Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 20th December 2006, 03:05 AM
ROOTS ROOTS is offline
Involved in Discussions
Registration Date: Nov 2006
Karma Power: 13
ROOTS has less than 100 Karma points so far.
Laughing Rms Spl And Peak Spl Spectrum - Sound Level Spectrum
I have a clarification in Sound Level Spectrum.
We are manufacturing Automotive DC Electric Horns and when we measured the Spectrum we achieved the following results;
1. Peak SPL : 108.8 dBA
2. RMS SPL : 112.1 dBA
3. Mean : 85 dBA
My doubt is whether the RMS SPL should be lesser or greater than the Peak SPL. My graph shows with RMS SPL as greater.
Pl. clarify me whether the graph is correct and also to arrive the formula for calculating RMS SPL, difference between RMS SPL, Peak SPL ansd overall SPL.
I have also attach the graph for your easy reference.
Pl. help.
Regards
M.Prabhakar
Last edited by ROOTS; 20th December 2006 at 04:18 AM. Reason: Wrong value entered for RMS and Peak SPL
Sponsored Links
Old 20th December 2006, 09:25 AM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Default Re: Rms Spl And Peak Spl Spectrum - Sound Level Spectrum
I have a small amount of experience with sound analysis of equipment. In that experience, the RMS has always been less than the Peak (How can it be the peak if it is not the max?). My guess is that you need to open your scale up to see the full spectrum. You are using 0 to 5000 Hz, but the frequency of the peak may be 20,000. Also, sound spectra of equipment will often show multiple peaks at different frequencies. The more complex the equipment, the more peaks.
Also, learn about harmonics and sidebanding. Your file appears to show a lot of sideband frequencies. Make certain that you have high quality microphones for your analysis, and that you have calibrated your microphones to your software. If you have not calibrated the microphone to the software, the amplitude measurement is meaningless.
Definitions:
- SPL = Sound Pressure Level
- RMS = Root Mean Square (This one method of determining an "average" SPL) This is analogous to Ra in surface roughness. You should check how your software determines this. Is it the RMS for the entire spectrum, or the RMS for the range of frequencies investigated?
- Peak SPL = the maximum SPL observed. You should check how your software determines this. Is it the max for the entire spectrum, or the max for the range of frequencies investigated?
- Overall = Check how your software defines this.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 21st December 2006, 12:16 AM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Originally Posted by ROOTS View Post
3. Mean : 85 dBA
Pl. help.
Regards
M.Prabhakar
Like Miner, I also know a bit a bout sound - just enough to be dangeraous!
The horn appears to have a "fundamental frequency" around 360 Hz, at then several "harmonics" at multiples of this frequency. As I interpret the graph, it basically shows the loudness of each of these peaks.
What you are most likely interested in is the "total loudness", since that is what people hear. In this case, you would want to add all the values. I expect that the "RMS SPL" listed above is the RMS sum, not the RMS average.
Two things to note when doing such a sum. First, decibels are a logrithmic measurement. Adding 109 dB and 105 dB (approximately your two biggest peaks) is only about 110.5 dB. Adding another two peaks at 103 and 102 raises it another 1.2 dB to about 111.7. Given the roughness of my esitmates, and adding in the rest of the smaller peaks, 112.1 dB sounds about right for the RMS total.
Secondly (and perhaps less importantly) "dBA" is slightly different than "dB". dBA tries to take into account that the ear hears some frequencies better than other frequencies. This would adjust the sum slightly, but probably not much in this case.
Remember, this is based on theory, not experience. I have taught sound in physics classes, but never done industrial measurements or had to calibrate equipment.
Tim F
Old 21st December 2006, 12:28 AM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Boy, for two ole boys with just a little bit of experience, nice posts!
I would have hated to see the length of it if they were your hobbies!
Roots, not sure if you may want to Google that one, and maybe post in some other Internet discussion threads specifically for sound/audio. Although, the level of expertise on the Cove has so far been nothing short of Amazing.
Also, maybe you could try some of the schools with Acoustical Engineering programs.
