Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > The Reading Room
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th December 2006, 12:06 PM
Scott Thor Scott Thor is offline
Getting Involved (6 to 9 Posts)
Registration Date: Apr 2002
Karma Power: 33
Scott Thor is appreciated, and has over 100 Karma points.Scott Thor is appreciated, and has over 100 Karma points.
Read This! Getting started with statistically based process improvement
Here's an article I wrote to explain the basics about statistically based process improvements. Feel free to give me any comments you may have.
Scott
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf Getting Started With Statistically Based Process Improvement, executive version.pdf (37.3 KB, 338 views)
Thanks to Scott Thor for your informative Post and/or Attachment!
Sponsored Links
Old 28th December 2006, 12:10 PM
Craig H. Craig H. is offline
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 283
Karma Power: 171
Craig H. is appreciated, and has over 1700 Karma points.
Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.
Default Re: Getting started with statistically based process improvement
Scott,
Nice work! Thanks for sharing!
Sponsored Links
Old 28th December 2006, 01:14 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Scott
Thanks for sharing. A few observations:
  • In Step 2 you encourage determining the current state of the process through use of control charts, which is sound advice, but you also suggest that "A basic condition that must be satisfied before any improvements can be made is a stable and predictable process." There's a bit of redundancy there, because in this context "stable" and "predictable" are synonymous. Also, the problem might be instability, so in curing that issue, the problem might be solved. In other words, you can make improvements to an unstable process, contrary to your assertion that stability must be achieved as a prerequisite.
  • The charts in figures 1 and 2 show signs of instability other than points beyond the control limits; you might want to point out the fact that there is more than one test for statistical control.
  • You say, "Any points outside of the limits represent what are known as special causes..." Not necessarily; when using the normal curve as a model (which might not be advisable) we can predict that some points will naturally fall outside the ±3-sigma limits. It might be good to point this out, and advise against tampering.
  • You say, "Typically most improvement projects identify that the process is unstable which then begins the task of identifying why that is?" I'm not at all sure that the statement is true. In many cases, analysis will reveal a predictable but incapable process. Also, the sentence should end with a period and not a question mark.
  • You say, "If after getting you process under control the upper and/or lower control limits are outside of the specification limits you have a process that is near the brink of chaos." Clearly, the condition you describe is undesirable in most cases, but "near the brink of chaos" seems a bit strong. Although the instances are rare, there are times when a certain level of nonconforming output is acceptable and economically necessary.
  • In addressing "Sustaining the Improvement," you say, "Without the proper controls all processes will tend to work back to where they began before the project." This is certainly true, but the object of the project should be installation and monitoring of controls. That is to say, the object should be to identify the process controls which, if maintained, will result in conforming output, and then monitor and measure those, rather than focusing on part/output measurement. The entire idea of process improvement should be making the process predictable by controlling the process variables that have been proven to contribute to conforming output.
Old 28th December 2006, 02:25 PM
Steve Prevette's Avatar
Steve Prevette Steve Prevette is offline
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
My suggestions would be:
Yes, I can improve a process that is not stable and predictable. I look at the special causes associated with the statistical signals and deal with them (corrective action when in the bad direction, reinforcing action when in the good direction). Actually, I'd much rather have this situation as compared to a stable and predictable process, as these special causes are usually easy to deal with, and fit with the paradigm of most managers that I must "do something" with the specific results.
It may be worth pointing out that changing a stable process is HARD!
On Figure 1, where did the control limits come from? They certainly do not fit the current data. Is it from some older data? If so, it is worth showing the older data (which should have been in control to get the control limits from) and then show the changing condition related to the trends (and yes, there are more than one) on Figure 1. In showing examples, they should be rigorous, good examples that you would want others to follow.
In figure 2, I'd show the example with at least 25 points. Dr. Shewhart stated do not declare a process stable without 25 points. It sets a good example to show your example chart with 25 points. So many folks want to throw out old data prematurely.
On the statement "Many projects make significant improvements only to fall back into the [previous] state". I would disagree with that. What I see more often is that people declare success on a "lucky" result, not a statistically significant trend on the control chart in the improving direction. Generally, once the control chart shows a significant trend, the improvement has stuck. At least, that is my empirical experience, and it is supported by theory.
Also, I'd suggest being careful with the "gut feeling" discussion. All data are flawed, Dr. Deming stated that there is no true value of any measurement. The best state is where you can reconcile your gut feelings with the data. I'd much rather have a doctor operate on me when their gut feeling and the data are in synch. How many times has that little red flag gone off in your head that something is amiss, but you ignore it due to the numbers, and come to find out . . .
Good luck, and Happy New Year
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
Old 28th December 2006, 03:06 PM
Deming Disciple
Karma Power: 190
I disagree with this disagreement. We use the 3 sigma limits as the operational definition of a signal. Just as we evacuate a building when the fire alarm sounds, and then check back to see if it was a false alarm if we find no indication of a fire, we should still take immediate action on a point outside the control limits. Yes, it may be a false alarm, but we do take a good-faith effort on taking action. I would not consider taking action on a 3 sigma limit outlier to be "tampering".
Steve Prevette
Old 28th December 2006, 08:02 PM
Jim Wynne's Avatar
Courtesy Access
Karma Power: 612
If you define "taking action" as looking to see what (if anything) happened, then I agree. I didn't mean to suggest that the potential signal should just be ignored. The statement in the article said that "Any points outside of the limits represent what are known as special causes..." And I said, "not necessarily," which is correct.
Old 28th December 2006, 08:15 PM
Deming Disciple
Karma Power: 190
Ah, okay. Yes, perhaps something like "theory and experience tells us that we likely will be able to find a special cause for any point outside of the limits".
Steve Prevette
Old 28th December 2006, 09:52 PM
Jim Wynne's Avatar
Courtesy Access
Karma Power: 612
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Internal Audit - Process based vs. Procedure based ValleyGirl AS9100 Aerospace Standard and Requirements 11 19th September 2008 09:05 AM
Process that is Not Stable vs. Not Statistically Capable - Differences hejianls Capability, Accuracy and Stability - Process, Machine, etc. 9 19th February 2008 08:55 PM
Continual Improvement based on a Company's Characteristics zerodefect Preventive Action and Continuous Improvement 6 16th November 2007 07:05 AM
Savings Yield of Process Improvement over Product Improvement k3nny Six Sigma 8 19th September 2007 10:49 PM
20 Factors based QMS to TS 16949 Process based Quality Management System Link Xue ISO/TS 16949 - International Automotive Quality Systems Standard 1 10th March 2004 03:57 AM
The time now is 03:50 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
