22nd June 2000, 06:06 PM
Increased positional tol. due to departure from MMC (Bonus)and calculation of Ppk/Cpk
We are in a bit of a dilema. Engineering and Quality are arguing about the use of "bonus" tolerance when calculating Ppk/Cpk values. One subcommittee member of ASME Y14.5M-1994 said that this is used only for building functional gages or in individual layouts, not for capability studies. I'm seeking a second opinion. I have been unable to find any basis for this in the standard. The closest I have come is on page 85 on the note after section 5.3.2.2, but this is vague.
Thanks,
Dura Guy
Manufacturing Engineer
22nd June 2000, 06:10 PM
Wow that is tough! there is two sides to this.
What about tolerance don't they understand? Bonus smonus bolonus, IT IS STILL TOLERANCE IS IT NOT?
However, feature amy change and that is not what you are testing, you are testing POSITION not feature capability.
what a conumdrum!!!!!!!
23rd June 2000, 11:58 PM
Registration Date: Mar 1999
Karma Power: 45 Karma: 10
Quality Joe, I had to disagree with you. There is a method to calculate capability with of true positions that I found. In an article published in 1991 by Glenn Gruner in Quality Engineering Magazine, he illustrated how to perform such calculation. This method is the combination of feature size and feature location that is critical, not the separate components.
TPa = TPm - (Bonus Tolerance)
TPa = TPm - (MMC-Xf)
TPa = TPM - MMC + Xf
where
TPa = Adjusted true position
TPm = Measured true position
Xf = Measured feature size
The procedure is, for example, a 100 piece sample size:
1) Calculate TPa for each of the 100 samples
2) Take the average of TPa (or XbarTPa)
3) Use conventional Cpk formula,
Cpk = (USL - XbarTPa)/3*s
According to the author, similar application could be made for tolerances specified at the LMC of the feature and when bonus tolerance is gained as one or more datum depart from MMC (or LMC).
Anyway, it was an interesting article. Hope this helps, Dura Guy.
24th June 2000, 01:39 AM
In general, you can not use "bonus" tolerance in calculating capability. The reason for this is the feature that is varying from MMC is what is giving you the bonus tolerance. Therefore, unless you can guarantee that the feature size will never result in less bonus tolerance than when you did the capability assessment, you MAY NOT use bonus tolerance.
However, if you can put in controls to insure that the size of the feature will never vary to take away bonus tolerance (i.e. making sure a punch is nominal or higher or a drill bit can never be below a certain exact size) you may use bonus tolerance.
I would say that a manufacturer of product that needs to use bonus tolerance to validate a positional Cpk study is playing with fire. You should either see if relief can be given from design or get a manufacturing engineer that knows what he or she is doing. The ME has be astute enough to ensure that the correct processes are in place without using the bonus tolerance as a crutch. That "crutch" will burn ya every time!
Joe Quality
18th July 2000, 10:33 AM
Courtesy Access
Registration Date: Jul 2000
Karma Power: 40 Karma: 10
Spaceman, I tried a couple of models using what you presented and I am having trouble getting it to produce a valid result. Did you write it as it was originally written or is my coconut just being too thick on this subject? (LOL)
20th July 2000, 02:22 PM
We need to hear from "Batman" here (forum contributor). I used to work with Batman & he had a neat little formula to report capabilty on a MMC / LMC features. He reported it as "percent tolerance used". I really need him to explain it!!! All I know is, we worked for an automotive supplier (tier 1 & 2) and used this many, many times. It usually involved a call to our SQA to explain how the numbers were derived, but never a problem! Sorry I'm of no help in explaining the "hows". I always relied on "Batman". Now I'm without an action hero!
Peace.....out!
25th July 2000, 05:47 AM
Instead of adding the bonus to the tolerance, which could result in 20 different tolerances if measuring 20 parts, subtract the bonus from the measurment. One ends up with a fixed tolerance zone, although some never get over the negative lower limit for position which is a consequence of maximum possible bonus and perfect position. I presented a paper on the technique a number of years back at a conference.
25th May 2001, 12:24 PM
Involved in Discussions
Registration Date: Jul 2003
Thanks Given to Others: 1
Karma Power: 26 Karma: 10
I'm finding a lot of interesting information here, but I'm still confused! Before capability can be determined, we first must know that the process is in control. Is there any special consideration for characteristics associated with bonus tolerances? (I know "specifications" don't have anything to do with "control"). So, if I'm plotting a measurement, do I chart only the actual measurement result without any consideration for potential "bonus" values?