Brad
My idea of housework is to sweep the room with a glance.
Old 21st December 2006, 12:47 AM
Karma Power: 13
Dear Mr.Miner / Mr.Tim Folkerts,
Thankyou very much for your kind feedback.
Mr.Miner for your question, the RMS shown here is for the entire Spectrum. (ie. from 0 to 5000 Hz). But however, now after seeing both of your feedback I am clear and will act accordingly.
And one more question Mr.Tim, You have mentioned that the RMS shown in the graph is RMS Sum and not RMS average. When we have to consider RMS average? in other words at what type of measurement RMS average to be considered? Can you Pl. reply
Once again thankyou for both of you for your kind help.
Regards
M.Prabhakar
Old 21st December 2006, 01:29 AM
Karma Power: 123
M. Prabhakar,
One common place where an RMS average is used is in AC electricity. In the US, the standard voltage for outlets is around 110 V AC. However, since the voltage goes positive and negative in AC, the actual "average" is zero! Instead, what is normally quoted is the RMS Voltage. You square (S) the volage at each instant (say every 0.001 s), then take the mean (M), then take the square root (R). So you have the Root of the Mean of the Squares. For a typical sine wave used in AC electricity, the peak value ends up being 20.5 times the RMS value.
Besides getting rid of the "average being zero" problem, the RMS AC voltage provides the same power as the equivalent DC voltage.
So 110 V(RMS) would go from about +155V to -155V, and light up a light bulb just as well as 110 V DC.
Tim F
P.S. Given that RMS means "root mean square" it is perhaps a bit of a misnomer to talk about RMS without taking an average.
Now that I think about it, you could also take the RMS average of the original pressure measurements. To get the FFT (fast fourier transform) graph you presented, you must have collected pressure data at fairly high speed (certainly higher than the 5000 Hz at the top of the graph). Instead of processing the data to get the graph, you could just take an RMS average of the raw pressure data. This RMS average could be used to calculate the dB level directly, and it would be higher than the dB level of any of the individual peaks.
Old 21st December 2006, 05:07 AM
Karma Power: 13
Dear Mr.Tim,
Thankyou for your immediate response. You have very clearly and nicely explained me the RMS. Now I got some idea to work. Thankyou very much.
Regards
M.Prabhakar
Old 8th January 2007, 12:36 AM
Karma Power: 13
Laughing Re: Rms Spl And Peak Spl Spectrum - Sound Level Spectrum
Dear Mr.Tim F,
Goodmorning to you.
One more clarification in the RMS SPL.
As you said SPL in complex frequencies gives RMS Sum is understood to me. But what we call the individual SPL at each frequencies. (ie. my question is we have checked the Spectrum from 1800 to 3550 Hz and found the SPL as below;
1. At 2000 Hz = 81.8 dBA
2. At 2500 Hz = 94.2 dBA
3. At 3200 Hz = 111.3 dBA
RMS Sum = 111.38 dBA
What we call the SPL at 2000 Hz, 2500 Hz and 3200 Hz. Whether it is RMS SPL or Peak SPL or maximum SPL.
Please clarify.
Regards
M.Prabhakar
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Tolerance Stack - Why do we use RSS instead os RMS in tolerance stacks? Guru_raj Book, Video, Blog and Web Site Reviews and Recommendations 1 17th February 2009 02:15 PM
Identifying Peak Demand and Usage with Start/End Time - Hospital brookstr Hospitals & Health Care Providers - Best Practices and ISO 9001 3 21st November 2008 05:07 PM
Sneak Peak of Committee Draft 1 of ISO 9001:2009 vanputten ISO 9001:2008 Status 4 16th February 2007 12:49 AM
Chemical Spectrum Analysis by one of our group companies ROOTS Various Other Specifications, Standards, and related Requirements 1 23rd November 2006 08:03 AM
Structure in ISO 9001 documentation - Level 1, Level 2, Level 3, Level4, etc. gilsg Documentation Control Systems, Procedures, Forms and Templates 7 14th October 2000 09:44 AM
The time now is 04:54 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
