28th August 1998, 06:03 PM
Sampling Plan to determine sample size/frequency based on a Given Rate of Production
I'm looking for a sampling plan/table to determine sample size and inspection frequency based on a given rate of production. For example, a process produces 500 pieces. How many pieces should be checked and how frequently?
28th August 1998, 06:37 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
If you're looking for an AQL (Acceptable Quality Level), why not use the old Mil-Std-105? It's technically a canceled document (as is the way with many old military specs) but you can still use it. I know an organization 'took it over' but I can't remember who it was.
21st September 1998, 06:36 PM
dWizard
Registration Date: Nov 1998
Karma Power: 63
bimco,
I agree with Marc. Even tho MIL STD 105 is discontinued, the OC's and sampling plans are still statistically valid. Use these as a good guide. I recently received a post that gave guidance as to sample sizes:
n>=((Za/2*sigma)/E)^2 wher Za/2 is (1-confidence(i.e.0.95))/2. Sigma is standard deviation of the data and E is the expected Error. This is also considered the difference between the mean and your sample and the mean (estimated, maybe) of your population.
I have another equation somewhere (?) and will also try to forward this one as well.
Regards,
Don
20th March 1999, 11:17 PM
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0 Karma: 40
Sampling Plans
Wanna talk sampling plans? I know. I read and read and I just don't get it. Wish I was born with a statistics mind. How do you determine the OC curve in the first place? I don't see the sample size anywhere on the OC curve samples I have looked at and I don't see any explanation on how they get it on there. Lost again....
21st March 1999, 10:05 PM
Dawn, I cannot answer you specifically, since I am also continually puzzled by statistics beyond Xbar and sigma, and histograms. However, Stan Hilliard has a sampling plan website called www.samplingplans.com. He also sells software there. I have never seen the software and am not promoting it, but he does have some info there.
22nd March 1999, 03:55 PM
dWizard
Karma Power: 63
Dawn,
Oops. Forgot something. I detailed the distributions to use, but forgot to describe when to use them. Here we go:
Binomial Probability Distribution: Applies when the population is large (greater than 50) and the sample size is small compared to the population, generally less than 10%.
Poisson Probability Distribution: Is an approximation to the binomial when P is equal to or less than 0.1 and the sample size is large. (I prefer this one).
Hypergeometric Probability Distribution: Whenever the sample is drawn from a smaller, finite lot. This calculation is a bear, but spreadsheets and computers make it easier these days.
Then, there is always the normal distribution. It can be used as a probability distribution as well when the population size is large.
The above are general guidelines. There are no firm, fixed rules when to use one or the other. My suggestion would be to balance time versus benefit in the calculations.
Generally, the sample tables in MIL-STD-105 are statistically valid, even though the document itself is obsolete. Rather than design sampling plans from scratch, I suggest, if a sampling plan is used, design it from these tables.
Regards,
Don
23rd March 1999, 01:22 AM
dWizard
Karma Power: 63
I personally am not a big fan of sampling plans, but that is another story.
The OC curve is developed by determining the probability of acceptance for several values of incoming quality. Pa is the probability that the number of nonconforming in the sample is equal to or less than the acceptance number for the sampling plan.
There are three distributions that can be used to find the probability of acceptance: the hypergeometic, binomial and the Poisson distribution. The Poisson distribution is the preferred because of the ease of Poisson table use. Be sure you can satisfy the assumptions for Poisson use. The Poisson formula is:
P = [(e^-np)*((np)^r)]/r!
n = Sample Size
p = Proportion nonconforming
r = Number of nonconforming or less
Assume n = 150 and r = 3, (called c in sampling plans) then:
Lot Percent Nonconforming
1%, np = (150)(0.01) = 1.50, P(r <= 3) = 0.93
2%, np = (150)(0.02) = 3.00, P(r <= 3) = 0.65
3%, np = (150)(0.03) = 4.50, P(r <= 3) = 0.34
4%, np = (150)(0.04) = 6.00, P(r <= 3) = 0.15
5%, np = (150)(0.05) = 7.50, P(r <= 3) = 0.06
6%, np = (150)(0.06) = 9.00, P(r <= 3) = 0.02
You then construct the table from these values with Lot Percent Nonconforming as the X value and Pa as the Y value.
Hope this helps.
Regards,
Don
23rd March 1999, 03:18 AM
Courtesy Access
Registration Date: Feb 1999
Karma Power: 44 Karma: 10
According to QS-9000 3rd edition Element 4.10 Inspection and Testing "4.10.1.1 Acceptance criteria for attribute data sampling plans shall be zero defects........"
Does it mean that Mil-std-105 can not meet to QS-9000 requirements on this item? Because of it allows acceptance not zero defects depend on AQL level and Lot/Batch size.
Please advise your opinion.
Thanks,
