges Method) - Reproducibility standard deviation Martin Kies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 28th October 2003 06:54 AM
The time now is 10:39 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
