Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st May 2000, 07:40 AM
dragonmaster
Unregistered Guest
Posts: n/a
Please Help! Can I calculate Cpk from Cp and Cr?
Not being real good with math, I would like to know if I can calculate CPK form just having CP and CR available.
Sponsored Links
Old 1st May 2000, 08:47 AM
Martin
Unregistered Guest
Posts: n/a
Lightbulb
If you send me your e-mail address I can send you an excel file of a capability study. This calculates your Cp and Cpk value in a sec. You just fill in the values (X) and the program calculates the Cp, Cpk, if it's capable and a lot more.
Greetings,
Martin
Sponsored Links
Old 2nd May 2000, 02:54 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Question
Capability Ratio = Tolerance Width/process capability; however i can't make it work out right.
I thought capability ration was Cr = 100/Cp?
Regards,
dWizard
Old 2nd May 2000, 04:11 PM
James Cupello
Unregistered Guest
Posts: n/a
Yin Yang
I would like to respond to dragonmasters original question.
As Don Winton notes: Cp is just the inverse of Cr. Cp is known as process capability. It is simply the ratio of two numbers: A and B.
The numerator in the ratio (number A) is simply the difference between the upper spec and lower spec limits. Obviously I am assuming a two-sided spec limit.
Referring to Sam's post, a +/- spec limit of 0.005 is equivalent to
0.005 - (- 0.005)
or a value of 0.01 for the numerator, not "0."
The denominator (number B) is 6 times the short term estimate of sigma. Lets not get into long-term and short-term estimates of sigma, even though the difference is important. For dragonmasters simple question lets keep it simple.
So we have A/B = 0.01/(6*sigma)= Cp.
Cr = (6*sigma)/0.01
In either case, the answer is not zero.
Cpk is another matter. Cp is a capability index since it measures a processes potential for performance. It is the best one could expect if the process were centered directly between the upper and lower spec limits.
Cpk assumes the process is not centered. In such a case you must calculate two values for Cpk, and use the lesser of the two resulting values.
First we measure Cpk relative to the upper spec limit (USL). Then we measure Cpk relative to the lower spec limit (LSL). The smaller of the two values is the Cpk for the process. The two equations are:
Cpk = (USL - Xbar)/ 3*sigma
Cpk = (Xbar - LSL)/ 3*sigma
Pick the smaller.
If you want to read everything there is to know about measuring process capability suggest Davis R. Bothe's MEASURING PROCESS CAPABILITY, McGraw-Hill, ISBN 0070066523. It runs about $100, so I hope you really want to know this stuff.
Cheers.
Old 3rd May 2000, 01:24 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
I found this little "quicky" formula in Juran's hdbk.
I don't understand the Cp - Cr concept;most tolerances I work with are bilateral,such as +/- 0.005, in which case the Cp always comes out "0", unless I'm using the wrong formula.
Old 3rd May 2000, 09:38 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Don, you are correct, but Juran also has the other equation listed in his book.
James, you sre correct. After seeing your response I realized my error; my thoughts were fixated on tolerance rather than USL and LSL. he equation states in the Numerator "USL - LSL", when using tolerance it should be the algebraic sum.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How can I calculate Cp & Cpk and make a control chart for maintenance activities? hispeed Capability, Accuracy and Stability - Process, Machine, etc. 3 10th November 2007 02:13 PM
Sampling plans and Cpk - Some way to calculate the sample quantity Angela at SKF Inspection and Test, Sampling and Related Topics 2 18th January 2006 09:50 PM
Capability study - What Values do I have to input to calculate Cp and Cpk NetScorpium Capability, Accuracy and Stability - Process, Machine, etc. 9 20th December 2004 05:33 AM
How do I calculate Cpk with a single Control Limit? Bob in KY Capability, Accuracy and Stability - Process, Machine, etc. 15 23rd June 2004 08:05 AM
How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK james_t_dk@hotmail.com Capability, Accuracy and Stability - Process, Machine, etc. 3 2nd April 2001 05:02 AM
The time now is 04:00 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
