Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th March 2001, 02:43 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
Default Machine Capability Studies: How many parts needed?
I'm looking but not finding a general statement anywhere here stating exactly how many parts should be checked as a general guideline for a machine capability study. Any body?
Sponsored Links
Old 14th March 2001, 03:18 PM
AJLenarz AJLenarz is offline
Involved in Discussions
Registration Date: Feb 2001
Karma Power: 36
AJLenarz has less than 100 Karma points so far.
Hello Dawn,
The rule of thumb as stated in both the SPC manual is “25 or more subgroups containing about 100 or more individual readings give a good test for stability and, if stable, good estimates of the process location and spread”.
This can be found in SPC manual pg 31.
The PPAP manual states: “… at least 100 individual samples…”
This can be found in PPAP manual pg 6.
Sponsored Links
Old 14th March 2001, 04:06 PM
Al Dyer
Unregistered Guest
Posts: n/a
Lightbulb
Dawn,
I'm not sure if you will find a definitive standard. The guidelines in the AIAG manual are at the best "adequate"
What I like to consider is the product being produced, the tools used, and cycle time. At a minimum I would consistantly graph 5 samples per subgroup during and 8 hour continuous production cycle.
This is not to mean inspect every part, just measure and plot one group and when that is done get the next 5 pieces, production continues while you are doing the study.
This is probably labor intensive but by doing it through 1 or 2 production shifts you will be able to get a handle on both random and assignable causes of variation.
ASD...
Old 15th March 2001, 09:56 AM
Ken K.
Unregistered Guest
Posts: n/a
I agree that the SPC Reference Manual and the PPAP Manual quantities are pretty standard.
Here is a method based on an article called "Recent Developments in Process Capability Analysis" by Robert N. Rodriguez (JQT, October, 1992)
I'll show it in Excel format:
XX=DELTA-NORMSINV(A/100)*SQRT((1/(9*N))+(CPK^2/(2*(N-1))))
where
A is the Type I confidence level expressed as a percentage, typically 90 or 95, {0<B<A<100}. n increases as A increases.
CPK is the upper bound estimate of the Cpk, n increases as the CPK estimate increases.
DELTA is the desired resolution. Half-width of the desired one-sided lower confidence interval. n increases as DELTA decreases toward zero.
In all the above inputs, if unsure, use the more conservative value - the one that would provide the larger sample size n.
N is a proposed sample size that will be evaluated using the XX value.
Start with N = N' shown below:
N'=CEILING(NORMSINV(A/100)^2*(1/9+CPK^2/2)/DELTA^2,1)
Increase the value of N by integers until the smallest positive value for XX is obtained. The resulting N is the recommended sample size, n. Of course this assumed normality.
Typically the final number n is simply N'+1.
Old 15th March 2001, 11:06 AM
DICKIE
Unregistered Guest
Posts: n/a
We typically use a minimum of 25 subgroups. Most of the customers for special machines we build ask for 25 subgroups of 5.
Old 15th March 2001, 12:28 PM
Karma Power: 0
Thanks!
If you are running a study for 8 hours, 20 hours, 24 hours, etc., is this without ANY adjustments?
Old 15th March 2001, 02:27 PM
Al Dyer
Unregistered Guest
Posts: n/a
Dawn,
That is with adjustments and are noted on the control chart as a reference.
ASD...
Old 16th March 2001, 01:05 AM
Karma Power: 36
Capability indices can be divided into two categories: short-term and long term. Short-term capability studies are based on measurements taken from one operating run (the time frame could vary depending your particular production process). The data are analyzed with a control chart for evidence that the process is operating in a state of statistical control. If no special causes are found (a machine adjustment could be considered as a special cause), a short-term capability index can be calculated. This type of study is often used to validate the initial parts produced from a process for customer submission. Another use is for machine capability studies.
Long-term capability studies consist of measurement consist of measurements that are collected over a longer period of time. The data should be collected for long enough, and in such a way, as to include all expected sources of variation.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Volumetric Positioning - Machine capability studies for CNC machine tools mlthompson ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 28th May 2008 01:37 PM
Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools mlthompson Manufacturing and Related Processes 5 17th May 2008 04:34 PM
Machine Capability Studies on CNC Lathes DWPOZE SPC Monitoring and Statistical Analysis Techniques 34 29th March 2008 02:08 PM
Differences between Machine Capability and Product Capability studies Mumus Capability, Accuracy and Stability - Process, Machine, etc. 9 14th October 2007 12:01 PM
Capability Studies - Fewest Number of Parts for a Capability Study ivo Capability, Accuracy and Stability - Process, Machine, etc. 9 20th June 2006 04:25 PM
The time now is 10:48 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
